protel 99se 中如何设置DRC规则?
8424|6
 楼主| tkgg324 发表于 2011-7-15 16:38 | 显示全部楼层 |阅读模式
运行DRC时出现了很多这个
Processing Rule : Width Constraint (Min=0.254mm) (Max=0.254mm) (Prefered=0.254mm) (Is part of net class other )
   Violation         Polygon Arc (18.034mm,28.702mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Arc (26.416mm,31.242mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Arc (26.15163mm,33.397mm)  BottomLayer  Actual Width = 0.5mm
ycz9999 发表于 2011-7-16 00:17 | 显示全部楼层
Design->Options->System
 楼主| tkgg324 发表于 2011-7-16 08:35 | 显示全部楼层
   Violation         Polygon Track (26.15163mm,32.643mm)(26.434mm,32.643mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (26.434mm,31.873mm)(26.434mm,32.643mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (26.33929mm,31.86832mm)(26.33929mm,32.643mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (25.654mm,32.43961mm)(26.434mm,32.43961mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (25.654mm,31.93961mm)(26.434mm,31.93961mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (25.83929mm,31.55766mm)(25.83929mm,32.71073mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (25.654mm,31.37237mm)(25.654mm,32.83054mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (25.654mm,31.37237mm)(25.96975mm,31.68812mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (21.154mm,30.43961mm)(21.946mm,30.43961mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (21.154mm,29.93961mm)(21.946mm,29.93961mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (25.277mm,29.485mm)(25.277mm,29.646mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (24.83929mm,29.485mm)(24.83929mm,29.646mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (24.3393mm,29.485mm)(24.3393mm,29.646mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (21.946mm,29.646mm)(25.277mm,29.646mm)  BottomLayer  Actual Width = 0.5mm
   Violation         Polygon Track (23.8393mm,29.485mm)(23.8393mm,29.646mm)  BottomLayer  Actual Width = 0.5mm
还是有哦,
hzppanavo 发表于 2011-7-16 10:01 | 显示全部楼层
ycz9999 发表于 2011-7-16 13:02 | 显示全部楼层
你的线宽设置有问题哦
freeman05 发表于 2011-7-16 14:44 | 显示全部楼层
 楼主| tkgg324 发表于 2011-7-16 17:26 | 显示全部楼层
这个规则如何设置?
