[matlab] ISE EDK 编译的怪问题!(经过一天奋战,终于解决...)
14117|31
 楼主| avonhu 发表于 2011-8-21 09:54 | 显示全部楼层 |阅读模式
这几天想调试一下板子,建了一个ISE工程,包含一个嵌入式微处理器,结果在EDK中调用: Hardware->Generate Netlist的时候,出现了如下的怪问题
ERROR:HDLParsers:3582 - Error opening "xst/plbv46_slave_single_v1_01_a/hdpdeps.ref" for reading.
ERROR:HDLParsers:3582 - Error opening "xst/xps_uartlite_v1_02_a/hdpdeps.ref" for reading.
ERROR:EDK:546 - Aborting XST flow execution!
ERROR:EDK:440 - platgen failed with errors!
make: *** [implementation/dlmb_wrapper.ngc]
而且出错模块不稳定,应该和IP核没什么关系
ERROR:HDLParsers:3582 - Error opening "xst/interrupt_control_v2_01_a/hdpdeps.ref" for reading.
make: *** [implementation/leds_8bit_wrapper.ngc]
是不是哪里设置的问题呢?我用的Windows 7, ISE SUITE 13.2
死活都通不过!求高手解惑!
 楼主| avonhu 发表于 2011-8-21 10:01 | 显示全部楼层
自己先顶一个!
 楼主| avonhu 发表于 2011-8-21 10:29 | 显示全部楼层
补充信息,通过跟踪platgen.log文件,发现是编译ps2_keyboard_wrap...时出问题的,以下是srp文件
Release 13.2 - xst O.61xd (nt)
Copyright (c) 1995-2011 Xilinx, Inc.  All rights reserved.
TABLE OF CONTENTS
  1) Synthesis Options Summary
  2) HDL Compilation
  3) Design Hierarchy Analysis
  4) HDL Analysis
  5) HDL Synthesis
     5.1) HDL Synthesis Report
  6) Advanced HDL Synthesis
     6.1) Advanced HDL Synthesis Report
  7) Low Level Synthesis
  8) Partition Report
  9) Final Report
        9.1) Device utilization summary
        9.2) Partition Resource Summary
        9.3) TIMING REPORT
*                      Synthesis Options Summary                        *
---- Source Parameters
Input Format                       : MIXED
Input File Name                    : "ps2_keyboard_wrapper_xst.prj"
Verilog Include Directory          : {"E:\MyDesigns\MyFPGA\ISE\XUPTEST\Version132\NetFPGA\NetCPU\pcores\" "D:\Xilinx132\ISE_DS\EDK\hw\XilinxBFMinterface\pcores\"
                                     "D:\Xilinx132\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\" }
---- Target Parameters
Target Device                      : xc5vlx110tff1136-1
Output File Name                   : "../implementation/ps2_keyboard_wrapper.ngc"
---- Source Options
Top Module Name                    : ps2_keyboard_wrapper
---- Target Options
Add IO Buffers                     : NO
---- General Options
Optimization Goal                  : speed
Netlist Hierarchy                  : as_optimized
Optimization Effort                : 1
Hierarchy Separator                : /
---- Other Options
Cores Search Directories           : {../implementation}
*                          HDL Compilation                              *
Total memory usage is 203936 kilobytes
Number of errors   :    1 (   0 filtered)
Number of warnings :    0 (   0 filtered)
Number of infos    :    0 (   0 filtered)
 楼主| avonhu 发表于 2011-8-21 11:32 | 显示全部楼层
修改用户环境变量,继续测试!
TEMP由c:\windows\temp修改为C:\TEMP,因为编译提示TEMP环境变量没有设置或指向了一个没有写入权限的文件夹。
正在编译ing...
 楼主| avonhu 发表于 2011-8-21 11:34 | 显示全部楼层
编译到ddr2_sdram核出问题了...以下是ddr2_sdram_wrap_xst.srp报告文件
TABLE OF CONTENTS
  2) HDL Compilation
  4) HDL Analysis
  5) HDL Synthesis
  8) Partition Report
  9) Final Report
        9.3) TIMING REPORT
Input File Name                    : "ddr2_sdram_wrapper_xst.prj"
Verilog Include Directory          : {"E:\MyDesigns\MyFPGA\ISE\XUPTEST\Version132\NetFPGA\NetCPU\pcores\" "D:\Xilinx132\ISE_DS\EDK\hw\XilinxBFMinterface\pcores\" "D:\Xilinx132\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\" }
Output File Name                   : "../implementation/ddr2_sdram_wrapper.ngc"
---- Source Options
Top Module Name                    : ddr2_sdram_wrapper
---- Target Options
Add IO Buffers                     : NO
---- Other Options
*                          HDL Compilation                              *
ERROR:HDLParsers:3582 - Error opening "xst/proc_common_v3_00_a/hdpdeps.ref" for reading.
