8bit_MCU救命啊!STM8S105 写EEPROM 多了,中断就不响应了!
7475|11
 楼主| 上树的猪 发表于 2011-9-1 05:33 | 显示全部楼层 |阅读模式
长话短说
目前 能从实验 的现象 稳定再现,  写入EEPROM    几个字节 正常
写入 十几个 字节,  EEPROM 写入 正常, 但是中断 就再也不能响应了!!
不知道 是 我程序 问题, 还是  芯片的问题!
大家有没有类似现象?
部分代码
#define WR_PG_DIS ( 1 << 0 )
#define HVOFF_BIT ( 1 << 6 )
*  奶奶的 资料上说是 EOP 结果 STM8S105 等不到 EOP, 后来看ST库,结果
*  他等的是 HVOFF
void WaitEOP( void )
    unsigned char flagstatus;
    unsigned short TimeOut;
    for( TimeOut = 0; TimeOut < 0xFFFF; TimeOut++ )
        flagstatus = ( FLASH_IAPSR & ( WR_PG_DIS | HVOFF_BIT ));
        if( flagstatus != 0 )
            break;
    //超时退出
void InitWriteEEPROM( void )
    if( 0 == FLASH_IAPSR_DUL )
        FLASH_DUKR = 0xAE;
        FLASH_DUKR = 0x56;
        while( 0 == FLASH_IAPSR_DUL );
*  就是EEPROM 空的时候  执行这个时候,有问题的
void LoadDefaultSysPara( void )
    InitWriteEEPROM();
    *(( unsigned char * ) EEPROM_ServicePosition ) = 50;
    WaitEOP();
    *(( unsigned char * ) EEPROM_BackwashPosition ) = 10;
    WaitEOP();
    *(( unsigned char * ) EEPROM_BrineDrawPosition ) = 10;
    WaitEOP();
    *(( unsigned char * ) EEPROM_WashPosition ) = 40;
    WaitEOP();
    *(( unsigned char * ) EEPROM_ReFillPosition ) = 50;
    WaitEOP();
    *(( unsigned char * ) EEPROM_SafeDuration ) = 15;
    WaitEOP();
    *(( unsigned char * ) EEPROM_G_FlowModulusH ) = 6;
    WaitEOP();
    *(( unsigned char * ) EEPROM_G_FlowModulusL1 ) = 9;
    WaitEOP();
    *(( unsigned char * ) EEPROM_G_FlowModulusL2 ) = 4;
    WaitEOP();
    *(( unsigned char * ) EEPROM_G_FlowModulusL3 ) = 4;
    WaitEOP();
    *(( unsigned char * ) EEPROM_M_FlowModulusH ) = 2;
    WaitEOP();
    *(( unsigned char * ) EEPROM_M_FlowModulusL1 ) = 6;
    WaitEOP();
    *(( unsigned char * ) EEPROM_M_FlowModulusL2 ) = 2;
    WaitEOP();
    *(( unsigned char * ) EEPROM_M_FlowModulusL3 ) = 0;
    WaitEOP();
    *(( unsigned char * ) EEPROM_Language ) = LangType_English;
    WaitEOP();
    *(( unsigned char * ) EEPROM_ValveType ) = 1;
    WaitEOP();
    *(( unsigned char * ) EEPROM_DefaultType ) = 2;
    WaitEOP();
bobo5650 发表于 2011-9-1 08:50 | 显示全部楼层
兄弟你真勤快,这么早发帖...
应该就是RWW的问题了,105没RWW,写eeprom的时候程序是停止的...
 楼主| 上树的猪 发表于 2011-9-1 09:12 | 显示全部楼层
兄弟你真勤快,这么早发帖...
没办法, 老板说是 我软件 BUG 让我 好好查查......
但是  程序停止的,   怎么中断也会停止?
就算 写的时候 停止   那写完了, 应该 放开 呀?
难道是 芯片 BUG  写完了,它 也 不让中断 响应 ?
IJK 发表于 2011-9-1 09:28 | 显示全部楼层
2L说得有理。记得STM8如果没有RWW(Read While Write),在写eeprom时不能响应中断,记得在PM(Program Manual)里面说了
tuyanjun 发表于 2011-9-1 09:38 | 显示全部楼层
减小写E2的时间,我就是这么做的,四字节一次写入
 楼主| 上树的猪 发表于 2011-9-1 09:57 | 显示全部楼层
写的时候 不能响应 . 是 没问题
但是  写完了呢 ?    写完了 应该 响应了吧 ?
难道 写  期间 发生多次中断,   这个中断就死掉了?
香水城 发表于 2011-9-1 10:00 | 显示全部楼层
写的时候 不能响应 . 是 没问题
写完EEPROM,CPU会响应中断;至于写期间发生多次中断,这个中断会不会死掉,就要看你的设备怎么处理了,还要看你的中断处理程序。
 楼主| 上树的猪 发表于 2011-9-1 10:24 | 显示全部楼层
GPIO 中断啊...  没标志位啊...
today_lucky 发表于 2012-3-16 14:42 | 显示全部楼层
hf5542 发表于 2012-3-22 10:36 | 显示全部楼层
明月小厨 发表于 2012-12-11 21:48 | 显示全部楼层
6mS的时间能有很多中断要发生吗?这点时间都不能等吗?要不你外挂串口的FLASHRAM;这样就没事了;
TECHWELL 发表于 2014-5-14 13:52 | 显示全部楼层
   我用STM8S105K4,也遇到了写EEPROM时程序halt之问题
   在ST官网上的、最新的文档CD00200092.PDF(STM8S105xx之datasheet,February 2014 DocID14771 Rev 13)中,明明白白地吹:
4.3 Flash program and data EEPROM memory
• Up to 32 Kbytes of Flash program single voltage Flash memory
• Up to 1 Kbytes true data EEPROM
• Read while write: Writing in data memory possible while executing code in program memory
• User option byte area
   这儿的专家,却说没这个RWW功能了。
   我应该相信专家?
   还是该相信官方文档??
  我可以骂娘吗???
  香水城,能加我QQ么?
  396936661
