[STM32F1] 使用STM32 485中断接收时不能进入中断
3796|9
 楼主| GEA 发表于 2018-8-28 10:54 | 显示全部楼层 |阅读模式
//初始化配置
void RS485_Init(void)
              USART_InitTypeDef USART_InitStructure;
              NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//ʹÄÜGPIOA/USARTʱÖÓ
                    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//¹¦Äܸ´ÓÃIOʱÖÓʹÄÜ
        USART_Cmd(USART1, ENABLE);//ʹÄÜUSART
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;           //RX½ÓÊÕÒý½Å
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //¸¡¿ÕÊäÈë
        GPIO_Init(GPIOA,&GPIO_InitStructure);        //ÅäÖÃ IO
                    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;           //TX·¢ËÍÒý½Å
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //¸´ÓÃÍÆÍìÊä³ö
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;        //Êä³öËÙ¶È
                    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;             //485¿ØÖÆÒý½Å
              GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   //ÍÆÍìÊä³ö
              GPIO_Init(GPIOA, &GPIO_InitStructure);
                                GPIO_ResetBits(GPIOA, GPIO_Pin_8);//ĬÈϽÓÊÕģʽ
        USART_ClearFlag(USART1,USART_FLAG_TC);//Çå³ý´®¿Ú´¦Àí±ê־λ
                                USART_ClearITPendingBit(USART1, USART_IT_RXNE);//Çå³ý´®¿ÚÖжϱê־λ
        USART_StructInit(&USART_InitStructure);
                    USART_Init(USART1,&USART_InitStructure);
               USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);        //ÖжÏʹÄÜ
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
//中断接收
void USART1_IRQHandler(void)
        u8 RX_dat;
  if(USART_GetITStatus(USART1,USART_IT_RXNE)==SET)//USART_IT_RXNE:????
    RX_dat=USART_ReceiveData(USART1);
    GPIO_SetBits(GPIOA,GPIO_Pin_8);
    delay_ms(1);
    USART_SendData(USART1,RX_dat);
    while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET){} //???????????
    delay_ms(2);
    GPIO_ResetBits(GPIOA,GPIO_Pin_8);
如题 我之前用串口助手测试232通信 这个测试程序通过了  但换成485通信时(相同串口,只是多了一个控制引脚),程序就实现不了了,感觉是没进入中断,求大神帮忙
jekey 发表于 2018-8-28 11:00 | 显示全部楼层
多看看例程吧,不要在中断里面等待和延时。
在接收数据超时或按协议接收完成后,再发送数据。
磨砂 发表于 2018-8-28 11:16 | 显示全部楼层
亲 程序流程有问题
晓伍 发表于 2018-8-28 11:22 | 显示全部楼层
哪有在中断里使用while的啊
 楼主| GEA 发表于 2018-8-28 13:34 | 显示全部楼层
在接收数据超时或按协议接收完成后,再发送数据。 ...
这是我在网上找的 因为我之前的那个不行
我原来的中断是void USART1_IRQHandler(void)
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        USART1_Buffer[uart_p]=USART_ReceiveData(USART1);
        uart_p++;
接收完后再发送的数据
 楼主| GEA 发表于 2018-8-28 13:35 | 显示全部楼层
哪有在中断里使用while的啊
这是我在网上找的 因为我之前的那个不行
        uart_p++;
接收完后再发送的数据
Ketose 发表于 2018-8-28 20:41 | 显示全部楼层
你是直接把232当485来使用,不用加485的芯片吗?
zhjgmn 发表于 2018-10-20 12:00 | 显示全部楼层
是不是有多个中断,看中断组的配置是否合理.之前遇到的问题好像是中断配置的有问题,还有就是串口中断函数里放了串口打印函数
caijie001 发表于 2018-10-20 12:18 | 显示全部楼层
中断不要延时啊,,,,,
煌ggg 发表于 2022-6-23 15:53 | 显示全部楼层
您好求问,遇到了一样的问题,加了一个引脚,用485,无法进入中断了
GEA