Total memory usage is 205088 kilobytes
 楼主| avonhu 发表于 2011-8-21 11:39 | 显示全部楼层
下午继续!吃饭去咯...
 楼主| avonhu 发表于 2011-8-21 14:43 | 显示全部楼层
怎么这个帖子成我自编自导的啦!
 楼主| avonhu 发表于 2011-8-21 15:00 | 显示全部楼层
应该不是许可证的问题吧?我使用网上搜来的许可证生成器:
 楼主| avonhu 发表于 2011-8-21 15:11 | 显示全部楼层
还是不行啊!而且出错模块又变了!!!
这是EDK编译的log文件片段:
INSTANCE:hard_ethernet_mac_fifo -
E:\MyDesigns\MyFPGA\ISE\XUPTEST\Version132\NetFPGA\NetCPU\NetCPU.mhs line 389 -
Running XST synthesis
PMSPEC -- Overriding Xilinx file
<D:/Xilinx132/ISE_DS/EDK/virtex5/data/virtex5.acd> with local file
<d:/Xilinx132/ISE_DS/ISE/virtex5/data/virtex5.acd>
ERROR:HDLParsers:3582 - Error opening "xst/plbv46_slave_burst_v1_01_a/hdpdeps.ref" for reading.
INFO:EDK:2246 - Refer to
   E:\MyDesigns\MyFPGA\ISE\XUPTEST\Version132\NetFPGA\NetCPU\synthesis\hard_ethe
   rnet_mac_fifo_wrapper_xst.srp for details
以下是上述指示的报告文件:
TABLE OF CONTENTS
  2) HDL Compilation
  4) HDL Analysis
  5) HDL Synthesis
  8) Partition Report
  9) Final Report
        9.3) TIMING REPORT
Input File Name                    : "hard_ethernet_mac_fifo_wrapper_xst.prj"
Output File Name                   : "../implementation/hard_ethernet_mac_fifo_wrapper.ngc"
---- Source Options
Top Module Name                    : hard_ethernet_mac_fifo_wrapper
---- Target Options
Add IO Buffers                     : NO
---- Other Options
*                          HDL Compilation                              *
Total memory usage is 203744 kilobytes
诡异啊!诡异...
linqing171 发表于 2011-8-21 15:34 | 显示全部楼层
权限够么?
评分
参与人数 1威望 +1 收起 理由
avonhu + 1
查看全部评分
 楼主| avonhu 发表于 2011-8-21 15:38 | 显示全部楼层
我是以管理员用户登录的啊,权限应该够的啊
 楼主| avonhu 发表于 2011-8-21 15:42 | 显示全部楼层
刚从别的论坛搜到关于HDLParser出错的问题提示,说有可能是工程文件夹路径太长所致:
现在将工程文件夹拷贝到根目录,清空netlist相关文件,重新编译ing...
 楼主| avonhu 发表于 2011-8-21 15:57 | 显示全部楼层
依旧!纠结啊...
SuperX-man 发表于 2011-8-21 17:10 | 显示全部楼层
LZ,感觉还是你License的问题.
你打开License Manager看看,确认下License的情况,特别是XPS和你用到的那些IP核
评分
参与人数 1威望 +1 收起 理由
avonhu + 1
查看全部评分
SuperX-man 发表于 2011-8-21 17:16 | 显示全部楼层
我下了你的License,运行后发现,只有几个软件的运行许可,但是没有IP核的许可.
 楼主| avonhu 发表于 2011-8-21 17:39 | 显示全部楼层
这个license的确是用于对ISE SUITE的组件许可,IP核的许可采用的ISE EDK默认的Corelicense许可:
1、EDK\data\core_licenses\xilinx.lic
2、ISE\coregen\core_licenses\xilinx.lic , xilinxfree.lic
 楼主| avonhu 发表于 2011-8-21 17:50 | 显示全部楼层
刚才在ISE中新建了一个含有较少组件的工程,仍然包含一个嵌入式微处理器,不过修改了设计的属性:
如图:
1、将 PreferredLanguage由Verilog改为VHDL
2、将 VHDL Source Analysis Standard由 VHDL-93改为 VHDL-200X
结果Systhesis 通过了!现在按同样方法重新编译原工程,期待ing...
