[应用相关] stm32f103c8t6串口3的问题
8037|24
 楼主| lefeng 发表于 2018-3-31 09:57 | 显示全部楼层 |阅读模式
stm32f103c8t6串口3能用吗,怎么怎么配置都不行,有没有哪位用过
void USART3_Initialise( u32 bound )
    NVIC_InitTypeDef NVIC_InitStructure;
    USART_InitTypeDef USART_InitStructure;
  /* Enable the USART3 Pins Software Remapping */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB| RCC_APB2Periph_AFIO ,ENABLE);
          GPIO_PinRemapConfig(GPIO_FullRemap_USART3, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
/* Configure USART3 Rx (PB.11) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure USART3 Tx (PB.10) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
/* Enable the USART3 Interrupt */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_InitStructure.USART_BaudRate = bound;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART3, &USART_InitStructure);
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
USART_Cmd(USART3, ENABLE);
USART_ClearFlag(USART3, USART_FLAG_TXE);
// USART3DATA[20]=0;
        void USART3_IRQHandler(void)                             //´®¿ÚÖжÏÊäÈë
        static u8 i = 0;
        u8 data = 0;
      if(USART_GetFlagStatus(USART3, USART_FLAG_RXNE) == SET)
       data = USART_ReceiveData(USART3);
                                //i++;
                                //if(i == 9)
                                        //i = 0;
                                        //temp1 = 1;
        USART_SendData(USART3, data);
mmuuss586 发表于 2018-3-31 09:58 | 显示全部楼层
103C8T6好像没有串口3吧
mmuuss586 发表于 2018-3-31 09:59 | 显示全部楼层
你上面的程序,发送和接收都不行吗?
CaLipton 发表于 2018-3-31 10:40 | 显示全部楼层
能用。以前用过。
Rospiers 发表于 2018-3-31 10:55 | 显示全部楼层
确定以前你用的是STM32F103C8T6,好像不行吧,STM32F103ZET6 可以用。复用映射的
Lewisnx 发表于 2018-3-31 11:05 | 显示全部楼层
c8t6是可以映射的
CCompton 发表于 2018-3-31 11:17 | 显示全部楼层
c8t6的串口3好像只能发送,不能接受
香水城 发表于 2018-4-3 23:35 | 显示全部楼层
除了注意管脚及时钟的配置外,如果是基于其它系列移植过来的话,注意选择正确的启动文件。
wishtoyou 发表于 2018-4-4 10:34 | 显示全部楼层
可以用的,先试试发送。
toofree 发表于 2018-4-4 11:59 | 显示全部楼层
USART3必须是能用的呀
cxz_00 发表于 2018-4-4 13:43 | 显示全部楼层
cxz_00 发表于 2018-4-4 13:44 | 显示全部楼层
soodesyt 发表于 2018-4-4 23:04 | 显示全部楼层
串口连接到PB10 pB11了?
mnynt121 发表于 2018-4-4 23:05 | 显示全部楼层
硬件问题吗
plsbackup 发表于 2018-4-4 23:05 | 显示全部楼层
示波器测了一下是不是有信号
kmzuaz 发表于 2018-4-4 23:07 | 显示全部楼层
寄存器能够读取吗
qiufengsd 发表于 2018-4-4 23:07 | 显示全部楼层
以前使用stm32f103vct6的
soodesyt 发表于 2018-4-4 23:07 | 显示全部楼层
检查下TX RX接反了没
mnynt121 发表于 2018-4-4 23:07 | 显示全部楼层
是不是波特率不同?
plsbackup 发表于 2018-4-4 23:08 | 显示全部楼层
看看串口的信号变化的幅值是多大的
