Win7下ByteBlaster II下载线驱动安装方法
8612|2
 楼主| impw 发表于 2011-8-15 12:38 | 显示全部楼层 |阅读模式
这是参考Altera官方的一个声明,链接http://www.altera.com/download/drivers/dri-bb-vista32.html,在Win7下测试正常。
Driver Installation
  • From the Start menu, choose Run.
  • In the Open field, type cmd and then click OK. The command prompt window appears.
  • To install the Altera ByteBlaster driver with the BBLPT utility, type the following command at the command prompt:
    <Quartus II Installation Path>\bin\bblpt /i
  • When the ByteBlaster Device Driver Installation window appears, click OK.
  • You may now connect the Altera ByteBlaster download cable to the PC. Complete the installation by setting up programming hardware:
  • To remove the Altera ByteBlaster driver with the BBLPT utility, type the following command at the command prompt:
    <Quartus II Installation Path>\bin\bblpt /r
快乐唯有你 发表于 2011-9-13 18:53 | 显示全部楼层
我为什么安不上去?[img][/img]
txzfw 发表于 2012-7-11 16:17 | 显示全部楼层
说明:bblpt的路径一般在安装目录的“drivers\i386”下面
