linux内核启动到mice后就终止,求高手解答
2989|0
 楼主| gejianjun1027 发表于 2011-9-18 14:26 | 显示全部楼层 |阅读模式
使用的是ATMEL原厂提供的AT91G20-EK,把文件全部烧好后,系统启动,但是启动到mice后就终止,如下是串口打印出来的数据:
   RomBOOT
U-Boot 1.3.4 (Oct 30 2009 - 09:53:33)
DRAM:  32 MB
NAND:  256 MiB
In:    serial
Out:   serial
Err:   serial
Net:   macb0
macb0: Starting autonegotiation...
macb0: Autonegotiation timed out (status=0x7849)
macb0: link down (status: 0x7849)
Hit any key to stop autoboot:  0
NAND read: device 0 offset 0x100000, size 0x200000
Reading data from 0x2ff800 -- 100% complete.
2097152 bytes read: OK
NAND read: device 0 offset 0x400000, size 0x400000
Reading data from 0x7ff800 -- 100% complete.
4194304 bytes read: OK
## Booting kernel from Legacy Image at 22200000 ...
   Image Name:   Linux-2.6.27
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1578020 Bytes =  1.5 MB
   Load Address: 20008000
   Entry Point:  20008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................
......................................... done, booting the kernel.
Linux version 2.6.27 (root@localhost.localdomain) (gcc version 4.0.0 (DENX ELDK
4.1 4.0.0)) #5 Wed Dec 9 14:23:10 CST 2009
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: Atmel AT91SAM9G20-EK
Memory policy: ECC disabled, Data cache writeback
Clocks: CPU 396 MHz, master 132 MHz, main 18.432 MHz
CPU0: D VIVT write-back cache
CPU0: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
Kernel command line: root=/dev/ram rw ramdisk_siz=16000 men=32M initrd=0x2110000
0,6000000 console=ttyS0,115200
AT91: 96 gpio irqs in 3 banks
PID hash table entries: 128 (order: 7, 512 bytes)
Console: colour dummy device 80x30
console [ttyS0] enabled
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 23296KB available (2908K code, 242K data, 128K init)
Calibrating delay loop... 197.83 BogoMIPS (lpj=989184)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 288 bytes
NET: Registered protocol family 16
AT91: Power Management
AT91: Starting after general reset
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 5859K
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
yaffs Dec  9 2009 14:23:04 Installing.
msgmni has been set to 56
io scheduler noop registered
io scheduler anticipatory registered (default)
Console: switching to colour frame buffer device 16x10
fb0: Baite InternetRadio lcd device, using 1024K of video memory
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIAL
atmel_usart.2: ttyS2 at MMIO 0xfffb4000 (irq = 7) is a ATMEL_SERIAL
brd: module loaded
loop: module loaded
ssc ssc.0: Atmel SSC device at 0xc2970000 (irq 14)
MACB_mii_bus: probed
eth0: Atmel MACB at 0xfffc4000 irq 21 (00:22:33:11:44:55)
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:00, irq=-1)
Driver 'sd' needs updating - please use bus_type methods
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bi
t)
AT91 NAND: 8-bit, Software ECC
Scanning device for bad blocks
Bad eraseblock 1633 at 0x0cc20000
Creating 3 MTD partitions on "atmel_nand":
0x00000000-0x00400000 : "Bootstrap"
0x00400000-0x04000000 : "Partition 1"
0x04000000-0x10000000 : "Partition 2"
usbmon: debugfs is not available
at91_ohci at91_ohci: AT91 OHCI
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1
at91_ohci at91_ohci: irq 20, io mem 0x00500000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
udc: at91_udc version 3 May 2006
mice: PS/2 mouse device common for all mice
  跪求高手,解答,小弟感激不尽!
