终于破译的仿真器问题,不容易啊
3106|1
 楼主| ccmicky 发表于 2011-7-31 18:33 | 显示全部楼层 |阅读模式
问题如下:
Error connecting to the target:
Error 0x80000200/-1047
Fatal Error during: OCS,
PTI_ERR_EMU_CLOSE Error Occured at 0x00000000
I/O Port = 240
Board Name: F2809 XDS510 Emulator
Cpu Name: CPU_1
Abort: Close Code Composer Studio.
Retry: Try to connect to the target again.
Cancel: Remain disconnected from the target
Diagnostic: Run diagnostic utility.
经过验证,得出结论我的板子是因为仿真器的驱动没有安装成功。
1.请注意驱动安装位置必须为CCS目录下,安了更新的,要放在更新后的CCS目录下
2.connection properties (setup CCS) 下选用extra config seedxds510plus.cfg (根据你的仿真器选)
bit6019 发表于 2011-8-11 20:15 | 显示全部楼层
不懂帮顶
