| #define FIO1SET         (*(volatile unsigned long *)(FIO_BASE_ADDR + 0x38)) #define PORT0 0
 #define PORT1 1
 #define PORT2 2
 #define PORT3 3
 #define PORT4 4
 void FIO_Set(unsigned char port, unsigned int pin)
 switch (port)
 case 0:
 FIO0SET=pin;
 break;
 case 1:
 FIO1SET=pin;
 break;
 case 2:
 FIO2SET=pin;
 break;
 case 3:
 FIO3SET=pin;
 break;
 case 4:
 FIO4SET=pin;
 break;
 default:
 break;
 //val应当与relays的值相对应,例如置位K0,K4,则val的值为 0x00000011;
 void Relay_Out(unsigned int relays,unsigned int val)
 unsigned int i = 0;
 for(i = 0; i < 10; i++)
 switch( relays & (1<<i))
 case KM1_OUT:
 if( val & KM1_OUT)
 FIO_Set(PORT1, Y0_P1_21);
 else
 FIO_Clr(PORT1, Y0_P1_21);
 break;
 case GM1_OUT:
 void Door_Ctrl(unsigned int cur_input)
 unsigned int i = 0;
 //判断输入值的下降沿
 for(i=0;i<5;i++)
 if(door_param.door_pre_input & (1<<i))  //door_param.door_pre_input:      //门机信号输入
 if(!(cur_input & (1<<i)))      //cur_input:轿厢信号输入
 //door_param.door_in_edge_detect:检测下降沿
 door_param.door_in_edge_detect |= (1<<i);
 if(door_param.door_led_cfg)  //是否允许LED亮
 if(i==0)
 Relay_Out(KM1_OUT, KM1_OUT);
 else if(i == 1)
 Relay_Out(GM1_OUT, GM1_OUT);
 else if(i == 1)
 else if(i == 2)
 Relay_Out(KM2_OUT, KM2_OUT);
 else if(i == 3)
 Relay_Out(GM2_OUT, GM2_OUT);
 else
 Relay_Out(KMDELAY_OUT, KMDELAY_OUT);
 这段程序是什么意思  ?