 楼主| avonhu 发表于 2011-8-21 17:52 | 显示全部楼层
还在编译,心跳加速ing...
 楼主| avonhu 发表于 2011-8-21 18:02 | 显示全部楼层
所有IP核NGC文件建立成功:
Running XST synthesis ...
INFO:EDK:4211 - The following instances are synthesized with XST. The MPD option
   IMP_NETLIST=TRUE indicates that a NGC file is to be produced using XST
   synthesis. IMP_NETLIST=FALSE (default) instances are not synthesized.
INSTANCE:hard_ethernet_mac - E:\NetFPGA\NetCPU\NetCPU.mhs line 293 - Running XST
synthesis
INSTANCE:ddr2_sdram - E:\NetFPGA\NetCPU\NetCPU.mhs line 324 - Running XST
synthesis
INSTANCE:sysace_compactflash - E:\NetFPGA\NetCPU\NetCPU.mhs line 362 - Running
XST synthesis
INSTANCE:xps_timer_0 - E:\NetFPGA\NetCPU\NetCPU.mhs line 378 - Running XST
synthesis
INSTANCE:hard_ethernet_mac_fifo - E:\NetFPGA\NetCPU\NetCPU.mhs line 389 -
INSTANCE:clock_generator_0 - E:\NetFPGA\NetCPU\NetCPU.mhs line 398 - Running XST
synthesis
INSTANCE:mdm_0 - E:\NetFPGA\NetCPU\NetCPU.mhs line 433 - Running XST synthesis
INSTANCE:proc_sys_reset_0 - E:\NetFPGA\NetCPU\NetCPU.mhs line 445 - Running XST
synthesis
INSTANCE:xps_intc_0 - E:\NetFPGA\NetCPU\NetCPU.mhs line 458 - Running XST
synthesis
Running NGCBUILD ...
IPNAME:hard_ethernet_mac_wrapper INSTANCE:hard_ethernet_mac -
E:\NetFPGA\NetCPU\NetCPU.mhs line 293 - Running NGCBUILD
Command Line: d:\Xilinx132\ISE_DS\ISE\bin\nt\unwrapped\ngcbuild.exe -p
xc5vlx110tff1136-1 -intstyle silent -i -sd .. hard_ethernet_mac_wrapper.ngc
../hard_ethernet_mac_wrapper
Reading NGO file
"E:/NetFPGA/NetCPU/implementation/hard_ethernet_mac_wrapper/hard_ethernet_mac_wr
apper.ngc" ...
Executing edif2ngd -noa
"E:\NetFPGA\NetCPU\implementation\hard_ethernet_mac_wrapper_fifo_generator_v4_3_
1.edn" "hard_ethernet_mac_wrapper_fifo_generator_v4_3_1.ngo"
Release 13.2 - edif2ngd O.61xd (nt)
INFO:NgdBuild - Release 13.2 edif2ngd O.61xd (nt)
INFO:NgdBuild - Copyright (c) 1995-2011 Xilinx, Inc.  All rights reserved.
PMSPEC -- Overriding Xilinx file <D:/Xilinx132/ISE_DS/EDK/data/edif2ngd.pfd>
with local file <d:/Xilinx132/ISE_DS/ISE/data/edif2ngd.pfd>
Writing module to "hard_ethernet_mac_wrapper_fifo_generator_v4_3_1.ngo"...
Loading design module
"E:\NetFPGA\NetCPU\implementation\hard_ethernet_mac_wrapper\hard_ethernet_mac_wr
"../hard_ethernet_mac_wrapper_fifo_generator_v4_3_1_fifo_generator_v4_3_xst_1.ng
c"...
2.edn" "hard_ethernet_mac_wrapper_fifo_generator_v4_3_2.ngo"
Writing module to "hard_ethernet_mac_wrapper_fifo_generator_v4_3_2.ngo"...
"../hard_ethernet_mac_wrapper_fifo_generator_v4_3_2_fifo_generator_v4_3_xst_1.ng
c"...
4.edn" "hard_ethernet_mac_wrapper_fifo_generator_v4_3_4.ngo"
Writing module to "hard_ethernet_mac_wrapper_fifo_generator_v4_3_4.ngo"...
"../hard_ethernet_mac_wrapper_fifo_generator_v4_3_4_fifo_generator_v4_3_xst_1.ng
c"...
3.edn" "hard_ethernet_mac_wrapper_fifo_generator_v4_3_3.ngo"
Writing module to "hard_ethernet_mac_wrapper_fifo_generator_v4_3_3.ngo"...
