关于中断问题
1100|8
 楼主| Erichk 发表于 2018-6-28 21:01 | 显示全部楼层 |阅读模式
求助,写了一个小程序,怎么才能跳出中断啊,求各位大佬解惑!
#include <msp430.h>
void GPIO_Init();
void P1_IODect();
void P2_IODect();
void TURN_Left();
void TURN_Right();
void TIMER_A0_1();
void TIMER_A1_1();
int main(void) {
    WDTCTL = WDTPW | WDTHOLD;
    GPIO_Init();
    TIMER_A0_1();
    TIMER_A1_1();
    _enable_interrupts();
void GPIO_Init(){
P1DIR |= BIT0+BIT1;
P1OUT |= BIT1;
P1OUT &= ~BIT0;
P1SEL |= BIT6;
P1DIR |= BIT6;
P2DIR |= BIT0+BIT1;
P2OUT |= BIT1;
P2OUT &= ~BIT0;
P2SEL |= BIT2;
P2DIR |= BIT2;
P1REN |= BIT3;
P1OUT |= BIT3;
P1DIR &=~ BIT3;
P1IES |= BIT3;
P1IE |= BIT3;
P2REN |= BIT3;
P2OUT |= BIT3;
P2DIR &=~ BIT3;
P2IES |= BIT3;
P2IE |= BIT3;
void TIMER_A0_1(){
TA0CTL=0;     //清除以前的设置
TA0CTL |= TASSEL_1+MC_1; //使用子系统时钟,帧计数模式,不倍频
TA0CTL|=ID_0;    //使用子系统时钟,帧计数模式,不倍频
    TA0CCTL1 = OUTMOD_7;
TA0CCR0 = 1000;             //时钟频率为32768HZ,100HZ
TA0CCR1 = 400;             //占空比CCR1/CCR0=1/3
TA0CTL |= TACLR;
void TIMER_A1_1(){
TA1CTL=0;     //清除以前的设置
TA1CTL |= TASSEL_1+MC_1; //使用子系统时钟,帧计数模式,不倍频
TA1CTL|=ID_0;    //使用子系统时钟,帧计数模式,不倍频
TA1CCTL1 = OUTMOD_7;
TA1CCR0 = 1000;             //时钟频率为32768HZ,100HZ
TA1CCR1 = 400;             //占空比CCR1/CCR0=1/3
TA1CTL |= TACLR;
#pragma vector = PORT1_VECTOR
__interrupt void PORT1_ISR(void)
P1_IODect();
    P1IFG=0;
void P1_IODect()
unsigned int Push_Key=0;
Push_Key=P1IFG&(~P1DIR);
if((P1IN&Push_Key)==0)
  switch(Push_Key){
  case BIT3:
   TURN_Right();
   P1IN ^= BIT3;
   break;
  default:       break;
#pragma vector = PORT2_VECTOR
__interrupt void PORT2_ISR(void)
P2_IODect();
    P2IFG=0;
void P2_IODect()
Push_Key=P2IFG&(~P2DIR);
if((P2IN&Push_Key)==0)
  switch(Push_Key){
  case BIT3:  TURN_Left();
                 P2IN ^=BIT3;
                 break;
  default:       break;
void TURN_Left(){
unsigned int MILL1=400;
unsigned int MILL2=400;
while((P2IN&0x04)==0){
  MILL1=MILL1+40;
  MILL2=MILL2-40;
  TA0CCR1=MILL1;
        TA1CCR1=MILL2;
void TURN_Right(){
    MILL1=MILL1-40;
    MILL2=MILL2+40;
    while((P1IN&0x04)==0){
        MILL1=MILL1-40;
        MILL2=MILL2+40;
        TA0CCR1=MILL1;
        TA1CCR1=MILL2;
Thorald 发表于 2018-6-28 21:27 | 显示全部楼层
进入低功耗模式试试
Bjorn 发表于 2018-6-28 21:35 | 显示全部楼层
中断里用了太多的while,那么只要条件符合,肯定就跳不出来了
Rollo 发表于 2018-6-28 21:49 | 显示全部楼层
当while的条件不符合的时候,也应该能跳出来才对。
Rangar 发表于 2018-6-28 21:57 | 显示全部楼层
中断所起的作用没有说明
Stannis 发表于 2018-6-28 22:09 | 显示全部楼层
P1_IODect();
    P1IFG=0;
P2_IODect();
    P2IFG=0;
没有对对应中断标志位清零,要找到这两个中断源的控制寄存器,然后找到对应位,对其置1·即可跳出中断了
Brand2 发表于 2018-6-28 22:20 | 显示全部楼层
定一个标志位
Soraka 发表于 2018-6-28 22:30 | 显示全部楼层
P1_IODect();
P1IFG=0这样不行么?
Garen2 发表于 2018-6-28 22:39 | 显示全部楼层
找到对应中断标志位,清除
