430 序列通道单次转换问题
795|4
Richardd|  楼主 | 2018-5-26 17:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
dc, AD, ADC, ADC1, se
我想实现的功能为:通过8个通道采集AD,定时器触发采样率为1个周期80个点,然后将通道ADC12CH_0和通道ADC12CH_1采集的数据存储在开辟的两段FRAM区域里面,用序列通道(ADC12CONSEQ_1)采。但是,不能进入中断。不知道啥原因,下面是程序部分,请各位大神帮忙解答!万分感谢。(注:我用的MCU是MSP430FR5969)
#include <msp430.h>
#define FRAM_TEST_START0 0x9000
#define FRAM_TEST_START1 0xD000
volatile unsigned long ADC_Data[8];
unsigned char count = 0;
unsigned long *FRAM_write_ptr;
void GPIOInit(void)
    // Configure all un-used GPIO to lowest power state
    P1DIR = 0xFF;
    P1OUT = 0;
    P1SEL1 |= BIT0 | BIT1 | BIT2 | BIT3 | BIT4 | BIT5;// Configure P1.0 P1.1 P1.2 P1.3 P1.4 P1.5for ADC
    P1SEL0 |= BIT0 | BIT1 | BIT2 | BIT3 | BIT4 | BIT5;// A0~A5
    P2DIR = 0xFF;
    P2OUT = 0;
//    P2OUT = 0xFF;
    P2SEL1 |= BIT3 | BIT4; // Configure P2.3 and P2.4 for ADC
    P2SEL0 |= BIT3 | BIT4; // A6~A7
    P3DIR = 0xFF;
    P3OUT = 0;
//    P2OUT = 0xFF;
    P4DIR = 0xFF;
    P4OUT = 0;
    PJOUT = 0;
    PJSEL0 = BIT4 | BIT5;                   // For XT1
    PJDIR = 0xFFFF;
    // Disable the GPIO power-on default high-impedance mode to activate
    // previously configured port settings
    PM5CTL0 &= ~LOCKLPM5;
void clockInit(void)
    // Clock System Setup
    CSCTL0_H = CSKEY >> 8;                  // Unlock CS registers
    CSCTL1 = DCOFSEL_6;                     // Set DCO to 8MHz
    CSCTL2 = SELA__LFXTCLK | SELS__DCOCLK | SELM__DCOCLK;   // Set ACLK = XT1; MCLK = SMCLK = DCO
    CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1;   // Set all dividers
    CSCTL4 &= ~LFXTOFF;                     // Enable LFXT1
    do
        CSCTL5 &= ~LFXTOFFG;                // Clear XT1 fault flag
        SFRIFG1 &= ~OFIFG;
    } while (SFRIFG1 & OFIFG);              // Test oscillator fault flag
    CSCTL0_H = 0;                           // Lock CS registers
void TimerInit(void)
    // Configure Timer0_A
    TA0CCR0 = 8-1;                          // 32K/32 = 1000Hz freq.
    TA0CCTL1 = OUTMOD_7;                      // CCR1 reset/set
    TA0CCR1 = 4;                             // 16/32 = 50% duty cycl
    TA0CTL = TASSEL__ACLK | MC__UP | TACLR;   // ACLK, up mode, clear TAR
void FRAMWrite(unsigned long data)
    *FRAM_write_ptr++ = data;
void ADC12Init()
    // By default, REFMSTR=1 => REFCTL 是配置内部参考电压的寄存器
    // while(REFCTL0 & REFGENBUSY);                              // 如果参考电压发生器busy, 等待
    // REFCTL0 |= REFVSEL_2 | REFON;                           // 选择内部参考源 ref = 2.5V,使能内部参考源
    // Configure ADC12
    ADC12CTL0 = ADC12SHT0_2 | ADC12ON | ADC12MSC;      // Sampling time, S&H=16, ADC12 on
    ADC12CTL1 = ADC12SHP + ADC12SHS_1 + ADC12SSEL_1 + ADC12CONSEQ_1;     // Use sampling timer, Use TA0CCR1 output as trigger , sequence channel
    ADC12CTL2 |= ADC12RES_2 + ADC12PWRMD;   // 12-bit conversion results, low power mode         ADC12CTL3 = ADC12CSTARTADD_0;// | ADC12CSTARTADD_1;
   // while(!(REFCTL0 & REFGENRDY));         // 等待参考源生效
    ADC12IER0 |= ADC12IE0;                  //开中断
    ADC12MCTL7 |= ADC12INCH_7 | ADC12VRSEL_1;        // A2 ADC input select; Vref=AVCC
    ADC12MCTL1 |= ADC12INCH_1 | ADC12VRSEL_1;
    ADC12MCTL0 |= ADC12INCH_2 | ADC12VRSEL_1;
    ADC12MCTL3 |= ADC12INCH_3 | ADC12VRSEL_1;
    ADC12MCTL4 |= ADC12INCH_4 | ADC12VRSEL_1;
    ADC12MCTL5 |= ADC12INCH_5 | ADC12VRSEL_1;
    ADC12MCTL6 |= ADC12INCH_6 | ADC12VRSEL_1;
    ADC12MCTL0 |= ADC12INCH_0 | ADC12VRSEL_1 + ADC12EOS;
    ADC12CTL0 |= ADC12ENC | ADC12SC;    //转换使能,开始转换
int main(void)
    WDTCTL = WDTPW | WDTHOLD;                 // Stop WDT
    GPIOInit();
    clockInit();
    TimerInit();
    ADC12Init();
    while (1)
        __bis_SR_register(LPM3_bits | GIE); // LPM3, ADC12_ISR will force exit
        __no_operation();                   // For debugger
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = ADC12_VECTOR
__interrupt void ADC12_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(ADC12_VECTOR))) ADC12_ISR (void)
#else
#error Compiler not supported!
