stm8串口中断接收
3572|0
 楼主| vectory 发表于 2011-7-21 13:34 | 显示全部楼层 |阅读模式
/* MAIN.C file
* Copyright (c) 2002-2005 STMicroelectronics
#include <stm8s105s6.h>
#include <stm8s105c_s.h>
void uart_Interrupt (void);
extern unsigned char data;
static void delay5ms(void)
unsigned char i;
for(i=0;i<100;i++);
static void delay100ms(void)
unsigned char i;
for(i=0;i<20;i++)
  {for(i=0;i<100;i++);}
void Sendchar(unsigned char byte)
{   PC_ODR =0X02;
  delay5ms();
   UART2_SR;
  UART2_DR=byte; //
    //while(!(UART2_SR & 0X80));
    //while(!(UART2_SR & 0X40));
   while (!_btst(UART2_SR,7));
   while (!_btst(UART2_SR,6));
  UART2_DR;
   //delay5ms();
  PC_ODR = 0X00;
  //delay5ms();
unsigned char k_read (void)
{if((UART2_SR & 0X20))
   if((UART2_SR & 0X28))
   return UART2_DR;
main()
//unsigned char a[20];
unsigned char i;
unsigned char a=0,flag;
void Sendchar(unsigned char byte);
void senddata(unsigned char buff[],unsigned int length);
void startsend(unsigned char buff[],unsigned char length);
unsigned char k_read (void);
//char putchar (char c);
CLK_CKDIVR&= 0X00;
CLK_CKDIVR|= 0X08;  //clk= 8MHZ
UART2_CR2 = 0X00;//disable rx tx
UART2_CR1 = 0X00;//uart enable m=0 8 bits data
UART2_CR3 = 0X00;//stop bit = 1
//UART2_BRR2 = 0X0B;//baud rate = 115200
//UART2_BRR1 = 0X08;
UART2_BRR2 = 0X01;//baud rate = 9600
UART2_BRR1 = 0X34;
//UART2_BRR2 = 0X0B;//baud rate = 14400
//UART2_BRR1 = 0X22;
UART2_CR2  = 0x1c;
//UART2_SR;
  _bset(PC_DDR,1);
_bset(PC_CR1,1);
_bset(PC_CR2,1);
_bset (PC_ODR,1);
_asm("rim");
  while (1)
   UART2_CR2|=0x20;//接受中断开启
   PC_ODR= 0X00;
  delay100ms();
   PC_ODR = 0X02;
   UART2_DR = a;
   //   while (!_btst(UART2_SR,7));
    // while (!_btst(UART2_SR,6));
   Sendchar(a);
  a++;
    delay5ms();
@near @interrupt void uart_Interrupt (void)
// if(_btst(UART2_SR , 5))//UART2_SR & 0X20 ==0X20
   data = UART2_DR;
   _bset(UART2_SR , 5);//UART2_SR &= 0XDF;
   //UART2_DR =data;
   //if (_btst (UART2_SR ,3))
// UART2_DR;
  PC_ODR = 0X02;
//UART2_CR2 &=(~0x20);//接受中断关闭
是利用485通信PC1接485使能端,单步可以实现接收数据,RUN的话一直是00;
各位大哥帮忙看看
