晕了!下载问题!真没办法了!
9623|32
 楼主| gupai1010 发表于 2011-7-22 20:05 | 显示全部楼层 |阅读模式
Active mode is BS
INFO:iMPACT:2648 - Failed to close Repository.
GUI --- Auto connect to cable...
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusbdfwu.sys found.
Driver version: src=1027, dest=1027.
Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Cable PID = 0008.
Max current requested during enumeration is 280 mA.
Type = 0x0605.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1100.
File version of C:/Xilinx/12.3/ISE_DS/ISE/data/xusbdfwu.hex = 1100.
Firmware hex file version = 1100.
PLD file version = 0012h.
PLD version = 0012h.
PROGRESS_END - End Operation.
Elapsed time =
0 sec.
Type = 0x0605.
ESN not available for this cable.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: ������ ����PROGRESS_START - Starting Operation.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc95288xl, Version : 5
INFO:iMPACT:1777 -
Reading C:/Xilinx/12.3/ISE_DS/ISE/xc9500xl/data/xc95288xl.bsd...
INFO:iMPACT:501 - '1': Added Device xc95288xl successfully.
'1': : Manufacturer's ID = Unknown
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
'2': : Manufacturer's ID = Unknown
'3': : Manufacturer's ID = Unknown
'4': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '5':The part does not appear to be Xilinx Part.
'5': : Manufacturer's ID =Unknown , Version : 8
INFO:iMPACT:1588 - '6':The part does not appear to be Xilinx Part.
'6': : Manufacturer's ID =Unknown , Version : 9
'7': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '8':The part does not appear to be Xilinx Part.
'8': : Manufacturer's ID =Unknown , Version : 11
'9': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '10':The part does not appear to be Xilinx Part.
'10': : Manufacturer's ID =Unknown , Version : 15
'11': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '12':The part does not appear to be Xilinx Part.
'12': : Manufacturer's ID =Unknown , Version : 15
'13': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '14':The part does not appear to be Xilinx Part.
'14': : Manufacturer's ID =Unknown , Version : 15
INFO:iMPACT:1588 - '15':The part does not appear to be Xilinx Part.
'15': : Manufacturer's ID =Unknown , Version : 15
'16': : Manufacturer's ID = Unknown
'17': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '18':The part does not appear to be Xilinx Part.
'18': : Manufacturer's ID =Unknown , Version : 5
'19': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '20':The part does not appear to be Xilinx Part.
'20': : Manufacturer's ID =Unknown , Version : 15
'21': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '22':The part does not appear to be Xilinx Part.
'22': : Manufacturer's ID =Unknown , Version : 15
INFO:iMPACT:1588 - '23':The part does not appear to be Xilinx Part.
'23': : Manufacturer's ID =Unknown , Version : 15
'24': : Manufacturer's ID = Unknown
'25': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '26':The part does not appear to be Xilinx Part.
'26': : Manufacturer's ID =Unknown , Version : 5
INFO:iMPACT:1588 - '27':The part does not appear to be Xilinx Part.
'27': : Manufacturer's ID =Unknown , Version : 7
'28': : Manufacturer's ID = Unknown
'29': : Manufacturer's ID = Unknown
INFO:iMPACT:1588 - '30':The part does not appear to be Xilinx Part.
'30': : Manufacturer's ID =Unknown , Version : 15
INFO:iMPACT - iMPACT quit the Identify Chain because it detects there are
at least 30 'UNKNOWN' type devices on the chain.
Please check the hardware settings and retry!
Elapsed time =
13 sec.
Cable is not connected.
�� 22 18:11:54 2011
晕了,以前用的好好,隔了几个星期,去用出现下载不了问题。上述是 ISE iIMPACT软件里, initialize chain 之后,出现对话框:there are many unkown device.出现的错误代码入上所述。
下载线换了又换,接口连的肯定没问题。CPLD供电也正常。问题到底出在哪?
急盼回复
软件 是ISE12.3
CPLD 是xilinx的 XC95系列
仿真器是 U口+JATG
星星之火红 发表于 2011-7-22 22:22 | 显示全部楼层
不好分析啊~~不知道大圣来不来
 楼主| gupai1010 发表于 2011-7-23 09:23 | 显示全部楼层
我都怀疑是CPLD坏了?可换一次芯片实在不容易
dan_xb 发表于 2011-7-23 13:18 | 显示全部楼层
你的TDI在CPLD之前短路了
查一下
话说,你用95288划不来啊,还不如Spartan-3 50AN
星星之火红 发表于 2011-7-23 17:05 | 显示全部楼层
是呀,还不如S3 50AN
AutoESL 发表于 2011-7-23 17:47 | 显示全部楼层
 楼主| gupai1010 发表于 2011-7-23 22:38 | 显示全部楼层
4# dan_xb
侧过了, 不短路,TDO也不短路,几个信号都不短路
 楼主| gupai1010 发表于 2011-7-23 22:39 | 显示全部楼层
6# 星星之火红
该一次硬件 不太容易 ,再说也没有那些东西
dan_xb 发表于 2011-7-23 22:42 | 显示全部楼层
不短路的话,有没有开路?
查TDI
 楼主| gupai1010 发表于 2011-7-23 22:42 | 显示全部楼层
问一下你们电脑设备管理器 里面 显示不显示xilinx usb cable 驱动?
我把下载线第一次插上的时候,自动寻找驱动,找到了,也安装完成了,怎么设备管理器不显示。是不是这个驱动的问题。
星星之火红 发表于 2011-7-23 23:37 | 显示全部楼层
11# gupai1010 这个方法可以试一试:)
dan_xb 发表于 2011-7-24 10:13 | 显示全部楼层
我觉得有点奇怪,你是手动在扫面链里面添加的CPLD吗?
不是应该自动去识别的吗?
 楼主| gupai1010 发表于 2011-7-24 13:48 | 显示全部楼层
13# dan_xb
是自动u识别的,现在识别不了。因为以前可以用,我用的是以前建好的工程,生成过.jed文件,所以可以手动添加,但是因为连不上硬件,所以即使添加上 也下载不了程序
greenapl1985 发表于 2011-7-24 20:06 | 显示全部楼层
接JTAG的时候好像不会显示吧,接UART时才会显示吧,不记得了
GoldSunMonkey 发表于 2011-7-24 22:38 | 显示全部楼层
先查驱动吧,如果驱动没问题。检查电路吧。如果没有错,就80%是片子坏了。另外20%是虚焊了
评分
参与人数 1威望 +1 收起 理由
nongfuxu + 1
查看全部评分
 楼主| gupai1010 发表于 2011-7-25 18:18 | 显示全部楼层
驱动没问题,我在资源管理器里可以看到显示xilinx usb。我用示波器测了一下 输入 输出信号和时钟,全是高电平,大概3.3V的样子。
 楼主| gupai1010 发表于 2011-7-25 22:09 | 显示全部楼层
难道真是芯片坏了?还有其他的可能吗,怎么板子放了两个星期,芯片会坏了 ?
hjjnet 发表于 2011-7-26 10:41 | 显示全部楼层
1. 先看你的PC+USB下载线有没问题,加到其他板子上试一下
2. 把下载线的速度降低到最低速750试一下
AutoESL 发表于 2011-7-26 12:21 | 显示全部楼层
以前遇到过类似的情况,好好的东西,放几周就有问题了.
可能是板子上面的配置开关不正确,不小心动过了
或者板子上面哪里松动了,都有可能
万一不行就摔几下:lol
