电容式冰霜检测参考设计,分辨率小于 1mm,温漂小于 0.25%
741|3
 楼主| dirtwillfly 发表于 2018-7-24 22:34 | 显示全部楼层 |阅读模式
描述
Frost and ice buildup on cooling bodies and evaporators can significantly decrease system energy efficiency in many appliance applications such as refrigerators, air conditioners, and freezers. This sensor reference design helps to achieve the more stringent energy efficiency requirements of modern appliances through reducing the number of unnecessary defrost cycles by sensing the amount of ice buildup (resolution of < 1mm) on enclosures and metal surfaces of cooling bodies to trigger defrost cycles only when necessary, versus the traditional defrost trigger method of using a timer or temperature sensor.
特性
  • Resolution of < 1mm, temperature drift < 0.25%
  • Reduce energy by minimizing defrost cycle of melting ice or frost on evaporator coils to eliminate unnecessary defrost cycles
  • Fit for universal application in all types of refrigeration equipment with great sensitivity, high reliability, and low cost
  • Accurately sense thickness of ice or frost accumulated on surface of evaporating coils of refrigeration equipment
 楼主| dirtwillfly 发表于 2018-7-24 22:37 | 显示全部楼层
vibra2016 发表于 2018-7-25 22:44 | 显示全部楼层
这个资料的很不错的,先参考了
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1199