#endif
    switch(__even_in_range(ADC12IV, ADC12IV_ADC12RDYIFG))
        case ADC12IV_NONE:        break;    // Vector  0:  No interrupt
        case ADC12IV_ADC12OVIFG:  break;    // Vector  2:  ADC12MEMx Overflow
        case ADC12IV_ADC12TOVIFG: break;    // Vector  4:  Conversion time overflow
        case ADC12IV_ADC12HIIFG:  break;    // Vector  6:  ADC12BHI
        case ADC12IV_ADC12LOIFG:  break;    // Vector  8:  ADC12BLO
        case ADC12IV_ADC12INIFG:  break;    // Vector 10:  ADC12BIN
        case ADC12IV_ADC12IFG0:             // Vector 12:  ADC12MEM0 Interrupt
            ADC_Data[0] = ADC12MEM0;
            ADC_Data[1] = ADC12MEM1;
            FRAM_write_ptr = (unsigned long *)FRAM_TEST_START0;
            FRAMWrite(ADC_Data[0]);                            // Endless loop
            ADC12MCTL0&=~ADC12INCH_2; //通道清2
            FRAM_write_ptr = (unsigned long *)FRAM_TEST_START1;
            FRAMWrite(ADC_Data[1]);                            // Endless loop
            ADC12MCTL1&=~ADC12INCH_3; //通道清3
                // Exit from LPM0 and continue executing main
                __bic_SR_register_on_exit(LPM3_bits);
            break;
        case ADC12IV_ADC12IFG1:   break;    // Vector 14:  ADC12MEM1
        case ADC12IV_ADC12IFG2:   break;    // Vector 16:  ADC12MEM2
        case ADC12IV_ADC12IFG3:   break;    // Vector 18:  ADC12MEM3
        case ADC12IV_ADC12IFG4:   break;    // Vector 20:  ADC12MEM4
        case ADC12IV_ADC12IFG5:   break;    // Vector 22:  ADC12MEM5
        case ADC12IV_ADC12IFG6:   break;    // Vector 24:  ADC12MEM6
        case ADC12IV_ADC12IFG7:   break;    // Vector 26:  ADC12MEM7
        case ADC12IV_ADC12IFG8:   break;    // Vector 28:  ADC12MEM8
        case ADC12IV_ADC12IFG9:   break;    // Vector 30:  ADC12MEM9
        case ADC12IV_ADC12IFG10:  break;    // Vector 32:  ADC12MEM10
        case ADC12IV_ADC12IFG11:  break;    // Vector 34:  ADC12MEM11
        case ADC12IV_ADC12IFG12:  break;    // Vector 36:  ADC12MEM12
        case ADC12IV_ADC12IFG13:  break;    // Vector 38:  ADC12MEM13
        case ADC12IV_ADC12IFG14:  break;    // Vector 40:  ADC12MEM14
        case ADC12IV_ADC12IFG15:  break;    // Vector 42:  ADC12MEM15
        case ADC12IV_ADC12IFG16:  break;    // Vector 44:  ADC12MEM16
        case ADC12IV_ADC12IFG17:  break;    // Vector 46:  ADC12MEM17
        case ADC12IV_ADC12IFG18:  break;    // Vector 48:  ADC12MEM18
        case ADC12IV_ADC12IFG19:  break;    // Vector 50:  ADC12MEM19
        case ADC12IV_ADC12IFG20:  break;    // Vector 52:  ADC12MEM20
        case ADC12IV_ADC12IFG21:  break;    // Vector 54:  ADC12MEM21
        case ADC12IV_ADC12IFG22:  break;    // Vector 56:  ADC12MEM22
        case ADC12IV_ADC12IFG23:  break;    // Vector 58:  ADC12MEM23
        case ADC12IV_ADC12IFG24:  break;    // Vector 60:  ADC12MEM24
        case ADC12IV_ADC12IFG25:  break;    // Vector 62:  ADC12MEM25
        case ADC12IV_ADC12IFG26:  break;    // Vector 64:  ADC12MEM26
        case ADC12IV_ADC12IFG27:  break;    // Vector 66:  ADC12MEM27
        case ADC12IV_ADC12IFG28:  break;    // Vector 68:  ADC12MEM28
        case ADC12IV_ADC12IFG29:  break;    // Vector 70:  ADC12MEM29
        case ADC12IV_ADC12IFG30:  break;    // Vector 72:  ADC12MEM30
        case ADC12IV_ADC12IFG31:  break;    // Vector 74:  ADC12MEM31
        case ADC12IV_ADC12RDYIFG: break;    // Vector 76:  ADC12RDY
        default: break;
Mattheww| | 2018-5-26 17:42 | 只看该作者
应该在中断里边采数据吧
Erichk| | 2018-5-26 18:14 | 只看该作者
定时器触发一直都在采集数据的,中断里面是将我采集的数据度给FRAM中
Thorald| | 2018-5-26 18:25 | 只看该作者
开通连续采集是吧
Bjorn| | 2018-5-26 18:54 | 只看该作者
这句有问题
应该开中断7,并且在中断ADC12IV_ADC12IFG7里进行数据提取
