[技术问答]
N76E003 P0端口如何配置才能够输出高低电平呢?
3329|10
i80757498|  楼主 | 2018-7-29 11:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问下使用新唐的各位前辈,就是我使用N76E003调试的时候将P0端口配置为开漏输出或者是推挽输出的状态下,为什么P0端口的输出始终保持不变呢。我使用P01端口如果输入电压是5V那么测的电压始终是3.3V,不论无输出的P01 = 0;还是P01 = 1;两个的结果都是这样的,我看了新唐的官方手册,并没有这方面的介绍。还有就是我输出端口P01已经具有上拉电阻了
xuanhuanzi| | 2018-7-29 11:34 | 只看该作者
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Jan/21/2017
//  File Function: N76E003 GPIO demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
////------------------- Define Port as Quasi mode  -------------------
//#define P00_Quasi_Mode                                P0M1&=~SET_BIT0;P0M2&=~SET_BIT0
//#define P01_Quasi_Mode                                P0M1&=~SET_BIT1;P0M2&=~SET_BIT1
//#define P02_Quasi_Mode                                P0M1&=~SET_BIT2;P0M2&=~SET_BIT2
//#define P03_Quasi_Mode                                P0M1&=~SET_BIT3;P0M2&=~SET_BIT3
//#define P04_Quasi_Mode                                P0M1&=~SET_BIT4;P0M2&=~SET_BIT4
//#define P05_Quasi_Mode                                P0M1&=~SET_BIT5;P0M2&=~SET_BIT5
//#define P06_Quasi_Mode                                P0M1&=~SET_BIT6;P0M2&=~SET_BIT6
//#define P07_Quasi_Mode                                P0M1&=~SET_BIT7;P0M2&=~SET_BIT7
//#define P10_Quasi_Mode                                P1M1&=~SET_BIT0;P1M2&=~SET_BIT0
//#define P11_Quasi_Mode                                P1M1&=~SET_BIT1;P1M2&=~SET_BIT1
//#define P12_Quasi_Mode                                P1M1&=~SET_BIT2;P1M2&=~SET_BIT2
//#define P13_Quasi_Mode                                P1M1&=~SET_BIT3;P1M2&=~SET_BIT3
//#define P14_Quasi_Mode                                P1M1&=~SET_BIT4;P1M2&=~SET_BIT4
//#define P15_Quasi_Mode                                P1M1&=~SET_BIT5;P1M2&=~SET_BIT5
//#define P16_Quasi_Mode                                P1M1&=~SET_BIT6;P1M2&=~SET_BIT6
//#define P17_Quasi_Mode                                P1M1&=~SET_BIT7;P1M2&=~SET_BIT7
//#define P20_Quasi_Mode                                P2M1&=~SET_BIT0;P2M2&=~SET_BIT0
//#define P30_Quasi_Mode                                P3M1&=~SET_BIT0;P3M2&=~SET_BIT0
////------------------- Define Port as Push Pull mode -------------------
//#define P00_PushPull_Mode                        P0M1|=SET_BIT0;P0M2&=~SET_BIT0
//#define P01_PushPull_Mode                        P0M1|=SET_BIT1;P0M2&=~SET_BIT1
//#define P02_PushPull_Mode                        P0M1&=~SET_BIT2;P0M2|=SET_BIT2
//#define P03_PushPull_Mode                        P0M1&=~SET_BIT3;P0M2|=SET_BIT3
//#define P04_PushPull_Mode                        P0M1&=~SET_BIT4;P0M2|=SET_BIT4
//#define P05_PushPull_Mode                        P0M1&=~SET_BIT5;P0M2|=SET_BIT5
//#define P06_PushPull_Mode                        P0M1&=~SET_BIT6;P0M2|=SET_BIT6
//#define P07_PushPull_Mode                        P0M1&=~SET_BIT7;P0M2|=SET_BIT7
//#define P10_PushPull_Mode                        P1M1&=~SET_BIT0;P1M2|=SET_BIT0
