顶层模块干嘛了?
8102|14
 楼主| jakfens 发表于 2011-8-24 10:20 | 显示全部楼层 |阅读模式
ERROR: The Top module has not been specified. This can happen if no sources have been added to the project,
or if you are using Manual Compile Order mode and have not entered the name of the top module in the Top Module field
这是啥错误?.
AutoESL 发表于 2011-8-24 10:38 | 显示全部楼层
说的很清楚啊
AutoESL 发表于 2011-8-24 10:39 | 显示全部楼层
1. no sources have been added to the project
2. have not entered the name of the top module in the Top Module field
估计不是第一条, 那就检查一下第二条呢?
 楼主| jakfens 发表于 2011-8-24 10:43 | 显示全部楼层
呃 可能不小心把testbench拿去综合了 3# AutoESL
AutoESL 发表于 2011-8-24 10:47 | 显示全部楼层
:D 4# jakfens
 楼主| jakfens 发表于 2011-8-24 11:08 | 显示全部楼层
这样怎么综合?? 5# AutoESL
avonhu 发表于 2011-8-24 21:22 | 显示全部楼层
6# jakfens
果然真的没有Top Module!!!
至于哪个是Top Module,那要看你具体项目了!这些源文件中哪个是顶层文件?或者如果都不是顶层文件的话,那就要自行编写一个顶层模块,对这些源文件模块的例化调用。
 楼主| jakfens 发表于 2011-8-25 08:44 | 显示全部楼层
呃 谢谢 我试试 7# avonhu
 楼主| jakfens 发表于 2011-8-25 14:46 | 显示全部楼层
module cpu(clk,rst,rd,wr,addr,data,opcode,fetch,ir_addr,pc_addr);
  input clk,rst;
  output rd,wr;
  output[4:0]addr;
  output[2:0]opcode;
  output fetch;
  output[4:0]ir_addr,pc_addr;
  inout[7:0]data;
  wire clk,rst;
  wire[7:0] data;
  wire[4:0]addr;
  wire rd,wr;
  wire fetch,alu_ena;
  wire[2:0] opcode;
  wire[4:0] ir_addr,pc_addr;
  wire[7:0] alu_out,accum;
  wire zero,inc_pc,load_acc,load_pc,load_ir;
  register m_register (.data(data),.load_ir(load_ir),.rst(rst),.clk(clk),.opcode(opcode),.ir_addr(ir_addr));
  accum m_accum (.data(alu_out),.load_acc(load_acc),.clk(clk),.rst(rst),.accum(accum));
  alu m_alu (.zero(zero),.data(data),.accum(accum),.clk(clk),.opcode(opcode),.alu_out(alu_out));
  machine m_machine (.inc_pc(inc_pc),.load_acc(load_acc),.load_pc(load_pc),.load_dr(load_dr),.rst(rst),.fetch(fetch),.rd(rd),.wr(wr),.clk(clk),.load_ir(load_ir),.zero(zero),.opcode(opcode));
  adr m_addrchoose (.fetch(fetch),.ir_addr(ir_addr),.pc_addr(pc_addr),.addr(addr));
  counter m_counter (.inc_pc(inc_pc),.rst(rst),.ir_addr(ir_addr),.load_pc(load_pc),.pc_addr(pc_addr));
  fetch m_fetch (.clk(clk),.rst(rst),.fetch(fetch));
  dr m_dr (.data(data),.alu_out(alu_out),.clk(clk),.rst(rst),.load_dr(load_dr));
endmodule
我这个算不算顶层模块
dan_xb 发表于 2011-8-25 15:10 | 显示全部楼层
这个算不算应该看你的其它模块写的是什么样子吧
不过这样写代码,真的很难看清楚啊
 楼主| jakfens 发表于 2011-8-25 15:28 | 显示全部楼层
呵呵 有点类似于原语吗 10# dan_xb
 楼主| jakfens 发表于 2011-8-25 16:39 | 显示全部楼层
综合出来是这样的不知道对不对
爱在2012 发表于 2011-9-14 15:11 | 显示全部楼层
一片模糊。
zhukegood 发表于 2013-9-27 11:42 | 显示全部楼层
加个威望。。。
mhanchen 发表于 2013-9-28 15:21 | 显示全部楼层
1.确保你的设计确实有顶层文件并且代码是可综合的 2.tb一定不能加到工程里去
个人签名:鄙视电工就是鄙视全人类的智慧;抛弃电子就是毁灭文明,人类将回到刀割火种的时代
30
