[DemoCode下载]
M051的I2C操作方式
3134|11
643757107|  楼主 | 2018-2-27 18:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 7 $
* $Date: 15/05/22 2:41p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series I2C Driver Sample Code (Master)
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      SYSCLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
/* Global variables        */
volatile uint8_t g_u8DeviceAddr;
volatile uint8_t g_au8MstTxData[3];
volatile uint8_t g_u8MstRxData;
volatile uint8_t g_u8MstDataLen;
volatile uint8_t g_u8MstEndFlag = 0;
typedef void (*I2C_FUNC)(uint32_t u32Status);
static volatile I2C_FUNC s_I2C0HandlerFn = NULL;
/*  I2C0 IRQ Handler        */
void I2C0_IRQHandler(void)
    uint32_t u32Status;
    u32Status = I2C_GET_STATUS(I2C0);
    if(I2C_GET_TIMEOUT_FLAG(I2C0))
        /* Clear I2C0 Timeout Flag */
        I2C_ClearTimeoutFlag(I2C0);
    else
        if(s_I2C0HandlerFn != NULL)
            s_I2C0HandlerFn(u32Status);
/*  I2C Rx Callback Function        */
void I2C_MasterRx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted and prepare SLA+W */
        I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1));    /* Write SLA+W to Register I2CDAT */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
    else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
        I2C_SET_DATA(I2C0, g_au8MstTxData[g_u8MstDataLen++]);
    else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
    else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
        if(g_u8MstDataLen != 2)
        else
            I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_SI);
    else if(u32Status == 0x10)                  /* Repeat START has been transmitted and prepare SLA+R */
        I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01));   /* Write SLA+R to Register I2CDAT */
    else if(u32Status == 0x40)                  /* SLA+R has been transmitted and ACK has been received */
    else if(u32Status == 0x58)                  /* DATA has been received and NACK has been returned */
        g_u8MstRxData = (unsigned char) I2C_GET_DATA(I2C0);
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
        printf("Status 0x%x is NOT processed\n", u32Status);
/*  I2C Tx Callback Function        */
void I2C_MasterTx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted */
        I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1);    /* Write SLA+W to Register I2CDAT */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        if(g_u8MstDataLen != 3)
        else
            g_u8MstEndFlag = 1;
    else
        /* TO DO */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART & I2C0 module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(I2C0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Configure the SDA0 & SCL0 of I2C0 pins */
    SYS->P3_MFP &= ~(SYS_MFP_P34_Msk | SYS_MFP_P35_Msk);
    SYS->P3_MFP |= SYS_MFP_P34_SDA0 | SYS_MFP_P35_SCL0;
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void I2C0_Init(void)
    /* Open I2C module and set bus clock */
    I2C_Open(I2C0, 100000);
    /* Get I2C0 Bus Clock */
    printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
    /* Set I2C 4 Slave Addresses */
    I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
    I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
    I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
    I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
    /* Enable I2C interrupt */
    I2C_EnableInt(I2C0);
    NVIC_EnableIRQ(I2C0_IRQn);
void I2C0_Close(void)
    /* Disable I2C0 interrupt and clear corresponding NVIC bit */
    I2C_DisableInt(I2C0);
    NVIC_DisableIRQ(I2C0_IRQn);
    /* Disable I2C0 and close I2C0 clock */
    I2C_Close(I2C0);
    CLK_DisableModuleClock(I2C0_MODULE);
int32_t I2C0_Read_Write_SLAVE(uint8_t slvaddr)
    uint32_t i;
    g_u8DeviceAddr = slvaddr;
    for(i = 0; i < 0x100; i++)
        g_au8MstTxData[0] = (uint8_t)((i & 0xFF00) >> 8);
        g_au8MstTxData[1] = (uint8_t)(i & 0x00FF);
        g_au8MstTxData[2] = (uint8_t)(g_au8MstTxData[1] + 3);
        g_u8MstDataLen = 0;
        g_u8MstEndFlag = 0;
        /* I2C function to write data to slave */
        s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
        /* I2C as master sends START signal */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
        /* Wait I2C Tx Finish */
        while(g_u8MstEndFlag == 0);
        g_u8MstEndFlag = 0;
        /* I2C function to read data from slave */
        s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterRx;
        g_u8MstDataLen = 0;
        /* Wait I2C Rx Finish */
        /* Compare data */
        if(g_u8MstRxData != g_au8MstTxData[2])
            printf("I2C Byte Write/Read Failed, Data 0x%x\n", g_u8MstRxData);
            return -1;
    printf("Master Access Slave (0x%X) Test OK\n", slvaddr);
    return 0;
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Lock protected registers */
    SYS_LockReg();
        This sample code sets I2C bus clock to 100kHz. Then, Master accesses Slave with Byte Write
        and Byte Read operations, and check if the read data is equal to the programmed data.
