[i.MX] imx6Q mfgtool 烧写eMMC 停在UTP: Waiting for device to appear
5611|3
 楼主| new_come 发表于 2018-7-14 17:26 | 显示全部楼层 |阅读模式
自己做的板子,用MfgTool工具下载时候,Uboot下成功识别eMMC ,启动内核后出现UTP: Waiting for device to appear,然后没有反应了,怎么回事?麻烦大神帮忙分析下,是硬件问题还是软件哪里配置问题?
下面是启动信息:
U-Boot 2015.04imx_v2015.04_4.1.15_1.2.0_ga+gede7538 (Jul 11 2018 - 21:35:44)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
CPU:   Temperature 42 C
Reset cause: POR
Board: MX6-SabreSD
I2C:   ready
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1(part 0) is current device
Net:   Phy 0 not found
PHY reset timed out
FEC [PRIME]
Error: FEC address not set.
Boot from USB for mfgtools
Use default environment for                              mfgtools
Run bootcmd_mfg: run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
Hit any key to stop autoboot:  0
Kernel image @ 0x12000000 [ 0x000000 - 0x6b40a0 ]
## Loading init Ramdisk from Legacy Image at 12c00000 ...
   Image Name:   fsl-image-mfgtool-initramfs-imx6
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    7565864 Bytes = 7.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800da4b
No PMIC found!
Starting kernel ...
reg-fixed-voltage regulators:regulator@1: Failed to resolve vin-supply for usb_h1_vbus
imx_usb 2184200.usb: Can't register ci_hdrc platform device, err=-517
dhd_module_init in
input: gpio-keys as /devices/soc0/gpio-keys/input/input2
reg-fixed-voltage regulators:regulator@0: Failed to resolve vin-supply for usb_otg_vbus
rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 0-0051: retrieved date/time is not valid.
rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
wm8962-supply: disabling
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
usb_h1_vbus: disabling
usb_otg_vbus: disabling
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 436K (80baf000 - 80c1c000)
Starting UTP
uuc 0.5 [built Mar 12 2016 19:04:20]
bbstr 发表于 2018-7-15 07:20 来自手机 | 显示全部楼层
你的usb通讯有问题,用sd启动先试试和pc usb通讯的 或者拿你这套环境换个板子试试
 楼主| new_come 发表于 2018-7-15 17:23 | 显示全部楼层
你的usb通讯有问题,用sd启动先试试和pc usb通讯的 或者拿你这套环境换个板子试试 ...
现在板子只留了USB接口,没有预留SD接口,通过这个能确定OTG是什么问题吗?有什么解决方法吗?谢谢
kevinfmb 发表于 2018-11-23 21:40 | 显示全部楼层
请问楼主解决了没呢 我们也遇到同样问题~~
