[产品供应]
铜编织线 单丝0.04,0.05,0.07单丝软铜编织线
390|0
铜编织线 单丝0.04,0.05,0.07单丝软铜编织线由东莞市雅杰电子材料有限公司生产0.04单丝,0.05单丝,0.07单丝,0.10单丝,0.15单丝方型铜编织线,采用多根0.04单丝,0.05单丝或0.07单丝,经8锭,12锭双向编织而成,经出线口挤压成预定的宽度和厚度。单锭单丝可达2000多芯,截面积从2平方-50平方,摇摆性能稳定,柔韧性能高,适用于电器开关连接线,主要是DW45触头,CM1连接线,空气开关连接线。编织线的直流电阻率(20℃)不大于0.022Ω.mm2/m,镀锡铜编织线的直流电阻率(20℃)不大于0.0234Ω.mm2/m。欢迎来电定制加工。
