[产品供应]
TGA4516 西安军工IC优势订货16-20周货期
470|0
gyhxhuang|  楼主 | 2019-1-7 20:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ic, AN, TE, TI, IO
TGA4516 西安军工IC优势订货16-20周货期 订货联系国宇航芯黄云艳
TGA4516 的英文资料
The TriQuint TGA4516 is a high power amplifier (HPA) MMIC for Ka band applications. The part is designed using TriQuint's 0.15um power pHEMT process. The small chip size is achieved by utilizing TriQuint's 3 metal layer interconnect (3MI) design technology that allows compaction of the design over competing products. The TGA4516 provides > 33 dBm saturated output power and has typical gain of 18 dB at a bias of 6 V and 1050 mA (Idq). The current rises to 1. 9A under RF drive. This HPA is ideally suited for many applications such as military radar systems, Ka band satellite communications, and point-to-point radios. The TGA4516 is 100% DC and RF tested on-wafer to ensure performance compliance. The part is lead-free and RoHS compliant.
TGA4516 的特征
Features:
30 to 40 GHz bandwidth
> 33 dBm nominal Psat @ Pin = 20dBm
18 dB nominal gain
Bias: 6 V, 1050 mA Idq (1.9 A under RF Drive)
0.15 um 3MI pHEMT technology
Chip dimensions: 2.79 x 2.315 x 0.1 mm (0.110 x 0.091 x 0.004 in)
