[STM32F4] 外部晶振起振
1016|12
 楼主| renyaq 发表于 2019-2-15 08:51 | 显示全部楼层 |阅读模式
STM32F407ZG 外部晶振是要程序启动还是MCU上电即可起振
 楼主| renyaq 发表于 2019-2-15 08:55 | 显示全部楼层
MCU没有写任何程序
zwll 发表于 2019-2-15 08:58 | 显示全部楼层
你当然要配置STM32F407ZG在 外部晶振模式了。
zwll 发表于 2019-2-15 09:02 | 显示全部楼层
 楼主| renyaq 发表于 2019-2-15 09:05 | 显示全部楼层
意思是还是要在程序中启动 外部晶振才能起振?
juventus9554 发表于 2019-2-15 09:08 | 显示全部楼层
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
 楼主| renyaq 发表于 2019-2-15 09:12 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈,结贴了先
mmuuss586 发表于 2019-2-15 12:01 | 显示全部楼层
默认使用内部晶振,使用程序
wanduzi 发表于 2019-2-15 20:00 | 显示全部楼层
程序执行后才转到外部
labasi 发表于 2019-3-5 16:00 | 显示全部楼层
当然是上电起振了
paotangsan 发表于 2019-3-5 16:04 | 显示全部楼层
当然是上电了
renzheshengui 发表于 2019-3-5 16:43 | 显示全部楼层
一定是上电呀 没有疑问
wakayi 发表于 2019-3-5 16:49 | 显示全部楼层
无论是外部还是内部 都是上电起振啊
