IMX35开发上电时序问题求教
2969|0
 楼主| zhouyangc 发表于 2011-7-13 11:07 | 显示全部楼层 |阅读模式
有哪位兄弟用过IMX357没?我看厂家开发板上电时序和C手册上要求的有点不一样,不知道这样会不会有什么隐患,现在开板有点犹豫了,不知道按照开发板的做好,还是按照IC手册做好。
手册上要求:
The power-up sequence should be completed as follows:
1. Assert Power on Reset (POR).
2. Turn on digital logic domain and IO power supply: VDDn, NVCCx
3. Wait until VDDn and NVCCx power supplies are stable + 32 μs.
4. Turn on all other power supplies: PHY1_VDDA, USBPHY1_VDDA_BIAS, USBPHY1_UPLLVDD, OSC24M_VDD, OSC_AUDIO_VDD, MVDD, PVDD, FUSEVDD. (Always FUSE_VDD should be connected to ground, except when eFuses are to be programmed.)
5. Wait until PHY1_VDDA, USBPHY1_VDDA_BIAS, PHY2_VDD, USBPHY1_UPLLVDD, OSC24M_VDD, OSC_AUDIO_VDD, MVDD, PVDD, (FUSEVDD, optional). Power supplies are stable + 100 μs.
6. Deassert the POR signal.
也就是说,VDDn和NVCCx要先起来,OSC24M_VDD要后起来,但是我发现厂家提供的评估板OSC24M_VDD与NVCCx是接的同一个电源3.3V,并没有按照上面要求的时序连接。
