为什么同样的程序同样的硬件,有时候程序能下载到flash有时候下不进去呢,提示信息如下,大家帮忙分析一下,是否有其他人也遇到过这个问题,是否是我的J-LINK不好!
* JLink Info: Found SWD-DP with ID 0x1BA01477
* JLink Info: TPIU fitted.
* JLink Info: ETM fitted.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
Full Chip Erase Done.
Programming Done.
Contents missmatch at: 08000000H (Flash=FFH Required=00H) !
Contents missmatch at: 08000001H (Flash=FFH Required=86H) !
Contents missmatch at: 08000002H (Flash=FFH Required=00H) !
Contents missmatch at: 08000003H (Flash=FFH Required=20H) !
Contents missmatch at: 08000004H (Flash=FFH Required=45H) !
Contents missmatch at: 08000005H (Flash=FFH Required=01H) !
Contents missmatch at: 08000006H (Flash=FFH Required=00H) !
Contents missmatch at: 08000007H (Flash=FFH Required=08H) !
Contents missmatch at: 08000008H (Flash=FFH Required=4DH) !
Contents missmatch at: 08000009H (Flash=FFH Required=01H) !
Contents missmatch at: 0800000AH (Flash=FFH Required=00H) !
Contents missmatch at: 0800000BH (Flash=FFH Required=08H) !
Contents missmatch at: 0800000CH (Flash=FFH Required=4FH) !
Contents missmatch at: 0800000DH (Flash=FFH Required=01H) !
Contents missmatch at: 0800000EH (Flash=FFH Required=00H) !
Contents missmatch at: 0800000FH (Flash=FFH Required=08H) !
Contents missmatch at: 08000010H (Flash=FFH Required=51H) !
Contents missmatch at: 08000011H (Flash=FFH Required=01H) !
Contents missmatch at: 08000012H (Flash=FFH Required=00H) !
Contents missmatch at: 08000013H (Flash=FFH Required=08H) !
Contents missmatch at: 08000014H (Flash=FFH Required=53H) !
Contents missmatch at: 08000015H (Flash=FFH Required=01H) !
Contents missmatch at: 08000016H (Flash=FFH Required=00H) !
Contents missmatch at: 08000017H (Flash=FFH Required=08H) !
Contents missmatch at: 08000018H (Flash=FFH Required=55H) !
Contents missmatch at: 08000019H (Flash=FFH Required=01H) !
Contents missmatch at: 0800001AH (Flash=FFH Required=00H) !
Contents missmatch at: 0800001BH (Flash=FFH Required=08H) !
Contents missmatch at: 0800001CH (Flash=FFH Required=00H) !
Contents missmatch at: 0800001DH (Flash=FFH Required=00H) !
Contents missmatch at: 0800001EH (Flash=FFH Required=00H) !
Contents missmatch at: 0800001FH (Flash=FFH Required=00H) !
Contents missmatch at: 08000020H (Flash=FFH Required=00H) !
Contents missmatch at: 08000021H (Flash=FFH Required=00H) !
Contents missmatch at: 08000022H (Flash=FFH Required=00H) !
Contents missmatch at: 08000023H (Flash=FFH Required=00H) !
Contents missmatch at: 08000024H (Flash=FFH Required=00H) !
Contents missmatch at: 08000025H (Flash=FFH Required=00H) !
Contents missmatch at: 08000026H (Flash=FFH Required=00H) !
Contents missmatch at: 08000027H (Flash=FFH Required=00H) !
Contents missmatch at: 08000028H (Flash=FFH Required=00H) !
Contents missmatch at: 08000029H (Flash=FFH Required=00H) !
Contents missmatch at: 0800002AH (Flash=FFH Required=00H) !
Contents missmatch at: 0800002BH (Flash=FFH Required=00H) !
Contents missmatch at: 0800002CH (Flash=FFH Required=57H) !
Contents missmatch at: 0800002DH (Flash=FFH Required=01H) !
Contents missmatch at: 0800002EH (Flash=FFH Required=00H) !
Contents missmatch at: 0800002FH (Flash=FFH Required=08H) !
