protel PCB DRC 检查后都变成绿色了。提示很多错误,求救
6744|4
 楼主| 注册好烦 发表于 2011-7-12 20:14 | 显示全部楼层 |阅读模式
几乎是第一次画PCB。
提示说三极管短路了,我看了下没有短路呀。怎么可能短路呢?不都是按照飞线连的嘛
还有安全距离那个,我设置了0.33mm。怎么还会提示有安全距离的错误.连线的时候线与线之间的距离不就是按照安全距离确定的吗??
有人跟我说画的不能用的。我已经画了两天了呀 ,不会要重新画吧!惨了惨了,肯定死定了!!!!!
Processing Rule : Short-Circuit Constraint (Allowed=Not Allowed) (On the board ),(On the board )
   Violation between Track (43540mil,46140mil)(43540mil,46220mil)  TopLayer and
                     Pad Q3-2(43540mil,46280mil)  TopLayer
   Violation between Track (43780mil,46500mil)(43780mil,46580mil)  TopLayer and
                     Pad Q1-2(43780mil,46640mil)  TopLayer
   Violation between Track (43540mil,46500mil)(43540mil,46580mil)  TopLayer and
                     Pad Q2-2(43540mil,46640mil)  TopLayer
   Violation between Track (43820mil,46140mil)(43820mil,46220mil)  TopLayer and
                     Pad Q4-2(43820mil,46280mil)  TopLayer
   Violation between Track (40820mil,44200mil)(40820mil,44280mil)  TopLayer and
                     Pad Q9-2(40820mil,44340mil)  TopLayer
   Violation between Track (42060mil,45560mil)(42060mil,45640mil)  TopLayer and
                     Pad Q7-2(42060mil,45700mil)  TopLayer
   Violation between Track (42300mil,45560mil)(42300mil,45640mil)  TopLayer and
                     Pad Q8-2(42300mil,45700mil)  TopLayer
   Violation between Track (41080mil,44200mil)(41080mil,44280mil)  TopLayer and
                     Pad Q10-2(41080mil,44340mil)  TopLayer
   Violation between Track (41020mil,44620mil)(41020mil,44700mil)  TopLayer and
                     Pad Q6-2(41020mil,44760mil)  TopLayer
   Violation between Track (40780mil,44620mil)(40780mil,44700mil)  TopLayer and
                     Pad Q5-2(40780mil,44760mil)  TopLayer
Rule Violations :10
Processing Rule : Broken-Net Constraint ( (On the board ) )
Rule Violations :0
Processing Rule : Clearance Constraint (Gap=8mil) (On the board ),(On the board )
                     Track (42300mil,45700mil)(42300mil,45820mil)  TopLayer
                     Track (41020mil,44760mil)(41020mil,44805mil)  TopLayer
                     Track (43820mil,46280mil)(43820mil,46340mil)  TopLayer
                     Track (43780mil,46640mil)(43780mil,46680mil)  TopLayer
Rule Violations :14
yhf311 发表于 2011-7-12 20:26 | 显示全部楼层
提示的错误应该是短路和线之间小于安全间距
 楼主| 注册好烦 发表于 2011-7-14 12:12 | 显示全部楼层
2# yhf311 知道了,rules里面被我改过了。
这里用protel99se画图的不多呀!
渊深海阔 发表于 2011-7-14 13:59 | 显示全部楼层
规则需要改一下吧
uzb9401 发表于 2011-7-14 15:57 | 显示全部楼层
规则设置错了,需重新设置,当然如果板子不太复杂,可肉眼核对正确后,直接拿去做:P,做废了别找我啊