    printf("\n");
    printf("+-------------------------------------------------------+\n");
    printf("| M05xx I2C Driver Sample Code(Master) for access Slave |\n");
    printf("|                                                       |\n");
    printf("| I2C Master (I2C0) <---> I2C Slave(I2C0)               |\n");
    printf("Configure I2C0 as a master.\n");
    printf("The I/O connection for I2C0:\n");
    printf("I2C0_SDA(P3.4), I2C0_SCL(P3.5)\n");
    /* Init I2C0 */
    I2C0_Init();
    printf("\n");
    printf("Check I2C Slave(I2C0) is running first!\n");
    printf("Press any key to continue.\n");
    getchar();
    /* Access Slave with no address */
    printf("\n");
    printf(" == No Mask Address ==\n");
    I2C0_Read_Write_SLAVE(0x15);
    I2C0_Read_Write_SLAVE(0x35);
    I2C0_Read_Write_SLAVE(0x55);
    I2C0_Read_Write_SLAVE(0x75);
    printf("SLAVE Address test OK.\n");
    /* Access Slave with address mask */
    printf("\n");
    printf(" == Mask Address ==\n");
    I2C0_Read_Write_SLAVE(0x15 & ~0x01);
    I2C0_Read_Write_SLAVE(0x35 & ~0x04);
    I2C0_Read_Write_SLAVE(0x55 & ~0x01);
    I2C0_Read_Write_SLAVE(0x75 & ~0x04);
    printf("SLAVE Address Mask test OK.\n");
    /* Close I2C0 */
    I2C0_Close();
    while(1);
643757107|  楼主 | 2018-2-27 18:25 | 只看该作者
* @file     main.c
* @version  V3.00
* $Revision: 6 $
* $Date: 14/11/14 10:48a $
* @brief    M051 Series I2C Driver Sample Code (Slave)
* @note
#include <stdio.h>
uint32_t slave_buff_addr;
uint8_t g_au8SlvData[256];
uint8_t g_au8SlvRxData[3];
volatile uint8_t g_u8SlvDataLen;
static I2C_FUNC s_I2C0HandlerFn = NULL;
    uint32_t u32Status;
    else
/*  I2C TRx Callback Function        */
void I2C_SlaveTRx(uint32_t u32Status)
    if(u32Status == 0x60)                       /* Own SLA+W has been receive; ACK has been return */
        g_u8SlvDataLen = 0;
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI_AA);
    else if(u32Status == 0x80)                 /* Previously address with own SLA address
                                                   Data has been received; ACK has been returned*/
        g_au8SlvRxData[g_u8SlvDataLen] = (unsigned char) I2C_GET_DATA(I2C0);
        g_u8SlvDataLen++;
        if(g_u8SlvDataLen == 2)
            slave_buff_addr = (g_au8SlvRxData[0] << 8) + g_au8SlvRxData[1];
        if(g_u8SlvDataLen == 3)
            g_au8SlvData[slave_buff_addr] = g_au8SlvRxData[2];
            g_u8SlvDataLen = 0;
    else if(u32Status == 0xA8)                  /* Own SLA+R has been receive; ACK has been return */
        I2C_SET_DATA(I2C0, g_au8SlvData[slave_buff_addr]);
        slave_buff_addr++;
    else if(u32Status == 0xC0)                 /* Data byte or last data in I2CDAT has been transmitted
                                                   Not ACK has been received */
    else if(u32Status == 0x88)                 /* Previously addressed with own SLA address; NOT ACK has
                                                   been returned */
        g_u8SlvDataLen = 0;
    else if(u32Status == 0xA0)                 /* A STOP or repeated START has been received while still
                                                   addressed as Slave/Receiver*/
        g_u8SlvDataLen = 0;
    else
        /* TO DO */
void SYS_Init(void)
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    /* Set I2C 4 Slave Addresses Mask */
    I2C_SetSlaveAddrMask(I2C0, 0, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 1, 0x04);
    I2C_SetSlaveAddrMask(I2C0, 2, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 3, 0x04);
    I2C_Close(I2C0);
/*  Main Function        */
int32_t main(void)
    uint32_t i;
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    SYS_LockReg();
    printf("|  M05xx I2C Driver Sample Code(Slave) for access Slave |\n");
    printf("|                                                       |\n");
    printf("Configure I2C0 as a slave.\n");
    /* Init I2C0 */
    I2C0_Init();
    /* I2C enter no address SLV mode */
        g_au8SlvData[i] = 0;
    /* I2C function to Slave receive/transmit data */
    s_I2C0HandlerFn = I2C_SlaveTRx;
    printf("\n");
    printf("I2C Slave Mode is Running.\n");
    while(1);
第一个是主机模式,第二个是从机模式。
好多人说I2C不好用,最后选择IO模拟,不仅新唐,STM32的更难用,其实不是难,是你没有弄明白这个操作方式。
643757107|  楼主 | 2018-2-27 18:26 | 只看该作者
所以你多研究一下例子和手册,应该很容易掌握的。
jiekou001| | 2018-2-27 19:06 | 只看该作者
好像用到了回调函数,学一下,这个不是很熟。
xinpian101| | 2018-2-27 19:23 | 只看该作者
PLL时钟很稳的啊,看所有的例子都是PLL跑起来。
zhuotuzi| | 2018-2-27 19:31 | 只看该作者
新唐的RC时钟技术很成熟的。
heisexingqisi| | 2018-2-27 20:37 | 只看该作者
有些检测,如果忽略,会不会就不稳定了。
捉虫天师| | 2018-2-28 22:35 | 只看该作者
每个外设都有自己的时钟驱动线
xujunyi3611| | 2018-2-28 22:47 | 只看该作者
代码风格还是很规范的,赞一个。
kingkong520| | 2018-3-28 18:32 | 只看该作者
直接Copy官方的代码
