F2812的485的实现
2808|3
gaochy1126|  楼主 | 2011-7-19 19:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
麻烦您们帮忙看下程序,怎么不管用:
#include "DSP28_Device.h"
unsigned int Sci_VarRx[100];
unsigned int i,j;
unsigned int Send_Flag;
void delay(unsigned int t);
void main(void)
/*初始化系统*/
InitSysCtrl();
/*关中断*/
DINT;
IER = 0x0000;
IFR = 0x0000;
/*初始化PIE中断*/
InitPieCtrl();
/*初始化GPIO*/
    InitGpio();
/*初始化PIE中断矢量表*/
InitPieVectTable();
/*初始化SCIB寄存器*/
    InitSci();
    for(i = 0; i < 100; i++)
     Sci_VarRx[i] = i;
    i = 0;
    j = 0;
    Send_Flag = 0;
   #if SCIB_INT      ///查看DSP28_Device.h,可用中断接收,但目前我们采用查询接收
//设置中断服务程序入口地址
EALLOW; // This is needed to write to EALLOW protected registers
PieVectTable.TXBINT = &SCITXINTB_ISR;
PieVectTable.RXBINT = &SCIRXINTB_ISR;
EDIS;   // This is needed to disable write to EALLOW protected registers
//开中断
IER |= M_INT9;
#endif
EINT;   // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
     for(;;)
   if((ScibTx_Ready() == 1) && (Send_Flag == 1))
      delay(10);
   ScibRegs.SCITXBUF = Sci_VarRx[i];
   Send_Flag = 0;
   i++;
   if(i == j)
    i = 0;
    j = 0;
   while(ScibTx_Ready() != 1); //等待发送结束
   delay(1000);
        if(ScibRx_Ready() == 1)
   Sci_VarRx[j] = ScibRegs.SCIRXBUF.all;
   Send_Flag = 1;
   j++;
   if(j == 100)
    j = 0;
unsigned int a,b;
  for(a=0;a<t;a++)
     for(b=0;b<100;b++);
ssdw| | 2011-7-19 20:03 | 只看该作者
我没看明白呀
:L
sqcumt123| | 2011-7-20 09:05 | 只看该作者
太多了,看不明白
