[ARM入门] ARM开发的问题1
1113|2
 楼主| wangxd5429 发表于 2018-4-2 16:09 | 显示全部楼层 |阅读模式
ARM, ST, pc, se, TI
各位高手,小弟基于友善之臂的MINI6410开发板编写裸板定时器中断程序。将裸板程序复制到SD卡中,设置开发板模式为SD卡启动。运行发现:系统未跳转到IRQ异常向量处执行。请教其中的原因。谢谢!启动文件内容如下:
.text
.globl _start
_start:
        b        reset
        ldr        pc, _undefined_instruction
        ldr        pc, _software_interrupt
        ldr        pc, _prefetch_abort
        ldr        pc, _data_abort
        ldr        pc, _not_used
        ldr        pc, _irq
        ldr        pc, _fiq
_undefined_instruction:
        .word undefined_instruction
_software_interrupt:
        .word software_interrupt
_prefetch_abort:
        .word prefetch_abort
_data_abort:
        .word data_abort
_not_used:
        .word not_used
_irq:
        .word irq
_fiq:
        .word fiq
_pad:
        .word 0x12345678 /* now 16*4=64 */
reset:
        ldr r0 , =0x7e004000
        mov r1 , #0x0
        str r1 , [r0]
        /*复制中断向量表至0x0*/
        mov r8 , #0
        adr r9 , _start
        ldmia r9! , {r0-r7}
        stmia r8! , {r0-r7}
        ldmia r9! , {r0-r7}
        stmia r8! , {r0-r7}
        ldr sp, =1024*4
        bl main
* exception handlers
        .align        5
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        bl        do_undefined_instruction
        .align        5
software_interrupt:
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        bl        do_software_interrupt
        .align        5
prefetch_abort:
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        bl        do_prefetch_abort
        .align        5
data_abort:
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        bl        do_data_abort
        .align        5
not_used:
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        bl        do_not_used
        .globl irq
        /*import c_irq_handler*/
        .align        5
irq:
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        /*stmfd sp!, {r0-r12, lr}                ;保存现场 */
        bl c_irq_handler                        /*调用中断处理子程序*/
        /*ldmfd sp!, {r0-r12, lr}                ;恢复现场*/
        /*subs pc, lr, #4*/
        /*END*/
        .align        5
fiq:
        ldr r0, =0x7f008800
        ldr r1, =0x11110000
        str r1, [r0]
        ldr r0, =0x7f008808
        ldr r1, =0x0
        str r1, [r0]
        bl        do_fiq
ayb_ice 发表于 2018-4-4 13:59 | 显示全部楼层
ARM7,都淘汰了
中断开了没
 楼主| wangxd5429 发表于 2018-4-9 10:32 | 显示全部楼层
ARM7,都淘汰了
中断开了没
在main函数中已经使能中断了。
