[电路/定理] TPA3221复位RESET时序和脉宽问题
1738|5
 楼主| shaorc 发表于 2019-3-28 17:50 | 显示全部楼层 |阅读模式
想看如图芯片复位时序,复位脉冲宽度是多少,再选取通用的复位芯片型号
看了整个手册 就只有这个图包含有复位信号RESET
这个图可以看出复位时序和复位脉宽吗?如何看
零三翟邢止胃 发表于 2019-3-29 08:34 | 显示全部楼层
我帮你看看啊!!!!!
airwill 发表于 2019-3-29 10:33 | 显示全部楼层
你要看 RESET 信号吗?
9.4.3 Device Reset
Asserting RESET low initiates the device ramp down. The output FETs go into a Hi-Z state after the ramp down
is complete. Output pull downs are active in both BTL mode and PBTL mode with RESET low.
In BTL modes, to accommodate bootstrap charging prior to switching start, asserting the RESET input low enables weak pull-down of the half-bridge outputs.
Asserting RESET low removes any fault information to be signaled on the FAULT output, that is, FAULT is forced high. A rising-edge transition on RESET allows the device to resume operation after a fault. To ensure thermal reliability, the rising edge of RESET must occur no sooner than 4 ms after the falling edge of FAULT.
The TPA3221 will enter a low power state once the ramp down sequence is complete.
这个信号是个输入信号.
 楼主| shaorc 发表于 2019-3-29 10:57 | 显示全部楼层
你要看 RESET 信号吗?
9.4.3 Device Reset
Asserting RESET low initiates the device ramp down. The outp ...
谢谢回答
我自己也看到了这句话
【1】你说这是个输入信号是什么意思 谁输入给谁?是复位电路(复位芯片)输出给功放芯片的吧
【2】上面这句英文 这个4ms也不是复位脉宽啊
airwill 发表于 2019-3-29 14:53 | 显示全部楼层
是外部输入的信号, 要求不要低于 4mS 嘛
 楼主| shaorc 发表于 2019-3-29 14:58 | 显示全部楼层
谢谢
