stm32w 怎么烧录CIB,CIB的内容含义是什么?
3344|0
 楼主| 上官金虹 发表于 2011-9-7 14:30 | 显示全部楼层 |阅读模式
''General' token group
TOKEN_MFG_CIB_OBS          [16 byte array ] : A55AFF00FF00FF00 FF00FF00FF00FF00
TOKEN_MFG_CUSTOM_VERSION   [16-bit integer] : 0x01FE
TOKEN_MFG_CUSTOM_EUI_64    [ 8 byte array ] : 08090A0B0C0D0E0F
TOKEN_MFG_STRING           [16 byte string] : "HAC Board!" (10 of 16 chars)
                                              48414320426F6172 6421FFFFFFFFFFFF
TOKEN_MFG_BOARD_NAME       [16 byte string] : "" (0 of 16 chars)
                                              FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF
TOKEN_MFG_MANUF_ID         [16-bit integer] : 0x1234
TOKEN_MFG_PHY_CONFIG       [16-bit integer] : 0xFFFC
TOKEN_MFG_BOOTLOAD_AES_KEY [16 byte array ] : FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF
TOKEN_MFG_EZSP_STORAGE     [ 8 byte array ] : FFFFFFFFFFFFFFFF
TOKEN_MFG_OSC24M_BIAS_TRIM [16-bit integer] : 0xFFFF
'Smart Energy CBKE (TOKEN_MFG_CBKE_DATA)' token group
Device Implicit Cert [48 byte array ] : FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF
CA Public Key        [22 byte array ] : FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF
                                        FFFFFFFFFFFF
Device Private Key   [21 byte array ] : FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF
                                        FFFFFFFFFF
CBKE Flags           [ 1 byte array ] : FF
'Smart Energy Install Code (TOKEN_MFG_INSTALLATION_CODE)' token group
Install Code Flags [ 2 byte array ] : FFFF
Install Code       [16 byte array ] : FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF
CRC                [16-bit integer] : 0xFFFF
个人签名:入门玩单片机C++
