TI Experimenter Kit-官方套件汇总
1547|14
 楼主| zhangmangui 发表于 2019-1-28 22:34 | 显示全部楼层 |阅读模式
TMS320F28335 Experimenter Kit
Hardware Features
  • TMDSCNCD28335: TMS320F28335 DIMM100 based controlCARD
  • DIMM100 Docking Station baseboard with DIMM100 controlCARD female connector
    • XDS100v1 USB-to-JTAG Debug Probe enables real-time in-system programming and debugging
    • Header pin access to key MCU signals – including most major digital IO and analog inputs
    • Breadboard area for customizable routing/prototyping
    • Board power can be provided by the provided USB cable or a 5V barrel supply
  • Hardware Files are in C2000Ware at boards\controlCARDs\TMDSCNCD28335
原理图:
相关手册:
大大,为你打call  发表于 2019-2-15 17:50
 楼主| zhangmangui 发表于 2019-1-28 22:43 | 显示全部楼层
F28379D controlCARD for C2000 Real time control development kits
Hardware Features
  • TMDSCNCD28379D: TMS320F28379D HSEC180 based controlCARD
    • Isolated XDS100v2 USB-to-JTAG Debug Probe enables real-time in-system programming and debugging
  • Standard 180-pin HSEC interface
  • Analog I/O, digital I/O and JTAG signals at card interface
  • USB Host connector
  • SDCard Slot
  • Hardware Files are in C2000Ware at boards\controlCARDs\TMDSCNCD28379D
 楼主| zhangmangui 发表于 2019-1-28 22:57 | 显示全部楼层
EtherCAT Slave and C2000 Delfino MCU controlCARD Kit for Industrial Factory Automation Applications
C2000™ high-performance real-time control MCU paired with low-latency real-time industrial EtherCAT at 100MbpsHigh-bandwidth, low-latency parallel interface to Beckhoff ET1100 EtherCAT slave controller (ESC)Hardware adapation software layer of MCU peripherals and C28x adaptation software for EtherCAT Technology Group slave stackExamples using TwinCAT/PC master and C2000 slave demo code; example supporting speed and position control on the Industrial Drives Development Kit (TMDXIDDK379D)Use with C2000 applications kits or "standalone" modeHardware Files are in controlSUITE at development_kits\TMDSECATCND379D_V1.0
 楼主| zhangmangui 发表于 2019-1-28 23:00 | 显示全部楼层
F28379D Delfino Experimenter Kit
Bread-board like baseboard with HSEC180 controlCARD female connector
 楼主| zhangmangui 发表于 2019-1-28 23:04 | 显示全部楼层
C2000 DesignDRIVE Development Kit for Industrial Motor Control
 楼主| zhangmangui 发表于 2019-1-28 23:08 | 显示全部楼层
C2000 Delfino MCUs F28377S LaunchPad Development Kit
USB connected isolated XDS100v2 JTAG debug probe for real-time debug and flash programming4x 20-pin headers/connectorsProgrammable buttons and LEDsTMS320F28377S: 200 MHz C28xCPU and CLA, 1 MB Flash, 16-bit/12-bit ADCs, comparators, 12-bit DACs, delta-sigma sync filters, HRPWMs, eCAPs, eQEPs, CANs, and more.Supports two BoosterPacks
 楼主| zhangmangui 发表于 2019-1-28 23:12 | 显示全部楼层
C2000 Delfino MCU F28379D LaunchPad™ development kit
USB connected isolated XDS100v2 JTAG debug probe for real-time debug and flash programming4x 20-pin headers/connectorsProgrammable buttons and LEDsTMS320F28379D: 200 MHz dual C28xCPUs and dual CLAs, 1 MB Flash, 16-bit/12-bit ADCs, comparators, 12-bit DACs, delta-sigma sinc filters, HRPWMs, eCAPs, eQEPs, CANs, and moreC2000 Delfino Position Manager-ready TMS320F28379D MCU capable of interfacing to absolute encoders as well as resolvers and SINCOS transducersSupports two BoosterPacksTwo encoder interface connectorsIsolated CAN transceiver connectorHardware Files are in C2000Ware at boards\LaunchPads\LAUNCHXL_F28379D
