[STM32F1] 为什么1602只显示1行呢
2673|20
 楼主| zhaoxqi 发表于 2019-1-16 15:33 | 显示全部楼层 |阅读模式
pi, IO, gp, GPIO, CD
lcd1602.h文件代码如下
#ifndef __LCD1602_H
#define __LCD1602_H
#include "sys.h"
#define LCD_RS_Set() GPIO_SetBits(GPIOB, GPIO_Pin_15)
#define LCD_RS_Clr() GPIO_ResetBits(GPIOB, GPIO_Pin_15)
#define LCD_RW_Set() GPIO_SetBits(GPIOB, GPIO_Pin_14)
#define LCD_RW_Clr() GPIO_ResetBits(GPIOB, GPIO_Pin_14)
#define LCD_EN_Set() GPIO_SetBits(GPIOB, GPIO_Pin_13)
#define LCD_EN_Clr() GPIO_ResetBits(GPIOB, GPIO_Pin_13)
#define DATAOUT(x) GPIO_Write(GPIOA, x)
void GPIO_Configuration(void);
void LCD1602_Wait_Ready(void);
void LCD1602_Write_Cmd(u8 cmd);
void LCD1602_Write_Dat(u8 dat);
void LCD1602_ClearScreen(void);
void LCD1602_Set_Cursor(u8 x, u8 y);
void LCD1602_Show_Str(u8 x, u8 y, u8 *str);
void LCD1602_Init(void);
#endif
lcd1602.c文件代码如下
#include "lcd1602.h"
#include "delay.h"
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOA,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15|GPIO_Pin_14|GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
u8 sta;
DATAOUT(0xff);
LCD_RS_Clr();
LCD_RW_Set();
do
  LCD_EN_Set();
  delay_ms(5);
   sta = GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_7);
  LCD_EN_Clr();
}while(sta & 0x80);
LCD1602_Wait_Ready();
LCD_RS_Clr();
LCD_RW_Clr();
DATAOUT(cmd);
LCD_EN_Set();
LCD_EN_Clr();
LCD_RS_Set();
LCD_RW_Clr();
DATAOUT(dat);
LCD_EN_Set();
LCD_EN_Clr();
LCD1602_Write_Cmd(0x01);
u8 addr;
if (y == 0)
  addr = 0x00 + x;
else
  addr = 0x40 + x;
LCD1602_Write_Cmd(addr | 0x80);
LCD1602_Set_Cursor(x, y);
while(*str != '\0')
  LCD1602_Write_Dat(*str++);
delay_ms(15);
LCD1602_Write_Cmd(0x38);
  delay_ms(15);
delay_ms(15);
LCD1602_Write_Cmd(0x0c);
delay_ms(15);
LCD1602_Write_Cmd(0x06);
delay_ms(15);
delay_ms(15);
main.c文件代码如下
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "led.h"
int main(void)
u8 str[] = "ATOM@ALIENTEK";
delay_init();
NVIC_Configuration();
uart_init(9600);
GPIO_Configuration();
LED_Init();
LCD1602_Init();
LCD1602_Show_Str(1, 0, str);
  LCD1602_Show_Str(2, 1, "I love STM32");
while(1)
  LED0 = 0;
  delay_ms(200);
  LED0 = 1;
  delay_ms(200);
lizye 发表于 2019-1-16 15:35 | 显示全部楼层
看这种情况应该是没有初始化成功
 楼主| zhaoxqi 发表于 2019-1-16 15:38 | 显示全部楼层
初始化代码有问题吗,检查了,没发现什么问题呀
tian111 发表于 2019-1-16 15:42 | 显示全部楼层
肯定是软件没 弄好
wuhany 发表于 2019-1-16 15:45 | 显示全部楼层
这不叫显示一行,这表明根本没正常工作。
jiaxw 发表于 2019-1-16 15:47 | 显示全部楼层
应该是初始化没有成功,图片中都不是正常的显示不是所说的只显示一行
 楼主| zhaoxqi 发表于 2019-1-16 15:51 | 显示全部楼层
初始化出了什么问题,检查不出来
liliang9554 发表于 2019-1-16 15:53 | 显示全部楼层
多看看时序
huangchui 发表于 2019-1-16 15:56 | 显示全部楼层
有可能是写命令函数的时序太快,加个延时试试
huzi2099 发表于 2019-1-16 15:56 | 显示全部楼层
F1太快了,io口设置成低速看看
jiajs 发表于 2019-1-16 15:59 | 显示全部楼层
应该是“LCD1602_Write_Cmd(0x38);”写入不成功,可能是LCD的上电复位比较慢,需要较长的延时,我的解决办法是增加首次的延时时间,写3次!不过你显示的是方块,没有显示内容,时序方面有问题。
 楼主| zhaoxqi 发表于 2019-1-16 16:02 | 显示全部楼层
搞定了~感谢大家的帮助。
mmuuss586 发表于 2019-1-16 21:02 | 显示全部楼层
程序哪里问题吧
guanjiaer 发表于 2019-2-11 12:08 | 显示全部楼层
上电后加长延时时间
heimaojingzhang 发表于 2019-2-11 12:10 | 显示全部楼层
看来真的是上电的问题哦
keaibukelian 发表于 2019-2-11 12:39 | 显示全部楼层
感觉这种屏对时序的要求很严格
labasi 发表于 2019-2-11 12:42 | 显示全部楼层
像这种产品啊  都要好好读读他的说明要求
paotangsan 发表于 2019-2-11 12:46 | 显示全部楼层
楼主怎么解决的问题啊  我很好奇啊
wowu 发表于 2019-2-11 12:59 | 显示全部楼层
不会的 这种串口屏 对时序要求并不高
xiaoqizi 发表于 2019-2-11 13:01 | 显示全部楼层
估计还是上电不完全
