<br /><br />此处定义的数组,在下面供函数调用,编译总是出错,尝试了很多办法还是不行,希望高手能指点一下~~~~~如果要能正常调用该数组,该如何改正或者用其他办法如何实现?小弟不甚感激~~~~<br /><br />unsigned char Inputdata_1[251574] <br /><br />void Display(int addr) //此处改成过指针的形式,但是后面没改,编译依然无法通过<br />{<br /> <br /> int_t i,j;<br /> int_t a,b;<br /> TempBuffer_img[j] = addr[i*960+j+54]; <br /><br />}<br /><br />void mian()<br />{<br />Display(Inputdata_1)<br />}<br /> <br />附:编译错误提示<br />"main.c", line 53: cc0142: error: expression must have pointer-to-object type<br /> TempBuffer_img[j] = addr[i*960+j+54];<br /> ^<br />编译软件对此错误的解释:<br />Compiler Error: expression must have pointer-to-object type<br />Description<br />The expression used does not have a pointer-to-object type. <br />Severity<br />Fatal error<br />Recovery<br />The compiler cannot recover from this error.<br />Example<br />int a;<br />int main()<br />{<br />return a[1]; /* Error occurs here */<br />}<br />How to Fix<br />Ensure that the expression used has a pointer-to-object type. The lvalue must be for a scalar, and if it is a pointer, it must point to an object.<br />One of the operands must have a pointer-to-object type, and the other one must be an integral expression. You can make the above example compile by either changing the declaration "int a;" to "int a[];" or by changing the return statement to "return a".<br /> <br /> |
