[应用相关] stm32 调试 ads7843时读取结果为oxfff
1426|8
 楼主| songqian17 发表于 2018-11-27 18:46 | 显示全部楼层 |阅读模式
这两天在调试tft屏上带的触控功能ic---ADS7843,但是无论用STM32F107的GPIO模拟spi或是SPI3,读出来的数据都是oxfff
xxrs 发表于 2018-11-27 18:51 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| songqian17 发表于 2018-11-27 18:54 | 显示全部楼层
TPCS   --->PB8
TPCLK  -->PC10
TPMOSI -->PC12
TPMISO -->PC11
TPIRQ    -->PC5
/*******************************GPIO模拟方式*********************************/
/*************   H 文件 **************/
#ifndef ADS7843_H
#define ADS7843_H
CS   :PB8
SCK  :PC10
MOSI :PC12
MISO :PC11
INT  :PC5
extern u16 TP_x,TP_y;
#define TP_CS()        GPIO_ResetBits(GPIOB,GPIO_Pin_8)
#define TP_DCS()       GPIO_SetBits(GPIOB,GPIO_Pin_8)
#define TP_DCLK2L()    GPIO_ResetBits(GPIOC,GPIO_Pin_10)
#define TP_DCLK2H()    GPIO_SetBits(GPIOC,GPIO_Pin_10)
#define TP_DOUT2L()    GPIO_ResetBits(GPIOC,GPIO_Pin_12)
#define TP_DOUT2H()    GPIO_SetBits(GPIOC,GPIO_Pin_12)
#define TP_RD_DIN()    GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_11)
#define TP_RD_INT()    GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_5)
void ADS7843_GPIO_Config(void) ;
void spistar(void);
void WriteCharTo7843(unsigned char num);
unsigned int ReadFromCharFrom7843(void) ;
void AD7843(void) ; //获取横坐标和纵坐标
#endif
/*************   C 文件 **************/
#include "stm32f10x.h"
#include "ads7842_gpio.h"
  GPIO_InitTypeDef  GPIO_InitStructure;
  //SPI3 Periph clock enable
//       RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3,ENABLE);
   //SPI2 Periph clock enable
// RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI2, ENABLE ) ;
//Configure SPI3 pins: SCK, MISO and MOSI
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   //推挽输出  SCK MOSI
  GPIO_Init(GPIOC,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   //推挽输出   TP__CS
  GPIO_Init(GPIOB,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;   //上拉输入   MISO
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;   //上拉输入  TP__PEN IRQ INT
void spistar()                                     //SPI开始
TP_CS(); //CS=1;
TP_DCLK2H();//DCLK=1;
TP_DOUT2H();//DIN=1;
void WriteCharTo7843(unsigned char num)          //SPI写数据
unsigned char count=0;
unsigned char tp_in=0;
TP_DCLK2L();//DCLK=0;
for(count=0;count<8;count++)
   tp_in=num&0x80;
     if(tp_in==1) TP_DOUT2H(); //DIN=CY;
  if(tp_in==0) TP_DOUT2L();
   num<<=1;
__nop();__nop();__nop();                //上升沿有效
unsigned int ReadFromCharFrom7843()             //SPI 读数据
unsigned int Num=0;
for(count=0;count<16;count++)
  Num<<=1;
  __nop();__nop();__nop();                //下降沿有效
if(TP_RD_DIN())Num++; //if(DOUT) Num++;
Num=Num>>3;
return(Num);
void AD7843(void)              //获取横坐标和纵坐标
TP_DCS();//CS=0;
//delayms(1);                     //中断后延时以消除抖动,使得采样数据更准确
//while(BUSY);                //如果BUSY信号不好使可以删除不用
//delayms(1);
WriteCharTo7843(0x90);        //送控制字 10010000 即用差分方式读X坐标 详细请见有关资料
//delayms(1);
__nop();__nop();__nop();__nop();
TP_y=ReadFromCharFrom7843();
WriteCharTo7843(0xD0);       //送控制字 11010000 即用差分方式读Y坐标 详细请见有关资料
TP_x=ReadFromCharFrom7843();
TP_CS();//CS=1;
/*********************************** SPI3 ***************************************/
#ifndef ADS7843_H
#define ADS7843_H
#define TP_CS()      GPIO_ResetBits(GPIOA,GPIO_Pin_4)
#define TP_DCS()     GPIO_SetBits(GPIOA,GPIO_Pin_4)
// GPIO_PinRemapConfig(GPIO_Remap_SPI1, ENABLE );
void SPI_Config(void) ;
unsigned char SPI_WriteByte(unsigned char data);
void SpiDelay(unsigned int DelayCnt);
u16 TPReadX(void);
u16 TPReadY(void);
#endif
#include "ads7843_wht.h"
  SPI_InitTypeDef   SPI_InitStructure;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;   //复用推挽输出  SCK MOSI
  GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE );  //外设端口重映射 开启
  // SPI3 Config
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;   //SPI_NSS_Hard
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI3,&SPI_InitStructure);
  // SPI1 enable
  SPI_Cmd(SPI3,ENABLE);
unsigned char Data = 0;
   //Wait until the transmit buffer is empty
  while(SPI_I2S_GetFlagStatus(SPI3,SPI_I2S_FLAG_TXE)==RESET);
  // Send the byte
  SPI_I2S_SendData(SPI3,data);
   //Wait until a data is received
  while(SPI_I2S_GetFlagStatus(SPI3,SPI_I2S_FLAG_RXNE)==RESET);
  // Get the received data
  Data = SPI_I2S_ReceiveData(SPI3);
  // Return the shifted data
  return Data;
unsigned int i;
for(i=0;i<DelayCnt;i++);
u16 TPReadX(void)
   u16 x=0;
   TP_CS();
   SpiDelay(10);
   SPI_WriteByte(0x90);
   SpiDelay(10);
   x=SPI_WriteByte(0x00);
   x<<=8;
   x+=SPI_WriteByte(0x00);
   SpiDelay(10);
   TP_DCS();
   x = x>>3;
   return (x);
u16 TPReadY(void)
u16 y=0;
  TP_CS();
  SpiDelay(10);
  SPI_WriteByte(0xD0);
  SpiDelay(10);
  y=SPI_WriteByte(0x00);
  y<<=8;
  y+=SPI_WriteByte(0x00);
  SpiDelay(10);
  TP_DCS();
  y = y>>3;
  return (y);
GPIO和外设的始终在main文件中已经使能。SPI3是重映射后的引脚。
stly 发表于 2018-11-27 18:55 | 显示全部楼层
随便写个数据,比如0x12(利用硬件自带SPI)到ADS7843,然后利用示波器看看CLK MOSI 的时钟波形,最好传个图片上来 我们帮你看看
renyaq 发表于 2018-11-27 18:56 | 显示全部楼层
用示波器看下,你的SPI操作成功没有;
不管什么问题,一步步验证;
xxrs 发表于 2018-11-27 18:58 | 显示全部楼层
SPI在读取数据的时候 y+=SPI_WriteByte(0xFF);同步一下时钟
morrisk 发表于 2018-11-27 19:00 | 显示全部楼层
宏定义高低电平的DIN和DOUT搞反了吧
 楼主| songqian17 发表于 2018-11-27 19:01 | 显示全部楼层
搞定了,呵呵,犯了低级错误……结贴啦,多谢各位
木木guainv 发表于 2018-12-3 15:34 | 显示全部楼层
用示波器看看
