epwm频率问题
1708|5
光头的强|  楼主 | 2018-6-22 14:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PWM, se, TE, TI, IO
#define EPWM1_TIMER_TBPRD  2000  // Period register
#define EPWM1_MAX_CMPA     1950
#define EPWM1_MIN_CMPA       50
#define EPWM1_MAX_CMPB     1950
#define EPWM1_MIN_CMPB       50
这个1950和50是啥意思,下面的程序分频是为什么,频率是按2000那个算还是分频之后算啊?小白求教啊
   EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
   EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD;       // Set timer period
   EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;    // Disable phase loading
   EPwm1Regs.TBPHS.half.TBPHS = 0x0000;       // Phase is 0
   EPwm1Regs.TBCTR = 0x0000;                  // Clear counter
   EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV2;   // Clock ratio to SYSCLKOUT
   EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV2;
   // Setup shadow register load on ZERO
   EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
   EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
   // Set Compare values
   EPwm1Regs.CMPA.half.CMPA = EPWM1_MIN_CMPA;    // Set compare A value
   EPwm1Regs.CMPB = EPWM1_MIN_CMPB;              // Set Compare B value
   // Set actions
   EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET;            // Set PWM1A on Zero
   EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR;          // Clear PWM1A on event A, up count
   EPwm1Regs.AQCTLB.bit.ZRO = AQ_SET;            // Set PWM1B on Zero
   EPwm1Regs.AQCTLB.bit.CBU = AQ_CLEAR;          // Clear PWM1B on event B, up count
   // Interrupt where we will change the Compare Values
   EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO;     // Select INT on Zero event
   EPwm1Regs.ETSEL.bit.INTEN = 1;                // Enable INT
   EPwm1Regs.ETPS.bit.INTPRD = ET_3RD;           // Generate INT on 3rd event
   // Information this example uses to keep track
   // of the direction the CMPA/CMPB values are
   // moving, the min and max allowed values and
   // a pointer to the correct ePWM registers
   epwm1_info.EPwm_CMPA_Direction = EPWM_CMP_UP; // Start by increasing CMPA & CMPB
   epwm1_info.EPwm_CMPB_Direction = EPWM_CMP_UP;
   epwm1_info.EPwmTimerIntCount = 0;             // Zero the interrupt counter
   epwm1_info.EPwmRegHandle = &EPwm1Regs;        // Set the pointer to the ePWM module
   epwm1_info.EPwmMaxCMPA = EPWM1_MAX_CMPA;      // Setup min/max CMPA/CMPB values
   epwm1_info.EPwmMinCMPA = EPWM1_MIN_CMPA;
   epwm1_info.EPwmMaxCMPB = EPWM1_MAX_CMPB;
   epwm1_info.EPwmMinCMPB = EPWM1_MIN_CMPB;
光头的强|  楼主 | 2018-6-22 14:26 | 只看该作者
要输出100Khz应该怎么设置啊
zhangmangui| | 2018-6-22 22:57 | 只看该作者
你先只关心比较寄存器和周期寄存器吧
周期寄存器决定的是输出PWM的周期   比较寄存器决定的是占空比
光头的强|  楼主 | 2018-6-27 08:55 | 只看该作者
zhangmangui 发表于 2018-6-22 22:57
你先只关心比较寄存器和周期寄存器吧
周期寄存器决定的是输出PWM的周期   比较寄存器决定的是占空比 ...
谢谢
zhangmangui| | 2018-6-28 22:49 | 只看该作者
欢迎  多多交流    MCU论坛里面使用的人比较多
光头的强|  楼主 | 2018-7-3 09:24 | 只看该作者
哦哦
