[技术问答] 一大波新唐的全新设计的芯片飞过来.
1848|1
 楼主| Harvard 发表于 2018-9-11 21:10 | 显示全部楼层 |阅读模式
从最新9月份更新的MDK5.26正式版 可见一斑,几乎是专门为新唐准备的.
https://armkeil.blob.core.windows.net/eval/MDK526.EXE
The next sections list the changes for each release of the MDK-ARM toolset.
MDK Version 5 is capable of using MDK Version 4 projects after installation of the Legacy Support. This adds support for ARM7, ARM9, and ARM Cortex-R4 processor-based devices.
Microcontroller Development Kit - Version 5.26
  • [uVision updated to V5.26.2.0]
    • Improved Event Recorder data capturing based on the Software Pack Keil - Arm Compiler Extensions 1.6.0 (included).
    • The System Analyzer now displays RTX5 RTOS thread time information.
    • ULINKplus power measurement is extended with long-term and cursor marker based energy measurement.
    • Flash programming is now supported via debug sequences (instead of programming algorithms that execute in RAM); this is required for devices with secured RAM (i.e. Microchip SAML11).
    • The PackInstaller supports local repositories to simplify pack development (for example using GitHub).
    • The Customize Tools Menu ... option is extended with Export/Import for sharing the tools menu setup across PCs.
  • [ARM Compiler included]
    • Included Arm Compiler 5 version 5.06u6 - same as in MDK - Version 5.25: see Release Notes for further details.
    • Updated Arm Compiler 6 to version 6.10.1: see Release Notes for further details.
      Note: This release solves the licensing issue caused by the Windows 10 update V1803. Previous versions of Arm Compiler 6 fail to checkout a license.
  • [Software Packs included]
    • ARM - CMSIS 5.4.0
      • Updated: CMSIS-Core (Cortex-M) to version 5.1.2 and CMSIS-Core (Cortex-A) to version 1.1.2
    • Keil - MDK Middleware 7.7.0
      • Updated: the File System Component: to version 6.10.1.
        • Minor change in Flash driver timeout handling (EFS).
      • Updated: the Network Component: to version 7.9.0.
        • Updated BSD sockets. See revision history for details.
        • Updated DNS Client control adding the following blocking functions: netSNTPc_GetTimeX, netPing_EchoX, and netDNSc_GetHostByNameX.
        • Corrected DHCP client problem assigning an address, if the IP address has already been set by AutoIP.
      • Updated: the USB Component to version 6.12.8.
        • Corrected timer, semaphore and mutex section location (for debugging).
        • Improved robustness by adding 2 retries for failed driver operations.
        • USB Host: Corrected USART_CDC_ACM.c CMSIS UART driver receive function and improved USB Flash-Disk unmount procedure.
        • USB Device: Corrected USBD_MSCn_GetMaxLUN callback return type from bool to uint8_t.
      • The Graphic Component remains unchanged at version 5.46.5 (5.46e).
    • Keil - Arm Compiler Extensions 1.6.0
      • Improved Event Recorder software component. Added Cortex-M0/M0+/M23 support utilizing new time-stamp sources: SysTick and RTOS system timer.
  • [Target debugging]
    • Updated: Segger J-Link debug driver to version 6.32i.
    • Updated: STMicroelectronics ST-LINK debug driver to version 3.0.5.0 adding option for integrated firmware updates.
    • Updated: P&E Micro debug driver to version 6.97.
    • Updated: NULink driver to version 2.05.6815.
  • [Supported Operating Systems]
    • Refer to System Requirements Overview for hardware and operating system requirements.
    • 再去看官网,新唐的刚刚入列的M23系列内核的芯片已经赫然在列.
除了这个还有几个比较有意思的单片机,没有在官网体现.
比如ML51系列
TRM_ML51Series_EN_Rev0.01.pdf (6.39 MB, 下载次数: 5)
居然还有10脚的封装,可以有三个串口 煞是有趣
另外一款,要上新的就是M031/M032系列.
PB_M031_M032_Series_EN_Rev0.13.pdf (1.52 MB, 下载次数: 3)
xuanhuanzi 发表于 2018-9-11 21:29 | 显示全部楼层
MDK更新了?我去下载。
