哈哈哈……原来老外也互相抄袭啊,而且是业界知名半导体
3291|15
soso| | 2007-10-13 10:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AN, se, TI, ic, TE
“The CD4013B dual D      flip-flop      is a monolithic complementary MOS (CMOS) integrated circuit constructed with N- and P-channel enhancement mode transistors. Each flip-flop has independent data, set, reset, and clock inputs and ``Q' and ``Q' outputs. These devices can be used for shift register applications, and by connecting ``Q' output to the data input, for counter and toggle applications. The logic level present at the ``D' input is transferred to the Q output during the positive-going transition of the clock pulse. Setting or resetting is independent of the clock and is accomplished by a high level on the set or reset line respectively.”
“The CD4013B dual D-type flip-flop      is a monolithic complementary MOS (CMOS) integrated circuit constructed with N- and P-channel enhancement mode transistors. Each flip-flop has independent data, set, reset, and clock inputs and â€œQ” and â€œQ” outputs. These devices can be used for shift register applications, and by connecting â€œQ” output to the data input, for counter and toggle applications. The logic level present at the â€œD” input is transferred to the Q output during the positive-going transition of the clock pulse. Setting or resetting is independent of the clock and is accomplished by a high level on the set or reset line respectively.”
哈哈,是不是完全一样?
http://www.fairchildsemi.com/ds/CD/CD4013BC.pdf
http://www1.national.com/ds.cgi/CD/CD4013BM.pdf
maychang| | 2007-10-13 10:34 | 只看该作者
很正常的事,不是抄袭
51系列单片机是Intel公司设计的,其它各厂家生产的都是向Intel买了许可证,当然同时也带着所有的技术资料。
chunyang| | 2007-10-13 11:33 | 只看该作者
楼主说的这两家公司更不是什么抄袭了,而是有一段“传奇
    楼主提到的第一家公司叫“仙童”,第二家叫“国半”(国家半导体),仙童公司是硅谷的奠基者,IC的商品化生产方法就是由仙童发明,当年很多半导体界的传奇人物和传奇事件也与仙童有关,比如“摩尔定律”等等。仙童也是包括国半、Intel、AMD等著名硅谷半导体公司的“生母”,其中血统最纯的就算是国半了。仙童在世界半导体产业曾经起过非常重要的作用,当时(1960S)的影响远超现在的Intel,像4000系列CMOS电路、74系列TTL电路等的标准制订仙童起的是主导作用,在80年代初出版的著名畅销书《硅谷热》(Silicon Valley Fever)中写到:“硅谷大约70家半导体公司的半数,是仙童公司的直接或间接后裔。在仙童公司供职是进入遍布于硅谷各地的半导体业的途径。1969年在森尼维尔举行的一次半导体工程师大会上, 400位与会者中,未曾在仙童公司工作过的还不到24人。”从这个意义上讲,说仙童半导体公司是“硅谷人才摇篮”毫不为过。
    但大量“出血”繁荣了硅谷的同时仙童自己却逃不了衰弱的**,到1970S末,仙童已到了破产倒闭的地步,最终于1979年被出售。仙童公司倒了,但仙童品牌还是极具分量的,所谓“瘦死骆驼比马大”,几经转手包括换了法国、日本等几个东家,仙童最终被国半收购,国半的核心正是当年从仙童“叛逃”的核心,CEO都是同一个人,仙童这算是“回家”了。
    目前,仙童作为国家半导体的全资子公司独立运作。
McuPlayer| | 2007-10-13 12:08 | 只看该作者
佩服
chunyang兄见多识广
edanzg| | 2007-10-13 12:31 | 只看该作者
呵呵,都是肖克利的门徒,
HWM| | 2007-10-13 12:42 | 只看该作者
其实硅谷的演变史,
充分演绎了当代半导体乃至整个当代技术的发展历程。其具有相当的借鉴价值。
mVA| | 2007-10-13 13:14 | 只看该作者
原来国半与仙童还有这样一段关系!
maychang| | 2007-10-13 13:30 | 只看该作者
回楼上
各大公司之间的这样的故事多得很,仙童(Fairchild,费尔柴尔德)与国半之间仅仅是几百个这样的故事中的一个。
世界上第一片模拟集成电路是仙童公司做出来的。
vr2whf| | 2007-10-14 01:46 | 只看该作者
Fairchild已在1997年从国半独立出来了
在共同利益或互补情况下, 外国公司之间有很多技术转移, 大家有同样的设计是不奇怪的.
再者, 有部分专利权过了一定时限之後就会废了, 人家也就可以合法模仿.
外国公司十分注重版权的, 因为仲值钱的不是血汗, 而是知识.
computer00| | 2007-10-14 02:11 | 只看该作者
中文名应该叫飞兆半导体了吧
风...|  楼主 | 2007-10-14 02:12 | 只看该作者
嘿,还有这么多历史啊,涨见识了!顶!
HWM| | 2007-10-14 10:33 | 只看该作者
00:那是直译拉,我还是喜欢"仙童",还是早期的译法好.
computer00| | 2007-10-14 10:35 | 只看该作者
没办法,这是官方给的名字,我们也只好这样用.
maychang| | 2007-10-14 10:40 | 只看该作者
音乐乐乐 在电测仪表版面问买示波器是买安捷伦的还是买泰
安捷伦就是从惠普公司分出来的。
chunyang| | 2007-10-14 13:58 | 只看该作者
仙童并非真正的独立,而是国半的子公司
    国半重新整合了仙童的产品线,令其独立运作,但仍在国半的全球战略框架内。当前国际市场环境下,大公司的战略两级分化严重,东方企业仍在追求大而全,西方企业则流行拆分,HP吃掉了Compaq及其未消化的DEC,负担很重,所以将其立家之本测量仪器拆分成立安捷伦以轻装觊觎PC老大的位置;Motorola则将其半导体业务拆分出ON和Freescale以Moto跟Nokia争霸;西门子则拆分出英飞凌;Philips在同一招牌下拆分,其半导体部分现在成了NXP;AMD为了和Intel在CPU产业上竞争,也准备将其Flash业务拆分……所有这些策略都是为了在特定的方向上优化资源以图全球霸业。
开发过程| | 2007-10-14 16:01 | 只看该作者
一个公司而已
国半是老板,仙童是打工的。
