示例问题
2464|38
 楼主| shimx 发表于 2018-4-9 16:40 | 显示全部楼层 |阅读模式
dc, ADC, AD, ADC1, RS
就是这个
//  MSP430F21x2 Demo - ADC10, DTC Sample A2-0, AVcc, Single Sequence, DCO
//  Description: Sample A2/A1/A0 as single sequence with reference to AVcc.
//  Software sets ADC10SC to trigger sample sequence. In Mainloop MSP430 waits
//  in LPM0 to save power until ADC10 conversion complete, ADC10_ISR(DTC) will
//  force exit from any LPMx in Mainloop on reti. ADC10_ISR will force LPM0
//  exit. ADC10 internal oscillator times sample period (16x) and conversion
//  (13x). DTC transfers conversion code to RAM 200h - 206h. P1.0 set at start
//  of conversion burst, reset on completion.
//               MSP430F21x2
//        /|\|              XIN|-
//         --|RST          XOUT|-
//       >---|P2.2/A2      P1.0|-->LED
//       >---|P2.1/A1          |
//       >---|P2.0/A0          |
//  A. Dannenberg
//  Texas Instruments Inc.
//  December 2007
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include "msp430x21x2.h"
void main(void)
   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
   ADC10CTL1 = INCH_2 + CONSEQ_1;            // A2/A1/A0, single sequence
   ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
   ADC10DTC1 = 0x03;                         // 3 conversions
   ADC10AE0 |= 0x07;                         // P2.2,1,0 ADC10 option select
   P1DIR |= 0x01;                            // Set P1.0 output
   for (;;)
     ADC10CTL0 &= ~ENC;
     while (ADC10CTL1 & BUSY);               // Wait if ADC10 core is active
     ADC10SA = 0x200;                        // Data buffer start
     P1OUT |= 0x01;                          // P1.0 = 1
     ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
     __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
     P1OUT &= ~0x01;                         // P1.0 = 0
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
   __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
 楼主| shimx 发表于 2018-4-9 16:44 | 显示全部楼层
想问下A2,A1,A0口的转换好的数据都放在哪了
liliang9554 发表于 2018-4-9 16:47 | 显示全部楼层
没看懂啊
 楼主| shimx 发表于 2018-4-9 16:49 | 显示全部楼层
该怎样调用转换好的数据呀
yszong 发表于 2018-4-9 16:52 | 显示全部楼层
ADC10MEM好像只能存放一个数据吧
liliang9554 发表于 2018-4-9 16:56 | 显示全部楼层
ADC10MEM确实只放一个数据
zhaoxqi 发表于 2018-4-9 16:58 | 显示全部楼层
嗯,每次转换完成ADC10IFG会置位一次
 楼主| shimx 发表于 2018-4-9 17:01 | 显示全部楼层
什么方式啊?
zhenykun 发表于 2018-4-9 17:05 | 显示全部楼层
先是A2 然后A1 再是A0
liliang9554 发表于 2018-4-9 17:08 | 显示全部楼层
jiahy 发表于 2018-4-9 17:11 | 显示全部楼层
有相对应的ad数据寄存器吧。
lizye 发表于 2018-4-9 17:13 | 显示全部楼层
Sample A2/A1/A0 as single sequence with reference to AVcc,这个说的是单通道以此转换的啦,所以啦就是用在同一个ADC10MEM中也是没啥问题的啦
wuhany 发表于 2018-4-9 17:18 | 显示全部楼层
只要有足够的时间以此重ADC10MEM中读取出这些数据的就Ok啦
heweibig 发表于 2018-4-9 17:20 | 显示全部楼层
有什么问题呢?看着没什么问题,你实际使用的时候,替换宏定义的IO就可以了
 楼主| shimx 发表于 2018-4-9 17:25 | 显示全部楼层
嗯,我知道了,多谢大家 啊
jiaxw 发表于 2018-4-9 17:28 | 显示全部楼层
楼主是代码粘贴了,没有说问题。
zhaoxqi 发表于 2018-4-9 17:30 | 显示全部楼层
 楼主| shimx 发表于 2018-4-9 17:34 | 显示全部楼层
嗯,我知道了,多谢大家 啊
51xlf 发表于 2018-4-9 21:40 | 显示全部楼层
ADC10有16个采样通道A0~A15
i1mcu 发表于 2018-4-9 21:42 | 显示全部楼层
可以读取ADC10MEM
