<font color=#FF6600>关于TI的电源产品设计参考手册的简介</font>::<table class=ubb cellspacing=0><TR><td class=ubb>包括的型号有TPS62220(Synchronous Buck)、TPS62040(Synchronous Buck)、TPS54350(Non-Synchronous Buck)、TPS54350(Inverting Buck Boost)、TPS54610(6A Monolithic Buck)、TPS61030(5V, 1A Boost Converter)、TPS64201(5V, Non-Synchronous Buck in SOT-23)、<font color=#FF0080>TPS43000( Sepic Controller)、</font>TPS40007( Low Input Voltage Synchronous Buck)、TPS40055(12-V, Input Synchronous Buck)、UC3572( Negative Output Flyback)、TPS40071( Synchronous Buck)、TPS51020( Dual Output Synchronous Buck)、TPS40060 (Wide Input Synchronous Buck)、TPS40130(2-Phase Buck with Integrated Drivers)、UCC38C4x(UCC38C4x Boost)、UCC3809 (Isolated Synchronous Flyback)、UCC3813(Triple Output Flyback)、UCC2580( Active Clamp Forward Converter)、bq24103 (Synchronous Switch-Mode Lithium-Ion Charger)等</td></TR></table><br /><br /><font color=#FF0000>TI的电源产品设计参考手册.pdf →</font> <a href="http://www.dykf.com/Soft/ShowSoftDown.asp?UrlID=1&SoftID=187" target=_blank>http://www.dykf.com/Soft/ShowSoftDown.asp?UrlID=1&SoftID=187</a>
