ADC多通道采集,数据串位问题
3589|1
 楼主| hackthree 发表于 2011-7-9 14:11 | 显示全部楼层 |阅读模式
程序如下:
#define ADC1_DR_Address    ((u32)0x4001244C)
vu16 AD_Value[2];
void DMA_Configuration(void)
    DMA_InitTypeDef DMA_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    //BufferSize=2,因为ADC转换序列有2个通道
    //如此设置,使序列1结果放在AD_Value[0],序列2结果放在AD_Value[1]
    DMA_InitStructure.DMA_BufferSize = 2;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    //循环模式开启,Buffer写满后,自动回到初始地址开始传输
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    //配置完成后,启动DMA通道
void ADC_Configuration(void)
ADC_InitTypeDef   ADC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
/* ADC */
ADC_InitStructure.ADC_Mode                        = ADC_Mode_Independent;         //独立模式
ADC_InitStructure.ADC_ScanConvMode          = ENABLE;                                 //连续多通道模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                                //连续转换
ADC_InitStructure.ADC_ExternalTrigConv        = ADC_ExternalTrigConv_None; //转换不受外界决定
ADC_InitStructure.ADC_DataAlign                   = ADC_DataAlign_Right;           //右对齐
ADC_InitStructure.ADC_NbrOfChannel             = 2;                                       //扫描通道数
ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 Regular Channel1 Configuration                                      */
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_28Cycles5); //通道X,采用时间为28.5周期,1代表规则通道第1个
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 2, ADC_SampleTime_28Cycles5);//通道X,采用时间为28.5周期,2代表规则通道第2个
ADC_Cmd   (ADC1, ENABLE);             /* Enable ADC1                        */
ADC_DMACmd(ADC1, ENABLE); // 使能指定的ADC的DMA请求 ;
ADC_ResetCalibration(ADC1); // 重置指定的ADC的校准寄存器 ;
while(ADC_GetResetCalibrationStatus(ADC1)); // 获取ADC重置校准寄存器的状态 ;
   ADC_StartCalibration(ADC1);  // 开始指定ADC的校准程序 ;
   while(ADC_GetCalibrationStatus(ADC1)); // 获取指定ADC的校准状态 ;
我想把ADC_Channel_1的数据放AD_Value[0],ADC_Channel_0的数据放AD_Value[1]
可是调试的时候发现,
有时候是ADC_Channel_1的数据放AD_Value[0],ADC_Channel_0的数据放AD_Value[1],
但有时候却是ADC_Channel_1的数据放AD_Value[1],ADC_Channel_0的数据放AD_Value[0]了,
这是什么原因?
55948218 发表于 2013-5-30 23:18 | 显示全部楼层
楼主解决了吗。我也遇到类似的问题。设置和你的基本一样的。我的根本就采集不到。用DMA采集一路是对的。郁闷死了!
