2812的adc模块
955|16
 楼主| CaLipton 发表于 2018-3-31 10:37 | 显示全部楼层 |阅读模式
void InitAdc(void)
        unsigned int i;
        AdcRegs.ADCTRL1.bit.RESET=1;
        NOP;
        AdcRegs.ADCTRL1.bit.RESET=0;
        AdcRegs.ADCTRL1.bit.SUSMOD=3;
        //仿真暂停时,序列发生器和其他数字电路逻辑立即停止
        AdcRegs.ADCTRL1.bit.ACQ_PS=0;
        //采样窗口大小,SOC脉冲宽度为1个ADCLK
        AdcRegs.ADCTRL1.bit.CPS=0;
        //核时钟预定标器,等于0,未将时钟进行2分频
        AdcRegs.ADCTRL1.bit.CONT_RUN=0;
        //运行于启动/停止模式
        AdcRegs.ADCTRL1.bit.SEQ_CASC=1;
        //级联方式
        AdcRegs.ADCTRL3.bit.ADCBGRFDN=3;
        for(i=0;i<10000;i++)        NOP;
        AdcRegs.ADCTRL3.bit.ADCPWDN=1;
        for(i=0;i<5000;i++)        NOP;
        AdcRegs.ADCTRL3.bit.ADCCLKPS=15;
        //ADCLK=HSPCLK/30
        AdcRegs.ADCTRL3.bit.SMODE_SEL=0;
        //采用顺序采样模式
        AdcRegs.MAX_CONV.bit.MAX_CONV=15;
        //总共采样16路
        AdcRegs.CHSELSEQ1.bit.CONV00=0;
        AdcRegs.CHSELSEQ1.bit.CONV01=1;
        AdcRegs.CHSELSEQ1.bit.CONV02=2;
        AdcRegs.CHSELSEQ1.bit.CONV03=3;
        AdcRegs.CHSELSEQ2.bit.CONV04=4;
        AdcRegs.CHSELSEQ2.bit.CONV05=5;
        AdcRegs.CHSELSEQ2.bit.CONV06=6;
        AdcRegs.CHSELSEQ2.bit.CONV07=7;
        AdcRegs.CHSELSEQ3.bit.CONV08=8;
        AdcRegs.CHSELSEQ3.bit.CONV09=9;
        AdcRegs.CHSELSEQ3.bit.CONV10=10;
        AdcRegs.CHSELSEQ3.bit.CONV11=11;
        AdcRegs.CHSELSEQ4.bit.CONV12=12;
        AdcRegs.CHSELSEQ4.bit.CONV13=13;
        AdcRegs.CHSELSEQ4.bit.CONV14=14;
        AdcRegs.CHSELSEQ4.bit.CONV15=15;
        AdcRegs.ADC_ST_FLAG.bit.INT_SEQ1_CLR=1;
        //清除SEQ1中的中断标志位INT_SEQ1
        AdcRegs.ADC_ST_FLAG.bit.INT_SEQ2_CLR=1;
        //清除SEQ2中的中断标志位INT_SEQ2
        AdcRegs.ADCTRL2.bit.EVB_SOC_SEQ=0;
        AdcRegs.ADCTRL2.bit.RST_SEQ1=0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1=1;
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ1=0;
        AdcRegs.ADCTRL2.bit.EVA_SOC_SEQ1=0;
        AdcRegs.ADCTRL2.bit.EXT_SOC_SEQ1=0;
        AdcRegs.ADCTRL2.bit.RST_SEQ2=0;
        AdcRegs.ADCTRL2.bit.SOC_SEQ2=0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ2=0;
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ2=0;
        AdcRegs.ADCTRL2.bit.EVB_SOC_SEQ2=0;
        AdcRegs.ADCTRL2.bit.SOC_SEQ1=1;
ADCINA0-7,ADCINB0-7,ADCLO 都接DGND,存储ad转换的寄存器值不为0,adcin引脚接0-3V的电压,寄存器的值也不变,是什么原因,求好心人赐教,谢谢!
Rospiers 发表于 2018-3-31 10:56 | 显示全部楼层
先运行下例程,确定是不是你的DSP的AD模块坏了
Lewisnx 发表于 2018-3-31 11:06 | 显示全部楼层
ADCLO是接模拟地的
CCompton 发表于 2018-3-31 11:18 | 显示全部楼层
看下你的AD结果存在哪里了
Richardd 发表于 2018-3-31 11:27 | 显示全部楼层
取结果是否正确,每个ADC要放到对应通道里
Mattheww 发表于 2018-3-31 11:39 | 显示全部楼层
我也遇到了,B0的采样结果一直就是这样!
baimiaocun2015 发表于 2018-3-31 19:00 | 显示全部楼层
adc的设计还是比较不错的资料
kkzz 发表于 2018-3-31 22:04 | 显示全部楼层
数据是多大?
hudi008 发表于 2018-3-31 22:04 | 显示全部楼层
就是没有正常采样。
lzmm 发表于 2018-3-31 22:04 | 显示全部楼层
使用的是定时器触发
minzisc 发表于 2018-3-31 22:05 | 显示全部楼层
如果配置正确,ADC也会变化的。
selongli 发表于 2018-3-31 22:05 | 显示全部楼层
怎么不使用外部的ADC呢?
kkzz 发表于 2018-3-31 22:09 | 显示全部楼层
是不同的IO采样吗?
hudi008 发表于 2018-3-31 22:09 | 显示全部楼层
ADC采样没有触发
lzmm 发表于 2018-3-31 22:09 | 显示全部楼层
顺序采样触发才可以。
minzisc 发表于 2018-3-31 22:09 | 显示全部楼层
应该是ADC有问题。
selongli 发表于 2018-3-31 22:10 | 显示全部楼层
外部的ADC芯片比较高端一些。
