[DSP编程] 28335CAN中断接收程序,接收邮箱标志位CANRMP被置位,可是邮箱里就是没有消息
11508|2
 楼主| 造诣zy 发表于 2018-8-19 16:19 | 显示全部楼层 |阅读模式
附上程序,邮箱的MDL和MDH死活为零。可是CANRMP有被置为1
#include "DSP2833x_Device.h"
#include "DSP2833x_Examples.h"
struct ECAN_REGS ECanbShadow;
interrupt void ECanbR_ISR(void);
void InitECanR(void);
Uint16 MSGL0 = 0;
Uint16 MSGL1 = 0;
Uint16 MSGL2 = 0;
Uint16 MSGL3 = 0;
Uint16 MSGH0 = 0;
Uint16 MSGH1 = 0;
Uint16 MSGH2 = 0;
Uint16 MSGH3 = 0;
int Counts = 0;
void main()
        InitSysCtrl();    //系统初始化
        InitXintf16Gpio();  //初始化16路Gpio
        InitECanGpio();
        InitECanbGpio();    //初始化ECanb
        InitECanaGpio();
        InitECana();
        InitECanb();
        DINT;
        InitPieCtrl();
        IER = 0x0000;
        IFR = 0x0000;
        InitPieVectTable();
        EALLOW;
        PieVectTable.ECAN1INTB = &ECanbR_ISR;
        EDIS;
        InitECanR();
        IER =M_INT9;
        //PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
        PieCtrlRegs.PIEIER9.bit.INTx8 = 1;   //使能第9组中断第8个小中断,即ECAN1INTB
        //PieCtrlRegs.PIEACK.bit.ACK9 = 1;     //PIEACK置1
        EINT;
        ERTM;
        for(;;)
        if(ECanbRegs.CANGIF1.bit.GMIF1 == 1)
                if(ECanbRegs.CANRMP.all == 0x00010000)
                ECanbRegs.CANRMP.all = 0x00010000;
                MSGL0 = ECanbMboxes.MBOX16.MDL.byte.BYTE0;
                MSGL1 = ECanbMboxes.MBOX16.MDL.byte.BYTE1;
                MSGL2 = ECanbMboxes.MBOX16.MDL.byte.BYTE2;
                MSGL3 = ECanbMboxes.MBOX16.MDL.byte.BYTE3;
                MSGH0 = ECanbMboxes.MBOX16.MDH.byte.BYTE4;
                MSGH1 = ECanbMboxes.MBOX16.MDH.byte.BYTE5;
                MSGH2 = ECanbMboxes.MBOX16.MDH.byte.BYTE6;
                MSGH3 = ECanbMboxes.MBOX16.MDH.byte.BYTE7;
        //ECanbRegs.CANOPC.all = 0x00000000;
        EALLOW;
        ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
        ECanbShadow.CANTIOC.bit.TXFUNC = 1;
        ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
        ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
        ECanbShadow.CANRIOC.bit.RXFUNC = 1;
        ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
        ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
        ECanbShadow.CANMC.bit.CCR = 1;
        ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
        EDIS;
        ECanbShadow.CANES.all = ECanbRegs.CANES.all;
        do
        }while(ECanbShadow.CANES.bit.CCE != 1);
        ECanbRegs.CANBTC.all = 0;
        EALLOW;
        ECanbShadow.CANBTC.all = ECanbRegs.CANBTC.all;
        ECanbShadow.CANBTC.bit.BRPREG = 9;
        ECanbShadow.CANBTC.bit.TSEG2REG = 2;
        ECanbShadow.CANBTC.bit.TSEG1REG = 10;
        ECanbShadow.CANBTC.bit.SAM = 1;       //采样三次取多次
        ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;
        ECanbShadow.CANMC.bit.CCR = 0;
        ECanbShadow.CANMC.bit.PDR = 0;
        ECanbShadow.CANMC.bit.DBO = 0;
        ECanbShadow.CANMC.bit.WUBA = 0;
        ECanbShadow.CANMC.bit.CDR = 0;
        ECanbShadow.CANMC.bit.ABO = 0;
        ECanbShadow.CANMC.bit.STM = 0;
        ECanbShadow.CANMC.bit.SRES = 0;
        ECanbShadow.CANMC.bit.MBNR = 0;
        EDIS;
        ECanbMboxes.MBOX0.MSGCTRL.all = 0;
        ECanbMboxes.MBOX1.MSGCTRL.all = 0;
        ECanbMboxes.MBOX2.MSGCTRL.all = 0;
        ECanbMboxes.MBOX3.MSGCTRL.all = 0;
        ECanbMboxes.MBOX4.MSGCTRL.all = 0;
