[产品供应]
AMC1200BDUBR 隔离放大器 【雪域科技 TI专营】
495|0
AMC1200BDUBR 隔离放大器 【雪域科技 TI专营】大量到货,支持实单! Tel:275582565878 QQ:2322654561
AMC1200BDUBR
用于并联测量的 4kV 峰值隔离放大器
特性
  • ±250-mV Input Voltage Range Optimized for Shunt Resistors
  • Very Low Nonlinearity: 0.075% max at 5 V
  • Low Offset Error: 1.5 mV max
  • Low Noise: 3.1 mV[size=0.7em]RMS typ
  • Low High-Side Supply Current: 8 mA max at
    5 V
  • Input Bandwidth: 60 kHz min
  • Fixed Gain: 8 (0.5% accuracy)
  • High Common-Mode Rejection Ratio: 108 dB
  • 3.3-V Operation on Low-Side
  • Certified Galvanic Isolation:
    • UL1577 and IEC60747-5-2 Approved
    • Isolation Voltage: 4000 V[size=0.7em]PEAK
    • Working Voltage: 1200 V[size=0.7em]PEAK
    • Transient Immunity: 10 kV/µs min
  • Typical 10-Year Lifespan at Rated Working Voltage (see Application Report SLLA197)
  • Fully Specified Over the Extended Industrial Temperature Range
