[STM32F4] UART没有接收到数据
1522|18
 楼主| laozhongyi 发表于 2018-8-11 19:32 | 显示全部楼层 |阅读模式
UART, se, pi, IO, TE
接收UART的数据,但是一直没有接收到,可是sscom又显示已经发送了数据。不知道是没有进中断还是什么问题。能否帮忙看看是不是代码哪里错了。
下面是代码
void UARTinit()
/* GPIO_setAsPeripheralModuleFunctionInputPin(
        GPIO_PORT_P9,
       GPIO_PIN5
  GPIO_setAsPeripheralModuleFunctionOutputPin(
          GPIO_PORT_P9,
       GPIO_PIN4
        GPIO_PORT_P5,
        GPIO_PIN7
    //Initialize USCI UART module
    //Baudrate = 9600, clock freq =8M  // 1.048MHz
    //UCBRx = 6, UCBRFx = 13, UCBRSx = 0, UCOS16 = 1
    USCI_A_UART_initParam param = {0};
    param.selectClockSource = USCI_A_UART_CLOCKSOURCE_ACLK;
    param.clockPrescalar =3 /*52*/;
    param.firstModReg = 0/*1*/;
    param.secondModReg = 3/*0*/;
    param.parity = USCI_A_UART_NO_PARITY;
    param.msborLsbFirst = USCI_A_UART_LSB_FIRST;
    param.numberofStopBits = USCI_A_UART_ONE_STOP_BIT;
    param.uartMode = USCI_A_UART_IDLE_LINE_MULTI_PROCESSOR_MODE;
    param.overSampling = USCI_A_UART_LOW_FREQUENCY_BAUDRATE_GENERATION/*USCI_A_UART_OVERSAMPLING_BAUDRATE_GENERATION*/;
    if(STATUS_FAIL == USCI_A_UART_init(USCI_A1_BASE, &param))
        return;
    //Enable UART module for operation
    USCI_A_UART_enable(USCI_A1_BASE);
    //Set USCI UART in dormant/sleep mode
    //USCI_A_UART_setDormant(USCI_A1_BASE);
    //Enable Receive Interrupt
    USCI_A_UART_clearInterrupt(USCI_A1_BASE,
                               USCI_A_UART_RECEIVE_INTERRUPT
    USCI_A_UART_enableInterrupt(USCI_A1_BASE,
//This is the USCI_A1 interrupt vector service routine.
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCI_A1_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(USCI_A1_VECTOR)))
#endif
void USCI_A1_ISR(void)
    switch(__even_in_range(UCA1IV,4))
    //Vector 2 - RXIFG
    case 2:
        //USCI_A1 TX buffer ready?
      while(!USCI_A_UART_getInterruptStatus(USCI_A1_BASE,
                                             USCI_A_UART_TRANSMIT_INTERRUPT_FLAG)
       // USCI_A_UART_resetDormant(USCI_A1_BASE);
        //Receive the data
        receivedData = USCI_A_UART_receiveData(USCI_A1_BASE);
       /* if(receivedData!=0x00) bspLedSet(BSP_LED_1);
        else bspLedSet(BSP_LED_2);*/
      // Send data back "echo"
      USCI_A_UART_transmitData(USCI_A1_BASE,
                                 receivedData
       // USCI_A_UART_setDormant(USCI_A1_BASE);
        break;
    default: break;
Edisons 发表于 2018-8-11 19:35 | 显示全部楼层
为什么非要一定搞得跟32库函数一样那么复杂呢?
_gege 发表于 2018-8-11 19:38 | 显示全部楼层
官网有提供例程的,建议先运行下例程
Mozarts 发表于 2018-8-11 19:40 | 显示全部楼层
用寄存器来操作会比较繁琐,官网提供了库,可以更快上手和方便使用
Listate 发表于 2018-8-11 19:45 | 显示全部楼层
楼主检查一下,说不定是接线的问题!
zhouhuanの 发表于 2018-8-11 19:46 | 显示全部楼层
找个串口监视软件看看。。。
bbapple 发表于 2018-8-11 19:52 | 显示全部楼层
注意一下,初始化时串口的定义顺序
sourceInsight 发表于 2018-8-11 19:53 | 显示全部楼层
估计是你的线接错了也有可能
boy1990 发表于 2018-8-11 19:55 | 显示全部楼层
uart接PC机串口调试工具来看
CallReceiver 发表于 2018-8-11 19:57 | 显示全部楼层
使用的是什么接口呢?是不是没有共地?
hfdy01 发表于 2018-8-11 19:59 | 显示全部楼层
可以先把串口关了,一段时间后再打开
xia00 发表于 2018-8-11 20:02 | 显示全部楼层
用示波器抓一下信号线上的波形。
shashaa 发表于 2018-8-11 20:02 | 显示全部楼层
是不是RX和TX接反了。
qiangweii 发表于 2018-8-11 20:04 | 显示全部楼层
字符格式发送,然后看看是不是半角或者圆角字符
feiqi1 发表于 2018-8-11 20:05 | 显示全部楼层
串口软件可能有不一样呢?、
androidbus 发表于 2018-8-11 20:09 | 显示全部楼层
这个单步调试看看是不是寄存器数值。
litengg 发表于 2018-8-11 20:10 | 显示全部楼层
或者地线和数据线相互换换
xiaoqizi 发表于 2018-8-13 13:14 | 显示全部楼层
电脑串口自身有没有问题
木木guainv 发表于 2018-8-13 13:17 | 显示全部楼层
接地了没有啊