//#define P11_PushPull_Mode                        P1M1&=~SET_BIT1;P1M2|=SET_BIT1
//#define P12_PushPull_Mode                        P1M1&=~SET_BIT2;P1M2|=SET_BIT2
//#define P13_PushPull_Mode                        P1M1&=~SET_BIT3;P1M2|=SET_BIT3
//#define P14_PushPull_Mode                        P1M1&=~SET_BIT4;P1M2|=SET_BIT4
//#define P15_PushPull_Mode                        P1M1&=~SET_BIT5;P1M2|=SET_BIT5
//#define P16_PushPull_Mode                        P1M1&=~SET_BIT6;P1M2|=SET_BIT6
//#define P17_PushPull_Mode                        P1M1&=~SET_BIT7;P1M2|=SET_BIT7
//#define P20_PushPull_Mode                        P2M1&=~SET_BIT0;P2M2|=SET_BIT0
//#define P30_PushPull_Mode                        P3M1&=~SET_BIT0;P3M2|=SET_BIT0
////------------------- Define Port as Input Only mode -------------------
//#define P00_Input_Mode                                P0M1|=SET_BIT0;P0M2&=~SET_BIT0
//#define P01_Input_Mode                                P0M1|=SET_BIT1;P0M2&=~SET_BIT1
//#define P02_Input_Mode                                P0M1|=SET_BIT2;P0M2&=~SET_BIT2
//#define P03_Input_Mode                                P0M1|=SET_BIT3;P0M2&=~SET_BIT3
//#define P04_Input_Mode                                P0M1|=SET_BIT4;P0M2&=~SET_BIT4
//#define P05_Input_Mode                                P0M1|=SET_BIT5;P0M2&=~SET_BIT5
//#define P06_Input_Mode                                P0M1|=SET_BIT6;P0M2&=~SET_BIT6
//#define P07_Input_Mode                                P0M1|=SET_BIT7;P0M2&=~SET_BIT7
//#define P10_Input_Mode                                P1M1|=SET_BIT0;P1M2&=~SET_BIT0
//#define P11_Input_Mode                                P1M1|=SET_BIT1;P1M2&=~SET_BIT1
//#define P12_Input_Mode                                P1M1|=SET_BIT2;P1M2&=~SET_BIT2
//#define P13_Input_Mode                                P1M1|=SET_BIT3;P1M2&=~SET_BIT3
//#define P14_Input_Mode                                P1M1|=SET_BIT4;P1M2&=~SET_BIT4
//#define P15_Input_Mode                                P1M1|=SET_BIT5;P1M2&=~SET_BIT5
//#define P16_Input_Mode                                P1M1|=SET_BIT6;P1M2&=~SET_BIT6
//#define P17_Input_Mode                                P1M1|=SET_BIT7;P1M2&=~SET_BIT7
//#define P20_Input_Mode                                P2M1|=SET_BIT0;P2M2&=~SET_BIT0
//#define P30_Input_Mode                                P3M1|=SET_BIT0;P3M2&=~SET_BIT0
////-------------------Define Port as Open Drain mode -------------------
//#define P00_OpenDrain_Mode                P0M1|=SET_BIT0;P0M2|=SET_BIT0
//#define P01_OpenDrain_Mode                P0M1|=SET_BIT1;P0M2|=SET_BIT1
//#define P02_OpenDrain_Mode                P0M1|=SET_BIT2;P0M2|=SET_BIT2
//#define P03_OpenDrain_Mode                P0M1|=SET_BIT3;P0M2|=SET_BIT3
//#define P04_OpenDrain_Mode                P0M1|=SET_BIT4;P0M2|=SET_BIT4
//#define P05_OpenDrain_Mode                P0M1|=SET_BIT5;P0M2|=SET_BIT5
