Pin Name Dir Description<br />1 RED <br />Red Video (75 ohm, 0.7 V p-p)<br />2 GREEN <br />Green Video (75 ohm, 0.7 V p-p)<br />3 BLUE <br />Blue Video (75 ohm, 0.7 V p-p)<br />4 ID2 <br />Monitor ID Bit 2<br />5 GND <br />Ground<br />6 RGND <br />Red Ground<br />7 GGND <br />Green Ground<br />8 BGND <br />Blue Ground<br />9 KEY - Key (No pin)<br />10 SGND <br />Sync Ground<br />11 ID0 <br />Monitor ID Bit 0<br />12 ID1 or SDA <br />Monitor ID Bit 1<br />13 HSYNC or CSYNC <br />Horizontal Sync (or Composite Sync)<br />14 VSYNC <br />Vertical Sync<br />15 ID3 or SCL <br />Monitor ID Bit 3<br />到底是0-0.7v还是0.7-1v不知道哪个是对的
