[产品供应] 軍工宇航級晶振(TCXO、OCXO)
1976|0
 楼主| Oscillator21 发表于 2011-7-8 11:54 | 显示全部楼层 |阅读模式
我們提供如下軍工級晶體振盪器。歡迎諸位客戶隨時聯繫。
溫補晶振(TCXO); h" c5 G5 r: y& K  |
10MHz,5V, Sine 10kohm/10F, +/-0.5PPM, -40~+85'C,帶壓控,SMD7x5
12.8MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5
13MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5
16.384MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x59 T9 Y) X7 s( K8 W* n7 ^$ Y% G
19.44MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5& q) r, A* J0 B9 ~, ], d* U
20MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5
20MHz,3.3V, HCMOS 15pF, +/-0.28PPM, -40~+85'C,帶壓控,SMD7x50 ^* d7 H, u+ O: u$ Y" ?6 E- A
40MHz,3.3V, HCMOS 15pF, +/-0.28PPM, -40~+85'C,帶壓控,SMD7x5
10MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2
16.384MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2( c: |! `% y- B
19.2MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2
20MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2
32.768MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2& @2 @2 b; p! J- h& q, y+ K0 q
50MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2 " c! D7 @4 i1 |3 n+ S) S
軍工級TCXO(定制)
10~80MHz, 3.3V/5V, HCMOS/Sine, ±1PPM(-20!+70°), ±3PPM(-40~+85°C), DIP14/SMD, MIL-PRF-55310 Level B; X% z9 ~- f. ?, ~7 F+ X8 O
8 U5 g( x2 D% a9 h# @7 I, \4 Y" V
宇航級TCXO(定制)& Z- [8 {/ ^2 ?2 I4 `6 |4 _
2~150MHz, 5~15V, Sine,  ±2PPM(-20!+70°), ±4PPM(-40~+85°C), 100kRads, 32x20x7.6mm, 24Pin
/ T# o  o6 m5 W* |. \
恒溫晶振(OCXO,軍工宇航級,需訂制); J! i; C) \; ^; {
Frequency: 80~125MHz(典型頻率100MHz,、120MHz)* J% v& _3 n( Y8 n5 V: y& m
Supply voltage: 12V, 15V8 n5 k) k3 e, X: {2 q7 Z' c
Output wave: Sine 50ohm. _' n9 W. k3 ]
Frequency Stability: ±5E-7
Operating Temperature range: -40~+85°C
Phase noise: -135dBc/Hz@100Hz  -163dBc/Hz@1kHz (for 100MHz); L$ Q  C, t0 |. K' A: v3 y4 ^
                         -132dBc/Hz@100Hz  -160dBc/Hz@1kHz  (for 120MHz)
Aging: ±0.5ppm/1st year, ±2ppm/10 year2 z7 d- G1 P) R7 Y* Q& P
Vibration: Mil-STD-202G method 204 condition A: sinus 10-500Hz 10g
Shock: Mil-STD-202G method 213 condition A: half-sine 50g, 11ms! r) e, u2 M2 G7 i
Package: 51x51x26mm : j' k  o7 f0 V/ ]7 A
4 x  v' o$ }% f. S6 [
QQ: 3 5 8 5 4 1 1 4 2  手機:1 3 9 2 2 8 4 6 4 6 5
