[求购信息] 回收AQ6330,回收AQ6330,回收AQ6330
388|0
 楼主| cw1483048431 发表于 2018-9-26 11:32 | 显示全部楼层 |阅读模式
长期AQ6330回收,二手AQ6330收购
回收AQ6330,回收YOKOGAWA AQ6330光谱分析仪
回收热线:13532739989(微信同号)在线咨询:1483048431 王生:13318450786
AQ6330回收、AQ6330价格、二手AQ6330、哪里回收AQ6330;
详细资料:
The AQ6330 is like no other optical spectrum analyzer you have ever seen. It is compact, lightweight - very portable. It weighs only 8 kg (18 lbs.), yet has all the features you need from a WDM system for field use.
Wavelength:1200~1700nm ,   Dynamic range: 40dB (peak ±1nm)
Features:
Compact and lightweight:Approx. 300 (W) x 200 (H) x 220 (D) mm, approx. 8 kg (18 lbs.).
WDM analysis function: Analyzes wavelength, level and SNR of up to 100 channels.
Long term monitoring: Capable of monitoring wavelength, level and SNR of each WDM channel.
High wavelength accuracy: Accurate to within ±0.05 nm for wavelength from 1500 to 1570, ±0.02 nm linearity, within a 1550 nm range.
High-level accuracy: High accuracy: ±0.3dB.
Internal wavelength calibration.
Low polarization dependency:±0.05dB
High power measurement: Max. +20dBm (100mW).
Built-in high-speed printer and large color display.
Useful interfaces: 3.5-inch FDD, GP-IB, PCMCIA, RS-232C, keyboard, mouse, VGA and printer ports are provided.
【详情:请联系王生13532739989 在线咨询1483048431】
