sourceless connector ERROR问题!
4226|4
 楼主| 274643473 发表于 2011-9-7 16:57 | 显示全部楼层 |阅读模式
在EDK12.2里综合的时候出的问题,提示如下,大家指点下是什么问题,谢谢!!
ERROR:
EDK:1525 - INST:transfer_ddr_ddr_0 PORT:BRAM_EN -
   E:\Project\MEM_ddrtoram\system.mhs line 250 - port is driven by a sourceless connector
ERROR:EDK:1525 - INST:transfer_ddr_ddr_0 PORT:BRAM_WEN -
ERROR:EDK:1525 - INST:transfer_ddr_ddr_0 PORT:BRAM_Addr -
ERROR:EDK:1525 - INST:transfer_ddr_ddr_0 PORT:BRAM_Dout_i -
MHS的第250行如下!!
BEGIN transfer_ddr_ddr
PARAMETER INSTANCE = transfer_ddr_ddr_0
PARAMETER HW_VER = 1.00.a
BUS_INTERFACE SPLB = mb_plb
PORT clk = clk_125_0000MHzPLL0
PORT rst = sys_rst_s
PORT aAddr_o = Addr
PORT aAddrReq_o = AddrReq
PORT aRNW_o = RNW
PORT aSize_o = Size
PORT aInitDone_i = InitDone
PORT aAddrAck_i = AddrAck
PORT aRdFIFO_RdWdAddr_i = RDFIFO_RdWdAddr
PORT aWrFIFO_Data_o = WrFIFO_Data
PORT aWrFIFO_BE_o = WrFIFO_BE
PORT aWrFIFO_Push_o = WrFIFO_Push
PORT aWrFIFO_Flush_o = WrFIFO_Flush
PORT aWrFIFO_Empty_i = WrFIFO_Empty
PORT aWrFIFO_AlmostFull_i = WrFIFO_AlmostFull
PORT aRdModWr_o = RdModWr
PORT aRdFIFO_Pop_o = RDFIFO_Pop
PORT aRdFIFO_Flush_o = RDFIFO_Flush
PORT aRdFIFO_Data_i = RDFIFO_Data
PORT aRdFIFO_Empty_i = RDFIFO_Empty
PORT aRdFIFO_Latency_i = RDFIFO_Latency
PORT BRAM_EN = BRAM_EN
PORT BRAM_WEN = BRAM_WEN
PORT BRAM_Addr = BRAM_Addr
PORT BRAM_Dout_i = BRAM_Dout
PORT BRAM_Din_o = BRAM_Din
END
AutoESL 发表于 2011-9-7 17:42 | 显示全部楼层
找找这个东西,看似是空的...
ooljo 发表于 2011-9-8 07:27 | 显示全部楼层
看得我眼睛花了
vivisa 发表于 2011-9-14 09:23 | 显示全部楼层
fwfjndx 发表于 2015-1-17 15:26 | 显示全部楼层
说明port没有连到制定端口,是不是