Contents missmatch at: 08000030H (Flash=FFH Required=59H) !
Contents missmatch at: 08000031H (Flash=FFH Required=01H) !
Contents missmatch at: 08000032H (Flash=FFH Required=00H) !
Contents missmatch at: 08000033H (Flash=FFH Required=08H) !
Contents missmatch at: 08000034H (Flash=FFH Required=00H) !
Contents missmatch at: 08000035H (Flash=FFH Required=00H) !
Contents missmatch at: 08000036H (Flash=FFH Required=00H) !
Contents missmatch at: 08000037H (Flash=FFH Required=00H) !
Contents missmatch at: 08000038H (Flash=FFH Required=5BH) !
Contents missmatch at: 08000039H (Flash=FFH Required=01H) !
Contents missmatch at: 0800003AH (Flash=FFH Required=00H) !
Contents missmatch at: 0800003BH (Flash=FFH Required=08H) !
Contents missmatch at: 0800003CH (Flash=FFH Required=5DH) !
Contents missmatch at: 0800003DH (Flash=FFH Required=01H) !
Contents missmatch at: 0800003EH (Flash=FFH Required=00H) !
Contents missmatch at: 0800003FH (Flash=FFH Required=08H) !
Contents missmatch at: 08000040H (Flash=FFH Required=7DH) !
Contents missmatch at: 08000041H (Flash=FFH Required=96H) !
Contents missmatch at: 08000042H (Flash=FFH Required=00H) !
Contents missmatch at: 08000043H (Flash=FFH Required=08H) !
Contents missmatch at: 08000044H (Flash=FFH Required=F9H) !
Contents missmatch at: 08000045H (Flash=FFH Required=7BH) !
Contents missmatch at: 08000046H (Flash=FFH Required=00H) !
Contents missmatch at: 08000047H (Flash=FFH Required=08H) !
Contents missmatch at: 08000048H (Flash=FFH Required=09H) !
Contents missmatch at: 08000049H (Flash=FFH Required=8FH) !
Contents missmatch at: 0800004AH (Flash=FFH Required=00H) !
Contents missmatch at: 0800004BH (Flash=FFH Required=08H) !
Contents missmatch at: 0800004CH (Flash=FFH Required=3BH) !
Contents missmatch at: 0800004DH (Flash=FFH Required=85H) !
Contents missmatch at: 0800004EH (Flash=FFH Required=00H) !
Contents missmatch at: 0800004FH (Flash=FFH Required=08H) !
Contents missmatch at: 08000050H (Flash=FFH Required=8DH) !
Contents missmatch at: 08000051H (Flash=FFH Required=67H) !
Contents missmatch at: 08000052H (Flash=FFH Required=00H) !
Contents missmatch at: 08000053H (Flash=FFH Required=08H) !
Contents missmatch at: 08000054H (Flash=FFH Required=1DH) !
Contents missmatch at: 08000055H (Flash=FFH Required=83H) !
Contents missmatch at: 08000056H (Flash=FFH Required=00H) !
Contents missmatch at: 08000057H (Flash=FFH Required=08H) !
Contents missmatch at: 08000058H (Flash=FFH Required=6DH) !
Contents missmatch at: 08000059H (Flash=FFH Required=64H) !
Contents missmatch at: 0800005AH (Flash=FFH Required=00H) !
Contents missmatch at: 0800005BH (Flash=FFH Required=08H) !
Contents missmatch at: 0800005CH (Flash=FFH Required=71H) !
Contents missmatch at: 0800005DH (Flash=FFH Required=64H) !
Contents missmatch at: 0800005EH (Flash=FFH Required=00H) !
Contents missmatch at: 0800005FH (Flash=FFH Required=08H) !
Contents missmatch at: 08000060H (Flash=FFH Required=BDH) !
Contents missmatch at: 08000061H (Flash=FFH Required=64H) !
Contents missmatch at: 08000062H (Flash=FFH Required=00H) !
Contents missmatch at: 08000063H (Flash=FFH Required=08H) !
Too many errors to display ! |
