NEC红外接收程序
2910|0
hisuny|  楼主 | 2011-8-13 17:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NEC红外接收程序,实际应用效果良好,请大家帮忙看看还有无其它问题。
#include <STC_NEW_8051.H>
#include "PWM.H"
sbit IR_PIN = P3^3;
sbit WHITE_PIN = P1^0;
bit bUpdateFlag = 0, bLeaderFlag = 0;
long gReceiveByte;
void SystemInit()
        IT1 = 1;
        EX1 = 1;
        EA = 1;
        AUXR &= 0x7f;
        ET0        = 1;
        TMOD = 0x01;
        TH0 = 0x00;
        TL0 = 0x00;
void timer0() interrupt 1 using 1
        TR0 = 0;
void exinit() interrupt 2 using 0
        WORD RT1, RT2;
        static BYTE BitCount;
        if(bLeaderFlag)
                RT1 = TH0 << 8;
                RT2        = RT1 + TL0;
                TH0 = 0;
                TL0 = 0;
                if((3600 < RT2) && (RT2 < 5400))
                        BitCount = 0;
                        gReceiveByte = 0;
                else if((300 < RT2) && (RT2 < 450))
                        BitCount++;
                        gReceiveByte = (gReceiveByte << 1);
                else if((600 < RT2) && (RT2 < 900))
                        BitCount++;
                        gReceiveByte = (gReceiveByte << 1) + 1;
                else
                        TR0 = 0;
                        bLeaderFlag = 0;
                if(BitCount == 32)
                        TR0 = 0;
                        bLeaderFlag = 0;
                        bUpdateFlag = 1;
        else
                TH0 = 0;
                TL0 = 0;
                TR0 = 1;
                bLeaderFlag = 1;
void main()
        const BYTE DimData[11] = {0, 25, 50, 75, 100, 125, 150, 175, 200, 225, 255};
        BYTE DataCode, NotDataCode, i, j;
        SystemInit();
        InitPWM();
        for(;;)
                if(bUpdateFlag)
                        bUpdateFlag = 0;
                        DataCode = gReceiveByte >> 8;
                        NotDataCode = gReceiveByte;
                        if(~DataCode == NotDataCode)
                                switch(DataCode)
                                        case 0x78: ChangeDutyCycle(0xff); WHITE_PIN = ~WHITE_PIN; break;
                                        case 0x50: ChangeDutyCycle(0xff); break;
                                        case 0x20: if(i < 10) ChangeDutyCycle(DimData[++i]); break;
                                         case 0x40: if(i > 0) ChangeDutyCycle(DimData[--i]); break;
                                        case 0x60: if(j < 255) ChangeDutyCycle(++j); break;
                                        case 0x10: if(j > 0) ChangeDutyCycle(--j); break;
                                        default: break;
#include "STC_NEW_8051.H"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define CPS0 0
#define CPS1 2
#define CPS2 4
#define CPS3 6
#define CPS4 8
#define CPS5 10
#define CPS6 12
#define CPS7 14
void InitPWM()
        CCON = 0x00;
        CMOD |= CPS0;
        CCAPM0 = 0x42;
        PCA_PWM0 = 0x00;
        CCAP0L = 0x00;
        CCAP0H = 0x00;
        CL = 0x00;
        CH = 0x00;
        CR = 1;
void ChangeDutyCycle(BYTE duty)
        if(duty == 0xff)
                PCA_PWM0 = 0x03;
        else
                PCA_PWM0 = 0x00;
        CCAP0L = CCAP0H = duty;