//#define P06_OpenDrain_Mode                P0M1|=SET_BIT6;P0M2|=SET_BIT6
//#define P07_OpenDrain_Mode                P0M1|=SET_BIT7;P0M2|=SET_BIT7
//#define P10_OpenDrain_Mode                P1M1|=SET_BIT0;P1M2|=SET_BIT0
//#define P11_OpenDrain_Mode                P1M1|=SET_BIT1;P1M2|=SET_BIT1
//#define P12_OpenDrain_Mode                P1M1|=SET_BIT2;P1M2|=SET_BIT2
//#define P13_OpenDrain_Mode                P1M1|=SET_BIT3;P1M2|=SET_BIT3
//#define P14_OpenDrain_Mode                P1M1|=SET_BIT4;P1M2|=SET_BIT4
//#define P15_OpenDrain_Mode                P1M1|=SET_BIT5;P1M2|=SET_BIT5
//#define P16_OpenDrain_Mode                P1M1|=SET_BIT6;P1M2|=SET_BIT6
//#define P17_OpenDrain_Mode                P1M1|=SET_BIT7;P1M2|=SET_BIT7
//#define P20_OpenDrain_Mode                P2M1|=SET_BIT0;P2M2|=SET_BIT0
//#define P30_OpenDrain_Mode                P3M1|=SET_BIT0;P3M2|=SET_BIT0
////--------- Define all port as quasi mode ---------
//#define Set_All_GPIO_Quasi_Mode                        P0M1=0;P0M1=0;P1M1=0;P1M2=0;P2M1=0;P2M2=0;P3M1=0;P3M2=0
#endif
The main C function.  Program execution starts
here after stack initialization.
void main (void)
//        unsigned char temp;
        Set_All_GPIO_Quasi_Mode;                                        // Define in Function_define.h
#if 0
        InitialUART0_Timer3(115200);
//        set_CLOEN;        // For clock out from P1.1
  while(1)
                clr_GPIO1;        // Tiny board GPIO1 LED define
                P0 = 0x00;
                P2 = 0x00;
                P1 = 0x00;
                Timer0_Delay1ms(30);
                P0 = 0xff;
                P2 = 0xff;
                P1 = 0xff;
                set_GPIO1;
                Send_Data_To_UART0(0x35);                                        //UART0 send ascii "U"
                temp = 0x31 + P0;
                Send_Data_To_UART0(temp);
                temp = 0x31 + P1;
#endif
#if 1
  while(1)
                P0 = 0x00;
                P2 = 0x00;
                P1 = 0x00;
                P0 = 0xff;
                P2 = 0xff;
                P1 = 0xff;
                set_GPIO1;
#endif
xuanhuanzi| | 2018-7-29 11:35 | 只看该作者
试试这个例子。我试的是好的。
i80757498|  楼主 | 2018-7-29 12:11 | 只看该作者
xuanhuanzi 发表于 2018-7-29 11:35
试试这个例子。我试的是好的。
好的,谢谢,我先试试
i80757498|  楼主 | 2018-7-29 12:20 | 只看该作者
试试这个例子。我试的是好的。
你好,测试了例子是可以使用的。请问下P0端口在配置的时候除了输入的情况下,配置需要配置为准双向呢?如果控制继电器这种需要进行推挽输出控制的,是否需要外加电路呢?非常感谢
xuanhuanzi| | 2018-7-29 12:31 | 只看该作者
i80757498 发表于 2018-7-29 12:20
你好,测试了例子是可以使用的。请问下P0端口在配置的时候除了输入的情况下,配置需要配置为准双向呢?如 ...
可以加三极管驱动
i80757498|  楼主 | 2018-7-29 12:32 | 只看该作者
xuanhuanzi 发表于 2018-7-29 12:31
可以加三极管驱动
好的,谢谢
xuanhuanzi| | 2018-7-29 12:33 | 只看该作者
另外也要看你继电器大小了,小的那种可以IO直接驱动,你可以测试一下,如果不行动力不够的加三极管。如果控制大电压严重的出于保护目的还要用光藕隔离开呢。
huahuagg| | 2018-7-29 14:51 | 只看该作者
开漏肯定是不行的。
xixi2017| | 2018-7-29 15:53 | 只看该作者
先搞清楚几种模式,然后结合BSP里面定义好的宏。
xinxianshi| | 2018-7-29 19:02 | 只看该作者
这个芯片是5V的还是3.3V的?