        ECanbMboxes.MBOX5.MSGCTRL.all = 0;
        ECanbMboxes.MBOX6.MSGCTRL.all = 0;
        ECanbMboxes.MBOX7.MSGCTRL.all = 0;
        ECanbMboxes.MBOX8.MSGCTRL.all = 0;
        ECanbMboxes.MBOX9.MSGCTRL.all = 0;
        ECanbMboxes.MBOX10.MSGCTRL.all = 0;
        ECanbMboxes.MBOX11.MSGCTRL.all = 0;
        ECanbMboxes.MBOX12.MSGCTRL.all = 0;
        ECanbMboxes.MBOX13.MSGCTRL.all = 0;
        ECanbMboxes.MBOX14.MSGCTRL.all = 0;
        ECanbMboxes.MBOX15.MSGCTRL.all = 0;
        ECanbMboxes.MBOX16.MSGCTRL.all = 0;
        ECanbMboxes.MBOX17.MSGCTRL.all = 0;
        ECanbMboxes.MBOX18.MSGCTRL.all = 0;
        ECanbMboxes.MBOX19.MSGCTRL.all = 0;
        ECanbMboxes.MBOX20.MSGCTRL.all = 0;
        ECanbMboxes.MBOX21.MSGCTRL.all = 0;
        ECanbMboxes.MBOX22.MSGCTRL.all = 0;
        ECanbMboxes.MBOX23.MSGCTRL.all = 0;
        ECanbMboxes.MBOX24.MSGCTRL.all = 0;
        ECanbMboxes.MBOX25.MSGCTRL.all = 0;
        ECanbMboxes.MBOX26.MSGCTRL.all = 0;
        ECanbMboxes.MBOX27.MSGCTRL.all = 0;
        ECanbMboxes.MBOX28.MSGCTRL.all = 0;
        ECanbMboxes.MBOX29.MSGCTRL.all = 0;
        ECanbMboxes.MBOX30.MSGCTRL.all = 0;
        ECanbMboxes.MBOX31.MSGCTRL.all = 0;
        do
        }while(ECanbShadow.CANES.bit.CCE != 0);
        ECanbRegs.CANGIM.all = 0x00000000;
        ECanbRegs.CANMIM.all = 0x00000000;
        ECanbRegs.CANMIL.all = 0xFFFFFFFF;
        ECanbRegs.CANME.all = 0x00000000;
        ECanbMboxes.MBOX16.MSGID.bit.IDE = 0;
        ECanbMboxes.MBOX16.MSGID.bit.STDMSGID = 0x0314;
        ECanbMboxes.MBOX16.MSGID.bit.AAM = 0;
        ECanbMboxes.MBOX16.MSGID.bit.AME = 0;
        ECanbRegs.CANMD.all = 0xFFFF0000;
        //ECanbShadow.CANGAM.all = ECanbRegs.CANGAM.all;
    //ECanbShadow.CANGAM.bit.AMI = 1;              //标准帧和扩展帧都接受
    //ECanbShadow.CANGAM.bit.GAM2816 |= 0x1fff;      //LAM(0)用于邮箱0~2 ,LAM(3)用于邮箱3~5,对于邮箱6~15,用全局接收屏蔽
    //ECanbRegs.CANGAM.all = ECanbShadow.CANGAM.all;
        /*ECanbShadow.CANOPC.all = ECanbRegs.CANOPC.all;
        ECanbShadow.CANOPC.bit.OPC16 = 0;                                   //设置为没有写覆盖保护
        ECanbRegs.CANOPC.all = ECanbShadow.CANOPC.all;
        ECanbMboxes.MBOX16.MSGCTRL.bit.DLC = 8;
        ECanbMboxes.MBOX16.MSGCTRL.bit.RTR = 0;
        EALLOW;
    ECanbShadow.CANMC.bit.STM = 0;    // Configure CAN for self-test mode
    ECanbShadow.CANMC.bit.SCB = 1;    // eCAN mode (reqd to access 32 mailboxes)
    EDIS;
        ECanbShadow.CANME.all = ECanbRegs.CANME.all;
        ECanbShadow.CANME.bit.ME16 = 1;
        ECanbRegs.CANME.all = ECanbShadow.CANME.all;
        ECanbRegs.CANMIL.all = 0xFFFF0000;
        ECanbRegs.CANMIM.all = 0xFFFFFFFF;
        EALLOW;
        ECanbShadow.CANGIM.all = ECanbRegs.CANGIM.all;
        ECanbShadow.CANGIM.bit.AAIM = 1;
        ECanbShadow.CANGIM.bit.WDIM = 1;
        ECanbShadow.CANGIM.bit.WUIM = 1;
        ECanbShadow.CANGIM.bit.BOIM = 1;
        ECanbShadow.CANGIM.bit.EPIM = 1;
        ECanbShadow.CANGIM.bit.WLIM = 1;
        ECanbShadow.CANGIM.bit.I0EN = 1;
        ECanbShadow.CANGIM.bit.I1EN = 1;
        ECanbShadow.CANGIM.bit.GIL =1;
        ECanbRegs.CANGIM.all = ECanbShadow.CANGIM.all;
        ECanbRegs.CANRMP.all = 0xFFFFFFFF;
        ECanbRegs.CANTA.all = 0xFFFFFFFF;
        ECanbRegs.CANGIF0.all = 0xFFFFFFFF;
        ECanbRegs.CANGIF1.all = 0xFFFFFFFF;
 楼主| 造诣zy 发表于 2018-8-19 16:20 | 显示全部楼层
希望大神指点,已经研究了三天了,实在找不出哪里出了问题,感谢!!!!
z_jzhao 发表于 2021-5-9 16:40 | 显示全部楼层
我一直进不了中断
