'1': Programming terminated. DONE did not go high.INFO:iMPACT:2217 - Error shows in the status register, CRC Error bit is NOT 0.
INFO:iMPACT:2218 - Error shows in the status register, release done bit is NOT 1.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 1011 0000 0011 0000 0000 0011 1100 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
PROGRESS_END - End Operation.
Elapsed time = 10 sec.
求助啊。出现这个问题引起的下载不进去的。但怎么解决啊。 |