 楼主| zhangmangui 发表于 2019-1-29 21:59 | 显示全部楼层
C2000 Piccolo MCU F28027 LaunchPad™ development kit
USB connected isolated XDS100 JTAG debug probe for real-time debug and flash programming2x 20-pin headers/connectors with access to all device pinsProgrammable buttons and LEDsSuperset TMS320F28027: 60 MHz C28x CPU, 64 KB Flash, 8 PWM Channels, 12-bit ADC, capture interface, UART, SPI, and moreHardware Files are in C2000Ware at boards\LaunchPads\LAUNCHXL_F28027
 楼主| zhangmangui 发表于 2019-1-29 22:02 | 显示全部楼层
C2000 Piccolo MCU F28069M LaunchPad™ development kit
USB connected isolated XDS100v2 JTAG debug probe for real-time debug and flash programming4x 20-pin headers/connectorsProgrammable buttons and LEDsTMS320F28069M: 90 MHz C28x CPU, 256 KB Flash, InstaSPIN-FOC and InstaSPIN-MOTION enabled, 12-bit ADC, CAN, 2x encoder interface (eQEP), UART, SPI, and moreSupports two BoosterPacksTwo encoder interface connectorsIsolated CAN transceiver connectorHardware Files are in C2000Ware at boards\LaunchPads\LAUNCHXL_F28069M
 楼主| zhangmangui 发表于 2019-1-29 22:05 | 显示全部楼层
C2000 Piccolo MCU F280049C LaunchPad™ development kit
TMS320F280049C: 100 MHz C28x CPU with FPU and TMU, 256 KB Flash, InstaSPIN-FOC enabled, 3x 12-bit ADC, CAN, encoder, FSI, UART, and moreOn-board XDS110 debug probe for real-time debug and flash programming80 pin LaunchPad leveraging the BoosterPack ecosystemPower domain isolation for real-time debug  and flash programmingIsolated CAN transceiverTwo encoder interface connectorsFSI interface connectorHardware Files are in C2000Ware at boards\LaunchPads\LAUNCHXL_F280049C
 楼主| zhangmangui 发表于 2019-2-19 21:44 | 显示全部楼层
 楼主| zhangmangui 发表于 2019-2-19 21:54 | 显示全部楼层
MSP430FR2355 LaunchPad™ development kit
ULP FRAM technology based on the MSP430FR2355 16-bit MCU with smart analog comboOn-board eZ-FET debug probe with EnergyTrace Technology available for ultra-low-power debugging40-pin LaunchPad headers to leverage the BoosterPack ecosystem2 buttons and 2 LEDs for user interactionOn-board ambient light sensorOn-board Grove module interface to add external sensors, actuators and more
 楼主| zhangmangui 发表于 2019-2-19 21:56 | 显示全部楼层
MSP430FR2433 LaunchPad™ Development Kit
ULP FRAM technology based MSP430FR2433 16-bit MCUEnergyTrace™ Technology available for ultra-low-power debugging20-pin LaunchPad kit standard leveraging the BoosterPack ecosystemOn-board eZ-FET debug probe2 buttons and 2 LEDs for user interaction
 楼主| zhangmangui 发表于 2019-2-19 21:59 | 显示全部楼层
MSP430FR5994 LaunchPad Development Kit
ULP FRAM technology based MSP430FR5994 16-bit MCU with low-energy accelerator (LEAEnergyTrace++ Technology available for ultra-low-power debugging40-pin LaunchPad kit standard leveraging the BoosterPack ecosystemOn-board eZ-FET debug probe2 buttons and 2 LEDs for user interactionOn-board micro SD CardSuper Capacitor (0.22 F)
http://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/MSP-EXP430FR5994/latest/index_FDS.html
个人签名:欢迎进入【TI DSP 论坛】 & 【DSP 技术】           TI忠诚粉丝!
935
