stm32+freeRTOS+LwIP移植
14737|21
 楼主| hhbgk 发表于 2011-9-5 11:08 | 显示全部楼层 |阅读模式
编译出现如下错误,有人知道是怎么回事吗?
Building configuration: RTOSDemo - Debug
Updating build tree...
stm32f107.c
Warning[Pe047]: incompatible redefinition of macro "SCS_BASE" (declared at line 529 of "T:\项目\FreeRTOS_Source\ T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\CORTEX_STM32F103_IAR\STM32F10xFWLib\CM3\core_cm3.h 269
FreeRTOS1.7\Demo\CORTEX_STM32F103_IAR\STM32F10xFWLib\inc\stm32f10x_map.h")
Linking
Error[Li005]: no definition for "tcp_tmr" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
CORTEX_STM32F103_IAR\Debug\Obj\netconf.o]
Error[Li005]: no definition for "etharp_tmr" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "dhcp_fine_tmr" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "dhcp_coarse_tmr" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_new" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
CORTEX_STM32F103_IAR\Debug\Obj\helloworld.o]
Error[Li005]: no definition for "tcp_bind" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_listen_with_backlog" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\
Demo\CORTEX_STM32F103_IAR\Debug\Obj\helloworld.o]
Error[Li005]: no definition for "tcp_accept" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "ip_addr_any" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_arg" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_err" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_write" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "STM32F10x_STR" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_recved" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "pbuf_free" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "mem_free" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "tcp_close" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "mem_malloc" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
CORTEX_STM32F103_IAR\Debug\Obj\mem.o]
Error[Li005]: no definition for "Set_MAC_Address" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "netif_add" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "netif_set_default" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "dhcp_start" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "netif_set_up" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "ethernet_input" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "ethernetif_init" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
Error[Li005]: no definition for "EXTI_Init" [referenced from T:\项目\FreeRTOS_Source\FreeRTOS1.7\Demo\
CORTEX_STM32F103_IAR\Debug\Obj\stm32f107.o]
Error[Li005]: no definition for "xAreBlockingQueuesStillRunning" [referenced from T:\项目\FreeRTOS_Source\
FreeRTOS1.7\Demo\CORTEX_STM32F103_IAR\Debug\Obj\main.o]
Error[Li005]: no definition for "xAreBlockTimeTestTasksStillRunning" [referenced from T:\项目\FreeRTOS_Source\
Error[Li005]: no definition for "xArePollingQueuesStillRunning" [referenced from T:\项目\FreeRTOS_Source\
Error[Lp011]: section placement failed: unable to allocate space for sections/blocks with a total estimated minimum
size of 0xe17a bytes in <[mem:0x20000000-mem:0x20004fff]> (total uncommitted space 0x5000)
Error while running Linker
Total number of errors: 30
Total number of warnings: 1
open_free 发表于 2011-9-5 13:25 | 显示全部楼层
根据提示一点点找吧。。:)
 楼主| hhbgk 发表于 2011-9-5 13:44 | 显示全部楼层
有没有人在stm3210x上移植freeRTOS+LwIP成功的啊
open_free 发表于 2011-9-5 18:27 | 显示全部楼层
肯定能成功,你咋选这么有难度的。。。
dfsa 发表于 2011-9-5 19:53 | 显示全部楼层
有些难度
火箭球迷 发表于 2011-9-5 22:59 | 显示全部楼层
没有移植过
guet_new_man 发表于 2011-9-6 11:40 | 显示全部楼层
LZ好好努力啊 过段时间我可能也要这样搞一下,到时多多交流 。
 楼主| hhbgk 发表于 2011-9-6 20:54 | 显示全部楼层
肯定能成功,你咋选这么有难度的。。。
请问你移植成功了吗?
 楼主| hhbgk 发表于 2011-9-6 20:55 | 显示全部楼层
有些难度
没人指点,只能靠自己啃了
 楼主| hhbgk 发表于 2011-9-6 20:56 | 显示全部楼层
上面的问题是解决了,现在是有新的问题啊,如下:
section placement failed: unable to allocate space for ctions/blocks  with a total estimated minimum size of 0x10cc2 bytes in  <[mem:0x20000000-mem:0x20004fff]> (total uncommitted space 0x5000)
hb_haitao2009 发表于 2011-9-7 16:55 | 显示全部楼层
有移植,但是会崩溃:'(
mrxiaocui 发表于 2012-3-29 16:10 | 显示全部楼层
你好 现在你的freerto+lwip调通了吗 能不能发给我个例程 谢谢 386845497@qq.com
winloop 发表于 2012-3-30 09:37 | 显示全部楼层
你太坏了,人家正求助呢,你这跟人家要例程
yinyangdianzi 发表于 2012-3-30 09:55 | 显示全部楼层
a43770 发表于 2012-12-6 16:09 | 显示全部楼层
头文件没有包含进去
song19881218 发表于 2012-12-6 16:16 | 显示全部楼层
ST官网有这方面的例程,可以去下载一下
song19881218 发表于 2012-12-6 16:18 | 显示全部楼层
这个可以取借鉴一下
stm32f2x7_eth_lwip.zip
3.34 MB, 下载次数: 244
wjjontheway 发表于 2014-4-18 09:07 | 显示全部楼层
谢谢song19881218的分享啊。
alber5099 发表于 2014-10-31 08:45 | 显示全部楼层
謝謝,我正在做這個