"../hard_ethernet_mac_wrapper_fifo_generator_v4_3_3_fifo_generator_v4_3_xst_1.ng
c"...
"E:\NetFPGA\NetCPU\implementation\hard_ethernet_mac_wrapper_blk_mem_gen_v2_7.edn
" "hard_ethernet_mac_wrapper_blk_mem_gen_v2_7.ngo"
Writing module to "hard_ethernet_mac_wrapper_blk_mem_gen_v2_7.ngo"...
"../hard_ethernet_mac_wrapper_blk_mem_gen_v2_7_blk_mem_gen_v2_7_xst_1.ngc"...
Partition Implementation Status
  No Partitions were found in this design.
NGCBUILD Design Results Summary:
  Number of errors:     0
  Number of warnings:   0
Writing NGC file "../hard_ethernet_mac_wrapper.ngc" ...
Total REAL time to NGCBUILD completion:  10 sec
Total CPU time to NGCBUILD completion:   2 sec
Writing NGCBUILD log file "../hard_ethernet_mac_wrapper.blc"...
NGCBUILD done.
IPNAME:ddr2_sdram_wrapper INSTANCE:ddr2_sdram - E:\NetFPGA\NetCPU\NetCPU.mhs
line 324 - Running NGCBUILD
xc5vlx110tff1136-1 -intstyle silent -i -sd .. ddr2_sdram_wrapper.ngc
../ddr2_sdram_wrapper
Reading NGO file
"E:/NetFPGA/NetCPU/implementation/ddr2_sdram_wrapper/ddr2_sdram_wrapper.ngc" ...
  Number of errors:     0
Writing NGC file "../ddr2_sdram_wrapper.ngc" ...
Total REAL time to NGCBUILD completion:  2 sec
Writing NGCBUILD log file "../ddr2_sdram_wrapper.blc"...
NGCBUILD done.
IPNAME:hard_ethernet_mac_fifo_wrapper INSTANCE:hard_ethernet_mac_fifo -
E:\NetFPGA\NetCPU\NetCPU.mhs line 389 - Running NGCBUILD
xc5vlx110tff1136-1 -intstyle silent -i -sd .. hard_ethernet_mac_fifo_wrapper.ngc
../hard_ethernet_mac_fifo_wrapper
Reading NGO file
"E:/NetFPGA/NetCPU/implementation/hard_ethernet_mac_fifo_wrapper/hard_ethernet_m
ac_fifo_wrapper.ngc" ...
  Number of errors:     0
Writing NGC file "../hard_ethernet_mac_fifo_wrapper.ngc" ...
Writing NGCBUILD log file "../hard_ethernet_mac_fifo_wrapper.blc"...
NGCBUILD done.
IPNAME:clock_generator_0_wrapper INSTANCE:clock_generator_0 -
E:\NetFPGA\NetCPU\NetCPU.mhs line 398 - Running NGCBUILD
xc5vlx110tff1136-1 -intstyle silent -i -sd .. clock_generator_0_wrapper.ngc
../clock_generator_0_wrapper
Reading NGO file
"E:/NetFPGA/NetCPU/implementation/clock_generator_0_wrapper/clock_generator_0_wr
apper.ngc" ...
  Number of errors:     0
Writing NGC file "../clock_generator_0_wrapper.ngc" ...
Writing NGCBUILD log file "../clock_generator_0_wrapper.blc"...
NGCBUILD done.
IPNAME:xps_intc_0_wrapper INSTANCE:xps_intc_0 - E:\NetFPGA\NetCPU\NetCPU.mhs
line 458 - Running NGCBUILD
xc5vlx110tff1136-1 -intstyle silent -i -sd .. xps_intc_0_wrapper.ngc
../xps_intc_0_wrapper
Reading NGO file
"E:/NetFPGA/NetCPU/implementation/xps_intc_0_wrapper/xps_intc_0_wrapper.ngc" ...
  Number of errors:     0
Writing NGC file "../xps_intc_0_wrapper.ngc" ...
Writing NGCBUILD log file "../xps_intc_0_wrapper.blc"...
NGCBUILD done.
希望就在前头,继续等待最后结果...
 楼主| avonhu 发表于 2011-8-21 18:03 | 显示全部楼层
哈哈...成功了!
"Running synthesis..."
cd synthesis & synthesis.cmd
"xst -ifn "NetCPU_xst.scr" -intstyle silent"
"Running XST synthesis ..."
"XST completed"
Done!
问题终于解决!不过...大侠们懂的!
