H型大电流高容量CR锂锰电池解决方案
993|0
受到警告 楼主
comsan|  楼主 | 2018-3-16 17:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
适用蓝牙应用电池解决方案:
COMSAN® CR2032
Open-Circuit Voltage: ≥3.3V
Rated Voltage: 3.0V
End  Voltage: 2.0V
Operating Temp:-40℃ to 80℃
Self Discharge: ≤2% / year
Pulse Drain Discharge(Cyclic&Continuous):
20mAh 20ms on / 20ms off to 2.0 volts
Capacity: 145mAh
Normal Continuous Discharge:
15kΩ/0.19mAh to 2.0 volts
Capacity: 240mAh
Normal Discharge Time: ≥1260Hours
COMSAN® CR2025
Rated Voltage: 3.0V
End  Voltage: 2.0V
Capacity: 116mAh
Capacity: 170mAh
Normal Discharge Time: ≥860Hours
COMSAN® CR1632
Rated Voltage: 3.0V
End  Voltage: 2.0V
Capacity: 65mAh
Normal Continuous Discharge(Continuous):
Capacity: ≥140mAh
Normal Discharge Time: ≥730Hours
COMSAN® CR3032
Rated Voltage: 3.0V
End  Voltage: 2.0V
Capacity: 217mAh
6kΩ/0.5mAh to 2.0 volts
Capacity: 600mAh(Continuous)
Normal Discharge Time: ≥1200Hours
